 Old 09-05-2011, 12:39 AM   #1
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
Default stock turbo replacement upgrade
well i have searched and maybe my searching skills are somewhat lacking as a brownie, but.
since the factory k04 is trash is there a turbo upgrade that maintains stock power levels but has a better design (i.e. no smokage)?
i have no plans of going bt and just want a reliable replacement.
thank you for your time and patience.
jon
671 grains of reason is offline   Reply With Quote
 Old 09-05-2011, 12:40 AM   #2
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
search for bnr turbos.
417whp 428tq 12.037@117.2mph
The Following User Says Thank You to Snyeed For This Useful Post:
671 grains of reason (09-05-2011)
 Old 09-10-2011, 09:25 PM   #3
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
bnrsupercars.com
I would strongly recommend the stage III as it can support close to 400whp and will spool very close to stock.
If you really never want much more than stock power then the stage I or II will suffice.
671 grains of reason (09-10-2011)
 Old 09-10-2011, 09:34 PM   #4
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Fuck bolt-ons. Go with a top mount and do it right. GTX3076R. It will spool almost as fast as the trash K04 and it will give you so much more car that you will cream everytime you hear it spool up.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says Thank You to zpele For This Useful Post:
 Old 09-10-2011, 10:35 PM   #5
thanx guys but the stage one will do. im not power hungry kinda guy. just want a upgrade to the crappy k04.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
 Old 09-11-2011, 06:26 AM   #6
Eth/Meth Junkie
cld12pk2go's Avatar
~1400 RPMs later is hardly the same spool. The K04 can spool around 2300 PRMs. The last 3076 I tuned spooled around 3700 RPMs.
That is not even remotely close.
Why do you want to upgrade? Is your K04 smoking?
Personally, I am still beating the living hell out of my stock K04 and it is performing fine. So if yours is working ok, then there is no reason to waste money/effort to upgrade if you do not desire more power capability. The stocker is most likely going to live for > 100K miles without issue.
Also, many people end up upgrading twice due to wanting more later. This is why I suggest the BNR stage III as it can be make stock-like power at ~15 PSI or be pushed much further for more power later. You can expect full spool around 2800 RPMs with the BNR Stage III. The stage I/II will probably be closer to 2500 RPMs.
Last edited by cld12pk2go; 09-11-2011 at 08:00 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
671 grains of reason (09-13-2011), asall667 (09-11-2011), MSMS3 (09-11-2011)
 Old 09-11-2011, 07:16 AM   #7
MSP611's Avatar
Posts: 2,291   (View Stats)
i will be runnin a PG reworked... spools like 300rpms later then stock but with a lil bigger compressor wheel to make some power.
In progress:
 Old 09-11-2011, 07:21 AM   #8
Eth/Meth Junkie
cld12pk2go's Avatar
FYI, K04 reworks are going to be less reliable than the stock K04 as they keep all the K04 guts except for the compressor wheel.
The BNR replaces all the rotating parts with much beefier GT28 components, which will be much more reliable.
 Old 09-11-2011, 07:50 AM   #9
MSP611's Avatar
mayb so but i have seen multiple threads on here tht have had no problem
In progress:
 Old 09-11-2011, 07:52 AM   #10
Eth/Meth Junkie
cld12pk2go's Avatar
While that is true, there are also many failure threads.
Good luck.
Alpha (09-11-2011)
 Old 09-11-2011, 07:56 AM   #11
shadesofgray19's Avatar
Posts: 794   (View Stats)
bnr is the way to go. I recommend you get the stage II.
 Old 09-11-2011, 08:09 AM   #12
MSP611's Avatar
i dont plan on it to go forever but i plan on it to last me to i get to where i wanna rebuild fully and go top mount gt3076
In progress:
 Old 09-11-2011, 08:58 AM   #13
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
First you should learn to donate.
Then you should learn that the smoking turbo isn't actually caused by the turbo itself.
"Exclusivity" - CP-enis
Demodded.
The Seals
MSMS3 (09-11-2011)
 Old 09-11-2011, 09:22 AM   #14
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
if u can wait til spring 2012, you can have mine for $500 shipped lol
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
 Old 09-11-2011, 01:55 PM   #15
zpele's Avatar
Groans: 354
Neutral  :  -1 score
I'm not talking about a regular 3076 im talking about the GTX3076R. Look it up before you start spouting ignorant shit.
The Following 2 Users Say NO Thank You to zpele For This Un-useful Post:
cld12pk2go (09-11-2011), manelscout4life (09-11-2011)
 Old 09-11-2011, 01:59 PM   #16
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
gtx3076 wont spool faster then the gt3076. It will just make more power.
manelscout4life is offline   Reply With Quote
The Following 4 Users Say Thank You to manelscout4life For This Useful Post:
Alpha (09-11-2011), Brian MP5T (09-15-2011), JacksonMS30 (09-14-2011), themytb (09-14-2011)
 Old 09-11-2011, 02:02 PM   #17
Ziggo's Avatar
Posts: 3,843   (View Stats)
QFT. The GTX difference is a more efficient compressor wheel, it has nothing to do with spool.
Even if you don't want power, get the stage 3. You can tune it however you want and the spool difference from stock is hardly noticeable.
Zigatapatalka
Ask Me About My:
 Old 09-11-2011, 02:03 PM   #18
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
use your mouth
The Following 2 Users Say Thank You to dooderek For This Useful Post:
spoolin00 (09-11-2011), Tokay444 (09-11-2011)
 Old 09-11-2011, 02:12 PM   #19
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
has any body tried the stage 3 of bnr???
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 09-11-2011, 02:13 PM   #20
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
I know ziggo does
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
 Old 09-11-2011, 02:15 PM   #21
dr_banano's Avatar
Originally Posted by PunjabiPlaya View Post
I know ziggo does
is there any thread about it ??
Dr_banano
 Old 09-11-2011, 02:16 PM   #22
Groans: 131
BNR S3 Swap How To
ATR tuning A BNR Stage 3
Cobb SRI
CPE 75 duro RMM
 Old 09-11-2011, 02:27 PM   #23
Eth/Meth Junkie
cld12pk2go's Avatar
Maybe you should understand the topic of discussion before posting misinformation...
They will both spool about the same and nowhere in the vicinity of a K04.
manelscout4life (09-11-2011), MSMS3 (09-11-2011)
 Old 09-11-2011, 05:34 PM   #24
2zz mr-s
dooderek's Avatar
Groans: 239
hahahha zpele doesnt even know how cars work.
 Old 09-11-2011, 05:39 PM   #25
Tokay444's Avatar
Groans: 793
Lol
Demodded.
The Seals
 Old 09-11-2011, 07:27 PM   #26
dixie789456's Avatar
Posts: 635   (View Stats)
dixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the world
Groaned at 25 Times in 15 Posts
if that is the case then why did my smoking turbo disappear after getting a replacement turbo.... no other work was done to the car?
dixie789456 is offline   Reply With Quote
 Old 09-11-2011, 07:43 PM   #27
Tokay444's Avatar
Groans: 793
Ha!
The problem lies with the unrestricted volume of oil flow, and the fact that the return line dump back into the block right at the crank, so it just gets splashed back and doesn't drain, and then has nowhere to go but under the seals.
Demodded.
The Seals
MSMS3 (09-11-2011)
 Old 09-11-2011, 07:55 PM   #28
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
gt3071 + or GTFO.
Just kidding...kinda. I only know hearsay about the BNR's but for a similar price point you can get a drop in ATP 3071/76 for $300 more. I would run the 30 series @ 18 psi over the BNR @ 18 simply because I don't miss the torque spike down low. I find it much easier to manage wheel spin when it comes on in a linear fashion rather than the on/off switch at lower rpms of the quicker spooling turbos. I know the BNR will not be as bad as the K04 but I know many people here really enjoy the driving dynamics of the GT30 series.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
dsmluck is offline   Reply With Quote
The Following User Says Thank You to dsmluck For This Useful Post:
Alpha (09-11-2011)
 Old 09-11-2011, 08:04 PM   #29
Posts: 2,827   (View Stats)
Stock turbo is not trash. And most "smoking" turbos that are replaced turn out to have nothing wrong with them. The problem is in the PCV system and the restrictor size in some of the earlier stock turbos. Mazda has revised the turbo several times. There's good data that the current replacement turbo does have substantially smaller oil passages that work like an aftermarket restrictor.
If you want that quick spool up of the stock turbo and don't plan to make more than 300-310 or so whp, stick with the stock turbo.
 Old 09-11-2011, 08:47 PM   #30
Ha!
so then if that is the case why is my new turbo not smoking? it has more miles on it than old smokey did! lol
 Old 09-11-2011, 09:25 PM   #31
Eth/Meth Junkie
cld12pk2go's Avatar
Originally Posted by dsmluck View Post
gt3071 + or GTFO.
It cost alot more than $300 when you consider all the other supporting parts that are required to go to a GT30 series turbo (manifold, downpipe, intake, in addition to the more expensive turbo). That is the beauty of the BNR.
Also the boost/torque spikes you refer to can be totally removed via tuning. They are not intrinsic to the turbo.
 Old 09-11-2011, 09:33 PM   #32
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i still laugh at people who blame the pcv valve and shit for the garbage ko4, i got gt3076 and never had a hint of smoke issues.
 Old 09-11-2011, 09:38 PM   #33
Tokay444's Avatar
Groans: 793
See the post RIGHT above yours for your answer.
Demodded.
The Seals
 Old 09-11-2011, 09:38 PM   #34
dsmluck's Avatar
Groans: 60
No. The only thing you need extra over a BNR is a new TIP. Picked one up for $150 used. You can easily rock a 3071 or 3076 with the stock mani, intake, and DP. I am on the stock manifold and normal sized MAF and I put down about 40 more HP than a BNR stage 3 that Dynoed with similar mods at my altitude. Granted I paid about $400 more between the TIP and turbo. Pretty insignificant when you compare the power potential. Even for lower power goals I pick a cooler running gt30.
 Old 09-11-2011, 10:55 PM   #35
Alpha's Avatar
Posts: 3,711   (View Stats)
Actually, the BNRs can be ran with the factory sized TIPs. Forzda and the others that are running them have confirmed this.
For OP's application, I'd also recommend the S3 BNR.
 Old 09-11-2011, 11:26 PM   #36
mazdaspdmike's Avatar
Posts: 784   (View Stats)
mazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the worldmazdaspdmike is the leader of the world
Groaned at 50 Times in 30 Posts
He was referring to the ATP turbo. It needs a bigger TIP because it's got a 4" inlet.
BNR's are designed to be drop-in with stock parts.
'12 Ford Focus SEL
mazdaspdmike is offline   Reply With Quote
 Old 09-11-2011, 11:49 PM   #37
2zz mr-s
dooderek's Avatar
Groans: 239
just to play devils advocate here. ask any tuner who has never dealt with a mazdaspeed. they will all say the same thing about the k04, great fucking turbos. not sure if its triple k or mazda engineering to blame, but they are to the outside msf world a very good turbo
The Following User Says Thank You to dooderek For This Useful Post:
Tokay444 (09-12-2011)
 Old 09-11-2011, 11:58 PM   #38
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Ask any GTI owner with a K04. Shit makes power.
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
easy (09-14-2011), Tokay444 (09-12-2011)
 Old 09-12-2011, 06:16 AM   #39
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Or the Cobalt SS guys. Their K04 is great.
07 MS3
The original Genpoo Hater
 Old 09-12-2011, 08:26 AM   #40
Ziggo's Avatar
Their K04 is a twin scroll with a big fat A/R so it doesn't choke off on the top end.
Ask Me About My:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/stock-turbo-replacement-upgrade-90844/
Design's Long Term Ownership/Build Thread This thread Refback 06-27-2015 05:41 PM
Turbo seals? : mazdaspeed6 This thread Refback 02-24-2015 05:36 PM
PTP super stock turbo upgrade. Anyone have/had one? Nataphen MazdaSpeed 3/6 - Turbo Induction 77 08-04-2010 08:05 AM
PTP super stock turbo upgrade. Any experiences? Nataphen 2010 MS3 - Turbo Induction 2 05-01-2010 10:37 AM
Stock Turbo & Medieval Manifold Upgrade ian101 MazdaSpeed 3/6 - Turbo Induction 14 06-10-2009 07:16 PM
Billet compressor wheel upgrade for the stock turbo!!!! ptperformance Mazdaspeed3/6 General Discussion 52 05-13-2009 05:20 PM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.57111 seconds with 40 queries
