 Old 03-16-2008, 03:52 PM   #1
kneedragger241's Avatar
Posts: 67   (View Stats)
kneedragger241 has a spectacular aura aboutkneedragger241 has a spectacular aura about
Default Want to upgrade that leaky valve...
But I'm not a fan of the Forge sound.
How does the TurboXS unit compare? Don't read about to many people with that unit.
Is there a benefit to VTA or hybrid over straight recirculating other than the BOV sound?
Any other suggestions for an upgraded valve are welcome.
Thanks!
kneedragger241 is offline   Reply With Quote
 Old 03-16-2008, 03:59 PM   #2
TurboXS unit is nice.. But if you are looking for something a little more low cost with some polished bling, the Forge is a good option too. Hyprid or VTA is just for sound imho...
 Old 03-16-2008, 05:07 PM   #3
ptperformance's Avatar
Posts: 4,123   (View Stats)
How about something that does both? With ease of adjustment and a great sound.
 Old 03-16-2008, 04:13 PM   #4
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
I have the hybrid and I'm happy with it. There isn't much else to say. Its not loud at all until you get an intake
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 03-16-2008, 04:32 PM   #5
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
Thanks!
I'm in the same boat as you. Why can't they have a $160 or less valve that sounds like stock or just not annoying.
 Old 03-16-2008, 05:08 PM   #6
Sorry, quality is going to take more money then that. You can get the TurboSmart units that are recirc only that hold more boost with easy adjustments, but you will have to build a flange in order to get them to fit the stock mounting flange.
 Old 03-16-2008, 06:02 PM   #7
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groans: 57
im running the turbosmart and like it, its actually a lil to loud for me as im 100 vta, but screw it, helps me keep the gas mileage up by not hitting boost
Laloosh is offline   Reply With Quote
 Old 03-16-2008, 09:02 PM   #8
Turn the control knob, it will quiet down quite a bit.
 Old 03-16-2008, 05:06 PM   #9
Thanks!
TurboSmart and we have them in stock. Don't waste your money on the Forge units, they have a horrible reputation for the diaphrams leaking. The XS units are not bad, but the TurboSmart units are just that much better.
Check out the site and there should be a sound clip of on on there, thanks.
http://www.pt-performance.com/showPr...&cID=2&pID=113
 Old 03-18-2008, 01:17 AM   #10
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
I have googled trying to find people experiencing problems with the Forge and havent had much success. Got any info on that? jw because I bought a Forge but havent installed it yet.
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline   Reply With Quote
 Old 03-18-2008, 07:40 AM   #11
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
My forge kicks ass
NYpest is offline   Reply With Quote
 Old 03-18-2008, 09:10 AM   #12
The MS is still to new. They have had issues with the EVO, SRT4 and WRX models. They diaphram keeps blowing out of them.
 Old 03-17-2008, 06:48 PM   #13
NYpest's Avatar
Thanks!
Robot chicken kicks ass
 Old 03-17-2008, 11:57 PM   #14
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
go with the hks its well woth the price for the performance.
You can see more on mymyspace
occschemguy is offline   Reply With Quote
 Old 03-18-2008, 12:11 AM   #15
HKS's valve is really over related and needs a conversion flange to work. More people replace it, than keep it.
 Old 03-18-2008, 01:46 AM   #16
prototype_x9's Avatar
Posts: 174   (View Stats)
prototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the worldprototype_x9 is the leader of the world
I just installed the Turbosmart hybrid and it sounds just like the factory valve only a little louder. Plus, it comes with the block off plate so you can run it in full recirc or full VTA. I would suggest this valve to anyone.
Resale value of the valve should be very high also.
prototype_x9 is offline   Reply With Quote
 Old 03-18-2008, 01:52 AM   #17
^ So the turbosmart can be full recirc and you dont need to build a flange or buy one? PTPs site says its just bolt on but on here he said you need to build a flange
Lightweight and compact, the Dual Port MPS bolts directly onto the factory plumbing with no specialised tools needed. Supplied with a “screw-in” blanking plug for easy conversion to a fully recirculating (Plumb Back) or a fully atmospheric (Supersonic) BOV.
 Old 03-18-2008, 01:57 AM   #18
The Turbosmart ones ive seen already have the flange, its the HKS's that need the flange. Great BPV if the price doesnt scare you away. Eventually ill move to one when i go big power. The little forge can only handle so much boost with its multiple springs and 2 shims.
 Old 03-18-2008, 09:11 AM   #19
The "recirc only units" need to have a flange built for them. There is a direct bolt on that can be converted to recirc only if need be.
 Old 03-18-2008, 02:20 AM   #20
^ Well I took mine apart and noticed quite a bit of o ring residue inside. Is this normal?
I just tested it to see if my piston had an obvious leak. I depressed the piston with my finger and then covered the vacuum fitting with another finger. Stopped depressing the piston with my finger and the piston did not move until I took my finger off the vacuum fittings orifice. Of course thats not real world but it seems like its sealing properly unless what I did means nothing lol
Plus this model has no diaphram.
 Old 03-18-2008, 07:29 AM   #21
I watched a video of a car with the Forge valve and to borrow another poster's words, it sounds like the cha-ching of coins much like a sound effect from Super Mario Brothers.
That would drive me up the wall!
The Turbosmart unit seems like overkill and a waste if all I'm going to do is install the block-off plate.
I'm not planning on adding any more boost. At least not in the near future. :-p
2007 True Red Mazdaspeed3
I'm on the MySpace
 Old 03-18-2008, 07:49 AM   #22
NYpest's Avatar
Someone has mentioned that the ca-ching noise can be quieted down/gone using a softer dump tube. Im not sure this works as i havent tried it. I dont mind the noise i neither like it or hate it.
 Old 03-18-2008, 09:13 AM   #23
TS unit is over kill, why not build a better part and never have to worry about it?
DI pump upgrade, ohhhh...... ptperformance Mazdaspeed3/6 General Discussion 165 02-13-2010 04:22 PM
Microsoft Windows Vista Home Premium w/Service Pack 1 Upgrade $99.99 Free Shipping Haltech Hot Deals Section 0 04-07-2008 01:20 PM
Stock turbo upgrade mdogg MazdaSpeed 3/6 - Turbo Induction 20 03-31-2008 02:14 PM
Page generated in 0.43382 seconds with 29 queries
