 Old 03-18-2014, 08:39 PM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default Whats the normal vacuum psi range for a Speed6
I know one of you guys knows the normal operating vacuum psi range for a Speed6?
After installing the TS BOV, CS TIP and various other tubes, I just want to make sure my DH reporting a range of -18 to -25 psi is normal.
TIA.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 03-19-2014, 12:13 AM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
FYI -18 to -25 isn't psi. Vacuum is in in/hg on the DH.
How many in Hg in 1 psi you ask? The answer is 2.0360206576.
You are reading -8.84psi to -12.28psi which is normal I guess, not knowing your altitude. I pretty much run the same range.
Pay attention to your long term fuel trims. They should be <5% across the closed loop RPM range. You can monitor those with the DH.
MINI H1 6.0 - CAR LED TAILS
Marcus (03-19-2014)
 Old 03-19-2014, 03:15 PM   #3
Marcus's Avatar
Ltft have usually been 10-13.... I'll check again when I leave this here shop. Hopefully the new fuel pump sets things right.
 Old 03-19-2014, 08:15 PM   #4
Marcus's Avatar
They're hovering around 7-8%.
 Old 03-19-2014, 08:26 PM   #5
Ya that's OK. Well within the range of the ecm being able to manage.
 Old 03-19-2014, 08:29 PM   #6
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
Stock in psi is -10.6ish idle, -8.8/9 with a/c condenser on. In NY, about sea level+80ft
kby is offline   Reply With Quote
The Following User Says Thank You to kby For This Useful Post:
Marcus (03-20-2014)
 Old 03-20-2014, 01:33 AM   #7
Marcus's Avatar
Thanks as I'm also coastal and about 120 above sea level.
 Old 07-04-2014, 10:14 PM   #8
GG6
GG6's Avatar
Posts: 2   (View Stats)
GG6 is on a distinguished road
I usually run around 16 in.Hg at idle. I'm a little more than a mile above sea level normally.
GG6 is offline   Reply With Quote
Official: Pics Aplenty: 2013 Range Rover in Morocco (with 1971 Range Rover) Haltech Automotive News 0 11-07-2012 06:10 PM
Spy Shots: Next Range Rover Sport shot at close range Haltech Automotive News 0 07-16-2012 02:20 PM
Classic Mashup: 2011 Range Rover vs. 1993 Range Rover Haltech Automotive News 0 12-30-2010 07:20 AM
Normal vacuum at idle? Thestaplegunkid MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-05-2010 08:51 AM
whats normal ms3 power on a mustang dyno? Wenis Prinkle MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 08-13-2009 09:28 PM
Page generated in 0.28377 seconds with 23 queries
