 Old 08-28-2012, 06:39 AM   #1
joey's Avatar
Posts: 63   (View Stats)
joey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to all
Unhappy Turbo seals went
YAY so my turbo started smoking after 2 years of owning my mk1. I dreaded this day for sooooo long since knowing the mk1 had a dodge turbo and that the seals were going to give in one day..
Anyway I also found another boo-boo, the ss gasket between the ex-mani and the tb was klaaaaar :bash: Dunno what the previous owner did to it, but yeah would also explain why my consuption was soooo bad.
Took me about 2.5hours to remove all in a small garage and with only a scissors jack LOL *takes a bow :king:
The impeller had a lot of play! Almost 2mm
I sent the turbo in today at TURBO REPAIR MASTER-021 511 8641/2 - 082 899 6930 - Mieshal Parker and getting re-conned under warranty. They will try and see if they can upgrade to bearing type.
Where can I get this gasket, except from the stealership?
Gasket:
DP:
Tourboless:
Turbo:
Also painted my heatshield with 900deg gloss black:
Versatune :: FMIC :: 3" SRI :: 3" TIP :: HKS SSQv4 :: 3" Turboback :: Devil's Own WMI Stg2 kit :: Autotech HPFP :: JBR EGR delete :: JBR BSD & Baffle plate :: Racing Logic coilovers :: TRZ TMM :: AWR PMM :: Poly bushes all round :: SURE RMM :: SURE Shortcut&Counter weight :: SURE g/knob :: PG PCV fix :: Aeroforce dual Interceptor gauges :: Apexi TT :: HDI Stg2 Evo boost controller :: VIBE ICE
joey is offline   Reply With Quote
 Old 08-28-2012, 06:45 AM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
ok a few things:
its a gen1, not mk1, we dont have volkswagons.
the other person probably didnt tighten the turbo down properly
that 900 degree stuff may not be enough, you might want to go with 2000 degree stuff
I have a gasket for sale, pm me about it
The Following User Says Thank You to TWOptSL0W For This Useful Post:
faeker (08-28-2012)
 Old 08-28-2012, 06:48 AM   #3
joey's Avatar
Originally Posted by TWOptSL0W View Post
ok a few things:
Can you ship to South Africa? USPS?
 Old 08-28-2012, 07:00 AM   #4
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Mazda OEM Manifold Turbo Gasket MS3 MS6
Mods: stock
joey (08-28-2012), TWOptSL0W (08-28-2012)
 Old 08-28-2012, 07:14 AM   #5
TWOptSL0W's Avatar
Groans: 125
sorry thats a bit far for me, it would be cheaper to get it from edge or a dealer
 Old 08-28-2012, 07:17 AM   #6
joey's Avatar
No probs, thx anyway
 Old 08-31-2012, 01:52 AM   #7
joey's Avatar
Turbo came back and I fitted it yesterday! Plus a new gasket! So happy!!
Turbo seals! :/ not covered on warranty mazdaspeed4life MazdaSpeed 3/6 - Turbo Induction 12 03-09-2012 02:04 PM
Turbo seals done? titusdrake MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 09-23-2011 03:48 PM
turbo seals fried eronenris MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 07-19-2010 11:31 AM
i knew the turbo seals were gone but this much? k0m MazdaSpeed 3/6 - Turbo Induction 19 01-06-2009 04:04 PM
Bye Bye Turbo Seals Laloosh MazdaSpeed 3/6 - Turbo Induction 50 04-27-2008 08:55 PM
Page generated in 0.28478 seconds with 22 queries
