![]() Join Date: Dec 2011 Location: Bergenfield, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 279
Groaned at 20 Times in 8 Posts
(Thread Starter) | Neutral : +2 score My reason for writing this up is cause, for some time I have been driving around not being able to use my blinkers/hazards due to the BCM(Body Control Module) has crapped out on me. This was determined after fuses were checked, and wirings were also checked. Mods please feel free to edit anything that you feel as an error...thanks Alright! So BCM(Body Control Module) image-1373969453.jpg You will need to disconnect the negative from your battery image-579068959.jpg Location: it is connected to the cabin fuse box as depicted here image-1046220323.jpg In order to remove the housing that contains BCM/Fusebox, you will need to remove the inner plastic lining that lays on the flooring of this "thingy". Doing so will unhinge the housing that contains the BCM. image-782364960.jpg As soon as housing is removed, you will see that the BCM is secured by a single 11mm bolt as shown below image-3871372257.jpg Once bolt has been removed, it is then all self explanatory where all that's left to do is simply unfasten the wiring through its "connector clips" and transfer wires/Fusebox to the new BCM image-3461147594.jpg There you have it! Pretty simple 15-20 min job or maybe less. Don't think I need to remind you folks to reconnect your battery =P Stay Frosty SSG P out
__________________ GT3076R//Custom FMIC with 13" Core with 3" piping//HTP 3.5 Intake/Inlet System with AEM Cone//CorkSport SS DownPipe//Custom 3inch Exhaust with Single Flowmaster Exit//Autotech Fuel Pump Internals//Prosport OCC//Devils Own Meth//GrimmSpeed EBCS//Bosch 3Bar//Cobb AccessPort V2//MSD DashHawk//TWM Stage 2 Short Throw Shifter//D2 Racing Coilovers//RotorPro Front and Rear Cross Drilled and Slotted Rotors//EBC Green Stuff Front and Rear Pads//ACT 6 Puck Clutch and Flywheel//CorkSport Front Strut Bar//CorkSport Rear Brace Bar//CorksSport Rear Differential Mount//CorkSport Front Sway Bar//Whiteline Rear Sway Bar//CorkSport LED Kit//AWR 80 Duro TMM/RMM/PMM//GTSpec 4 Point Ladder Brace Bar// ////MADSCIENTISTTUNED//// |
| The Following 5 Users Say Thank You to ArmySpeed6 For This Useful Post: | :: Gusto :: (03-04-2015), ChrisMazda3Owner (10-25-2018), mczimer (05-07-2013), Mistersix (06-17-2013), Poohster (05-18-2013) |
| Banned ![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
| Not Ranked : 0 score Best how to EVER |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score @ArmySpeed6; I have the same issue as you did. Horn blaring lights flashing. I'm wondering if this is my issue, that i zapped the bcm some how. Questions: 1.Did you short something and fry the bcm? 2.How did you come to the conclusion this was your issue? 3.Did this solve your problem completely? 4.Does this require and software writing? As in, how does it know your key fob? 5.Did you get this part from the dealer? Was it expensive? Trying to explore all options before i head to the dealership. |
1. I assume that whatever my buddy did, fried my bcm. 2. I did a few trouble shoots. tested fuse box inside the engine bay, checked for current and fuse life. Checked in cabin fuse box, but I checked what else were affected. 3. Once concluded/pinpointed the issue, it was all in the matter of finding someone who has one laying around. 4. My vehicle is the GT model but I lost my credit card key fob, so I am not sure whether or not any type of wiring was necessary, it was pretty much plug in play. 5. Dealership quoted me for $430 just for the part, time and labor is ridiculous, that alone would cost $185 per hour. also, make sure if you decide to lurk on here, make sure it corresponds to your vehicles model, ie. GT to GT, sport to sport. installation was very simple...but if you are like me, patience is NOT my best skill...nearly destroyed all the clips Cheers bud...
__________________ GT3076R//Custom FMIC with 13" Core with 3" piping//HTP 3.5 Intake/Inlet System with AEM Cone//CorkSport SS DownPipe//Custom 3inch Exhaust with Single Flowmaster Exit//Autotech Fuel Pump Internals//Prosport OCC//Devils Own Meth//GrimmSpeed EBCS//Bosch 3Bar//Cobb AccessPort V2//MSD DashHawk//TWM Stage 2 Short Throw Shifter//D2 Racing Coilovers//RotorPro Front and Rear Cross Drilled and Slotted Rotors//EBC Green Stuff Front and Rear Pads//ACT 6 Puck Clutch and Flywheel//CorkSport Front Strut Bar//CorkSport Rear Brace Bar//CorksSport Rear Differential Mount//CorkSport Front Sway Bar//Whiteline Rear Sway Bar//CorkSport LED Kit//AWR 80 Duro TMM/RMM/PMM//GTSpec 4 Point Ladder Brace Bar// ////MADSCIENTISTTUNED//// | |
| The Following User Says Thank You to ArmySpeed6 For This Useful Post: | Mistersix (06-17-2013) |
| Not Ranked : 0 score Thanks so much. I intend to pull it and make sure the numbers match. I just hope i don't need key codes written in or anything. This stuff is kinda new to me so i'm unsure of that. |
| The Following User Says Thank You to Mistersix For This Useful Post: | ArmySpeed6 (06-17-2013) |
I know there are a few dudes on here that, unfortunately totaled their six's...they should have it laying around.
![]() Join Date: Dec 2008 Location: CT :: Stratford :: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 632
Groaned at 34 Times in 27 Posts
| Not Ranked : 0 score Where did you buy your bcm from??
__________________ :: somewhere between CT & VA :: yea yea - i know i cant spell |
![]() Join Date: Dec 2014 Location: Saint Johns, FL
Rep Power: 213 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score If your question was for the OP, @ArmySpeed6;, he hasn't been active since 04-14-2014 04:00 PM. Seeing as his last post on this thread was on 06-17-2013 04:17 PM ... it's probably safe to say he will not be answering. Just a wild guess ...
__________________ 2007 MS3 GT Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks 2006 MS6 GT (ZZB Rebirth) Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts 1990 Miata I like it raw |
| The Following 2 Users Say Thank You to sporkbomb For This Useful Post: | :: Gusto :: (03-05-2015), ASHMS3 (03-04-2015) |
![]() Join Date: Sep 2016
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score My BCM went bad as well, taillights/dashlights go off intermittently when headlights are on. I have a replacement, but was told I need to get the computer flashed after I install it. Did you need to do this after your swap? |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | ||
| The Following User Says Thank You to Vansquish For This Useful Post: | sporkbomb (09-06-2016) |
![]() Join Date: Feb 2017
| The Following User Says NO Thank You to Tactown98499 For This Un-useful Post: | g00s3y (02-16-2017) |
Groans: 438
| Not Ranked : 0 score Holy shit, how many times can stupid happen in the same thread
__________________ All good things must come to an end... Last edited by g00s3y; 02-16-2017 at 04:30 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() Join Date: Jan 2018
| Not Ranked : 0 score Hello fellow Mazdaspeed Forum users, I own a 2012 Mazda 6 which I have had for 3+ years now. I look forward to receiving useful tips from this forum! |
![]() Join Date: Oct 2018
Rep Power: 0 ![]() Thanks: 1
Absolutely awesome how-to guide with pics..... But does anyone know if we have a BCM replacement for a 2010 Mazda 3? I have searched and searched and cannot find one.... ![]() Thanks! Chris | |
![]() Join Date: Oct 2015 Location: Central Jerz
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score Hello and welcome but I honestly dont think this forums gonna help you much with that '12 Mazda 6
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
| Not Ranked : 0 score I hope he get that since January
| Not Ranked : 0 score Yeah he probably got that quick lol. I didnt even notice, i thought that was the post that bumped the thread. I gotta put the crackpipe down smh
| The Following User Says Thank You to Bertospeed3 For This Useful Post: | monkey.bones.007 (10-25-2018) |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score Bert is fat.
__________________ 94 M MS6 IS350 |
| Not Ranked : 0 score hum that bumping post isn't even better....a guy not finding used parts for a 2010 mz3 won't be lucky here. And... you should find parts very easily in any local junkyard for a common 2010 car unless you live somewhere you are the only one with that car lol
| CP-E TC3 ECU Swap for gen 2 | Torque_steer | 2010 MS3 - Turbo Induction | 91 | 02-24-2017 07:35 AM |
| Fs-ZE Swap | Focus | MSP - ECU Computer Tuning | 4 | 09-11-2014 08:43 AM |
| LSD Swap out | Tomas | MazdaSpeed 3 - How-To's | 81 | 10-08-2012 09:16 PM |
| HID swap | TXspeed3 | MazdaSpeed 3/6 - Appearance | 19 | 06-28-2009 05:04 PM |
| Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al | Haltech | Automotive News | 0 | 03-27-2009 02:30 PM |
