 Old 05-24-2017, 04:06 PM   #1
dbeckms3's Avatar
Posts: 15   (View Stats)
dbeckms3 will become famous soon enough
Default Turbo Inlet Hose/Pipe vacuum plug
The vacuum plug on the turbo inlet hose (goes from the TIH to the EBCS) broke. Attached is a picture of my solution. Brass fitting with clear hose and then drill a small hole where the old plug is and put the other end. Not sure how well it's going to do for disassembly if I have to do it again but for now it works okay.
2003 Civic Coupe LX - AutoX car (sold, sadly)
2008 MazdaSpeed3 GT - Daily
Last edited by dbeckms3; 05-26-2017 at 03:59 PM. Reason: Corrected what the plug is for
dbeckms3 is offline   Reply With Quote
The Following User Says Thank You to dbeckms3 For This Useful Post:
MSMS3 (05-25-2017)
 Old 05-24-2017, 06:14 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Should be fine for now. If it leaks, you'll run a bit lean in vacuum and rich in boost.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-25-2017, 06:57 AM   #3
Posts: 2,826   (View Stats)
Good tip. The "sensor" is actually the electronic boost control solenoid or EBCS. It's not a sensor, itself, but controls boost by opening and closing the vacuum ports based on a triggering signal from the ECU.
 Old 05-26-2017, 03:58 PM   #4
dbeckms3's Avatar
Thanks for the correction/information!
 Old 05-25-2017, 07:44 AM   #5
Omega's Avatar
Posts: 441   (View Stats)
people will never learn to cut the hose off the plastic barb on the ebcs...
2006 Super Clean BCM MS6
 Old 09-26-2018, 05:35 PM   #6
Tomumass06's Avatar
Posts: 18   (View Stats)
Tomumass06 has a little shameless behaviour in the past
I broke that piece as well. What did you use to keep the clear tube inplace? Silicone? Or am I interpreting this wrong? Either way, cool fix!
Tomumass06 is offline   Reply With Quote
 Old 10-02-2018, 06:11 PM   #7
dbeckms3's Avatar
You know, I'm looking back at this and I can't for the life of me figure out what that clear hose is for... basically just get a brass fitting and stick it in the hole where the plastic plug was. I've since swapped in the Cobb TIH so I don't really have the issue anymore. Just checked the OEM TIH and it just has the brass fitting. I'll update to post to remove the clear tube.
Turbo Inlet Hose Spectrum24x Mazdaspeed3/6 General Discussion 12 02-20-2012 02:21 PM
TURBO INLET HOSE, Love it jeffdevo CorkSport 0 04-17-2011 04:26 PM
Page generated in 0.26940 seconds with 25 queries
