Closed Thread
 Old 01-08-2013, 11:46 PM   #41
Mase33's Avatar
Posts: 19   (View Stats)
Mase33 is on a distinguished road
Wanted to know if this is the right bnoon bolt? --> Turbo Banjo Bolt Mazda Speed 3 6 w Restrictor to Prevent Exhaust Smoke | eBay
Just bought one last night. If its not genuine what do i need to be aware before install??
Mase33 is offline
 Old 01-09-2013, 03:33 AM   #42
Well, the holes are not the right size, based on what I read here....
Raider is offline
 Old 01-09-2013, 03:37 AM   #43
Mase33's Avatar
thanks for reply raider..
its shitty cause i bought it already and do u know where do i modified to make it good ?
Mase33 is offline
 Old 01-09-2013, 03:42 AM   #44
Yeah, search for @bnoon's thread. Oil restricted bolt install or something. Cannot tell if already posted in this thread already, it might be. Drill press and proper drill bits.
Raider is offline
 Old 01-09-2013, 03:49 AM   #45
Mase33's Avatar
Ok got it.
one question: whats the correct ' length' to drill at the stem of bolt. Imagine i have a bolt length 30mm, am i gona drill right before side hole or over it?
Any recommendation? 20mm-25mm perhaps?
Mase33 is offline
 Old 01-10-2013, 09:09 AM   #46
jhample's Avatar
Posts: 72   (View Stats)
jhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud ofjhample has much to be proud of
May be about the right size. bnoon said it should be .06" which is ~1.524mm. Listing says its 1.5mm. Not sure what that small difference will do though. I may pick one up
Cobb SRI / Cobb TIP / Forge BPV V1 / TRZ RMM / JBR PMM / JBR SSP / H&R Springs / Autometer Boost Gauge
jhample is offline
 Old 01-10-2013, 09:18 PM   #47
Mase33's Avatar
Hi all,
My question:
whats the length to drill in the center hole? im using 15/64" bit as recommended but not sure to which extend i need to drill.
Before or just ''meet'' side hole?
mase
Mase33 is offline
 Old 01-27-2013, 05:57 PM   #48
rolanblack's Avatar
Posts: 2,110   (View Stats)
Originally Posted by bnoon View Post
FYI WARNING!!! The restrictor bolt side hole is too small!!! ENLARGE IT!!! .060" is the BARE MINIMUM and they are under that by several thousands. I have no problem with other people selling banjo bolts, but they WILL NOT use my name to expand their sales. I have another problem with them not doing the research needed, and then providing a bolt with insufficient specs. Fucking tards.
Already been covered.
Search
Donate.
rolanblack is offline
 Old 02-13-2013, 03:01 PM   #49
mazdamx3freak's Avatar
Posts: 219   (View Stats)
mazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond reputemazdamx3freak has a reputation beyond repute
I also bought this same ebay bolt. my question is I cant find the exact bit size anyware local only online. would using a 1/16 bit for the center bore work. Bolt center bore is 1.5mm with a 1/16 bit i would be 1.58mm.
2008.5 CPW
JBR:3.5 intake, fmic, r51 Battery Box, Ancors, EGR Delete, Thermal Spacers, 5mm Wheel spacers, Shift plate.
Matt Dimond OCC, Autotech Internals, CNT catted downpipe, itv-22, Threadstone T8L FMIC,SU Turbosmart Bpv, SUv2 Rmm
mazdamx3freak is offline
 Old 02-14-2013, 07:00 PM   #50
anyone have any info. I really need to install it to stop the smoke
2008.5 CPW
 Old 02-22-2013, 12:24 AM   #51
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
These still being made or do I need to buy it off email? Also found great reference threads.
Bnoon restrictor bolts
Oil restrictor bolt install
redboat is offline
 Old 02-22-2013, 03:07 AM   #52
Not made. Buy off email? Sounds risky.
Time to read the how-to on making one, know the eBay size is different and not recommended. Oh, and search.
Raider is offline
Closed Thread
Bnoon Banjo turbo restrictor bolt tburton101 MazdaSpeed 3/6 - Turbo Induction 24 07-13-2009 10:06 AM
Page generated in 0.31880 seconds with 25 queries
