 Old 12-20-2016, 09:20 PM   #1
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Default Turbo Blanket vs. Ceramic coating BNR S4
So I have a new S4 to install once my block is done being built, and since I have the turbo still off, I'd like to either get a blanket for it or get it coated. My question is if I get it coated, would I even need a blanket? Or would it still be beneficial to have the blanket as well? So one or the other or both??
Speaking of blankets, what size blanket do I need for the S4, does anyone know?
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 12-20-2016, 09:56 PM   #2
I went with the Ceramic Coat on my S4 and on my manifold. And if you combined it with the blanket it should keep more of the heat inside the turbo.
Sent from my Pixel XL
 Old 12-21-2016, 12:22 AM   #3
HaXiR's Avatar
Ok, well now I just need to find a blanket that fits the S4
Current:
 Old 12-21-2016, 05:23 AM   #4
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Finding a blanket is going to be quite difficult not because of its size, but because of the shape of the mazda flange.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
meicalnissyen (12-25-2016)
 Old 12-21-2016, 08:41 AM   #5
That's the problem. It's hard to find an blanket to fit it. You might have to cut one to fit.
 Old 12-21-2016, 06:03 PM   #6
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
This one worked well enough on a GTX28. You do have to get inventive if you want to check the bolts while it is installed.
http://ptpturboblankets.com/T3/
 Old 12-21-2016, 07:37 PM   #7
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
I have one of these, second-hand from @silvapain; and it does not fit the K04 stock turbine housing. not sure about the s4.
-feejay
-wetzel
JSmith (12-21-2016), silvapain (05-11-2017)
 Old 12-25-2016, 07:36 PM   #8
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
I was happy with the one I used on the 3 with a 2867gtx, I shall try yo remember where I scored it. used SS wire to retain it, and hadda eff it a bit around WG linkage, but it was cool
Thinkin generic summit, but not sure.
I'll chase you If I find it
The Following User Says Thank You to meicalnissyen For This Useful Post:
mituc (12-26-2016)
Ceramic Coating or Header Wrap Nitr0EngiE MazdaSpeed 3 - Engine, Transmission & Driveline 51 11-14-2013 05:44 AM
ceramic coating TWOptSL0W Mazdaspeed3/6 General Discussion 4 03-29-2012 02:27 PM
Ceramic coating anyone? jlefebvre123 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 02:21 PM
ceramic coating ms3boost MazdaSpeed 3/6 - Turbo Induction 11 03-30-2009 02:12 PM
Page generated in 0.28431 seconds with 25 queries
