 Old 07-30-2010, 10:44 AM   #1
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
Default Turbo upgrade without a custom tune
Sup guys,
I'm tempted to upgrade my stock K04. But as most of you know, the Mexican FAIL-ECU doesn't recognizes COBB AccessPort and COBB is "too busy" to help us...
So, without a custom tune we only have Hypertech or Piasini as a solution. I have the Hypertech and it has worked great on my car... But... I've been checking lots of threads of turbo upgrade uptions such as PTP, ATP, BNR... that I'm tempted to get one of those... I don't want an extremely BIG turbo, but something that can go PNP without any other issue... (Maybe BNR Stage 1 or 2..)
What options do you recommend? Will it work with my Hypertech tune? Should I use a manual boost controller?
Thanks everyone in advance!
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 07-30-2010, 10:49 AM   #2
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
only one way to find out man, buy one and be the guinea pig! Then i will follow you if it works good, if you blow up, ill be safe. Its a win-win.
09 MGM MS3
The Following User Says Thank You to Addikted To Boost For This Useful Post:
Dre (07-30-2010)
 Old 07-30-2010, 11:00 AM   #3
EnzoR's Avatar
Posts: 256   (View Stats)
EnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond reputeEnzoR has a reputation beyond repute
Wonderful question, anyone with viable info to be the guide for the masses?
thehatingnetwork.com
EnzoR is offline   Reply With Quote
 Old 07-30-2010, 11:04 AM   #4
The big question is regarding boost control. If you choose to use the stock solenoid and ECU with a non stock turbo and wastegate you can run into issues (too much or too little boost). Using an independent boost controller in this case my address the issue.
 Old 07-30-2010, 11:07 AM   #5
EnzoR's Avatar
How will smoking crack rocks affect this particular situation?
 Old 07-30-2010, 04:26 PM   #6
RGV_MS3's Avatar
Posts: 893   (View Stats)
RGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the worldRGV_MS3 is the leader of the world
Groaned at 12 Times in 5 Posts
I got a US ECU that you can buy from me, that's if you want to go CP-e or Cobb tunes. Only thing is I haven't found the spare key for the ECU so you will have to reprogram your keys to the ECU.
Originally Posted by alien_sporez View Post
Some say that when he exhales he makes a "PSHHH" sound... and that when women see him they immediately go into the kitchen and make him a sandwich... all we know is he's called FORZDA, the MSF Stig
2009 Rally Yellow Cobalt SS/TC
K&N Intake, Badmab Catless Downpipe, ZZP FMIC Kit, Forge BPV, Mpx Exhaust, Dual Aeroforce Gauges, R1 Concept Drilled and Slotted Rotors, E85 Tune
310 WHP 330 WTQ 93 Octane
347 WHP 386 WTQ E85
RGV_MS3 is offline   Reply With Quote
 Old 07-30-2010, 04:36 PM   #7
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
that's like living on borrowed time. don't do it.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
So i did a custom tune... R.MS3 MazdaSpeed 3/6 - ECU Computer Tuning 21 03-24-2011 04:54 PM
Custom AP tune Dyno runs Snyeed MazdaSpeed 3/6 - Dyno Sheets/Discussions 13 07-28-2010 04:48 PM
CUSTOM dyno tune at COBB HQ 3-12-09 ljudgeii MazdaSpeed 3/6 - Dyno Sheets/Discussions 66 10-09-2009 02:56 PM
Will be getting a custom tune soon!! DYNO DAY!! johnac08 MazdaSpeed 3/6 - Dyno Sheets/Discussions 18 02-21-2009 07:39 PM
Surgeline Custom Tune w/ ETS TMIC TXS TBE Cobb SRI PDXImportRacer MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 11-16-2008 12:21 PM
Page generated in 0.29340 seconds with 25 queries
