> MazdaSpeed 6 - How-To's
  • 1 Post By SJP0tato
 Old 09-06-2014, 02:07 PM   #1
SJP0tato's Avatar
Posts: 322   (View Stats)
Neutral  +2 score
Default How to fix/replace window motor gear
On my rear driver's window a few weeks ago, when fully rolled up rather than stopping it started making a loud/obnoxious grinding noise. Then during operation it'd make grinding/clicking noises too.
Here's a quick example:
http://www.mazdaspeedforum.org/forum/foru...1&d=1410222832
Based on the info from this thread: Another window isssue
I ordered a couple replacement gears from here: power windows repair parts - mazda 3,5,6,cx7,cx9,rx8 from 2003-2012 8.00 USD
They shipped super quick, like within 2 days or so.
That Link is dead, but it looks like Amazon carries them now: https://www.amazon.com/Mazda-Front-P.../dp/B00VYTDD3C
rear door:
First screw is behind the trim panel:
2nd & 3rd screws are behind this trim piece you have to pry off the handle:
After that it's a lot of pulling around the bottom/sides of the panel to disengage the trim clip things. If you're a pro you probably have a puller tool of some kind. For the remaining 99% of us, just remove them from the door once the panel is off & slide them back into the panel. Before you can fully remove the panel, you have to unhook this connector:
Here's the motor installed in the door:
I was a little worried about this part, as none of the write-ups I could find really mentioned how the motor attaches to the glass. Turns out it's just a gear that stays in the door, and the motor engages it. So there's nothing to worry about pulling the motor away:
Upclose pic of the motor (don't bother with this side, it looks like the seal will come off, but it won't):
This is the side of the housing you're going to remove:
It takes some finagling, but eventually the piece should pry loose:
With everything separated:
You can see why the grinding was happening:
The top piece slides right off:
And this rubber dampener piece comes right off too:
New vs old:
Check the drive gear & housing, mine had several of the teeth jammed up against the housing. I wouldn't doubt this contributed to things binding up:
After dropping the gear stuff back in, and snapping the case together it's straightforward how everything goes back onto the door. All in all going slow and taking pictures this took me about 45 minutes. Super easy job that anyone with a screwdriver and maybe a 10mm to help snug up the motor screws/bolts when you're done.
nacwolf likes this.
SJP0tato is offline   Reply With Quote
The Following 13 Users Say Thank You to SJP0tato For This Useful Post:
Alucard93 (08-18-2017), Bexar (09-01-2017), chaser27 (09-06-2014), Code Monkey (09-13-2014), enkiddu (05-26-2017), Fi5H (09-10-2014), Hargarbl (09-06-2014), Hush (09-13-2014), JSmith (09-13-2014), Pu Manchu (03-02-2018), roguemazda (05-08-2017), thems3driver (09-08-2014), TiGraySpeed6 (09-06-2014)
 Old 09-06-2014, 07:12 PM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Neutral  +1 score
Nice write up, thanks!
We'll see more & more of this kind of thing as the speeds get older
340hp / 371tq
 Old 09-06-2014, 07:29 PM   #3
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Yeah mine went too (I think) I have had the gear in my garage for a couple weeks, just haven't gotten around to replacing it.
 Old 09-08-2014, 03:26 PM   #4
reidclark's Avatar
Posts: 301   (View Stats)
reidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the worldreidclark is the leader of the world
would replacing the gear fix my problem which is when you roll it up or down it will stop and you have to push it down a little then continue rolling it down and stop then push it again then it goes down. and same with up except you have to pull it up when it stops and makes a loud grinding noise? or is it the regulator? thanks. can't find anything on my specific problem and it sounds like yours is similar.
2006 Mazdaspeed6/Cobb short ram/M2(eBay)DP/BC Coilovers/Denso ITV22's/Custom front mount/cooling mist water meth/Kmd internals/
up next//Copp AP(again)/AMG reps/
reidclark is offline   Reply With Quote
 Old 09-08-2014, 03:44 PM   #5
Hargarbl's Avatar
Groans: 51
It only takes about 10-15 minutes to pull the door apart and get to the motor and pull it open, you could always do that and inspect it to see if the teeth are broken.
 Old 09-09-2014, 09:55 PM   #6
reidclark's Avatar
ok cool ill try that. thanks!
 Old 09-13-2014, 01:20 PM   #7
blarose's Avatar
Posts: 4   (View Stats)
blarose can only hope to improve
Groaned at 6 Times in 1 Post
anyone ever have there window shift a little when you start rolling it up? It slides back into place when rolling it down but when going up the back top corner shifts forward about a half inch like one of the mounting points is loose.
blarose is offline   Reply With Quote
 Old 03-04-2016, 08:48 AM   #8
haines21's Avatar
Posts: 1   (View Stats)
haines21 is an unknown quantity at this point
Default Prefect fix
Thanks for the write up. This was exactly my problem and you made it easy to replace.
haines21 is offline   Reply With Quote
 Old 03-13-2016, 10:32 AM   #9
ms3-17's Avatar
ms3-17 is an unknown quantity at this point
Just wanna say thanks. Both my front and rear window on driver side had this exact same problem. Was quoted $130 to fix at local window shop and I fixed both for right under $20. Thanks again and awesome write up.
ms3-17 is offline   Reply With Quote
 Old 05-23-2016, 05:56 AM   #10
Trinity's Avatar
Posts: 55   (View Stats)
Trinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud ofTrinity has much to be proud of
Many thanks for this DIY. My wife took my 08 Speed 3 out yesterday and when she got back told me the window wasn't working (Front driver side). Did the credit card swipe on the weather stripping to see if it was just "stuck" and no workie. Will be checking the motor/gear teeth out tonight.
Trinity is offline   Reply With Quote
 Old 05-08-2017, 12:23 PM   #11
mattbatt's Avatar
Posts: 2   (View Stats)
mattbatt will become famous soon enough
Thanks for all of the photo documentation. The link you provided to cheap power windows parts is dead. It looks like the whole site died. Does anyone else have an idea where I can find these gears? A new motor assembly is $100 which is about $50 more than i want to spend.
mattbatt is offline   Reply With Quote
 Old 05-08-2017, 12:39 PM   #12
Go VIP, post a WTB, profit?
 Old 05-08-2017, 12:59 PM   #13
Probs
 Old 05-08-2017, 10:47 PM   #14
mattbatt's Avatar
Neutral  +1 score
To answer my own question I found some listed on Ebay with this description "Mazda 3 5 6 CX-7 CX-9 RX8 Power Window Motor Gear Regulator"
To help out anyone else attempting this repair on the front doors. Do yourself a favor and pull off the the tweeter pod before removing the door panel it just pulls straight off. I didn't and I had to pull off the pod before I could put the door panel back on.
When trying to disassemble the motor assembly there are two small clips on the side that break off easily be careful of them. I also found that shoving a screwdriver between the two pieces was very difficult. I tapped the steel part of the gear with a small hammer and the two pieces came apart. Be careful that you don't hit the exposed plastic gear it will break.
For reassembly I had to remove the speaker from the door so that I could hold the window regulator in place to screw in the bolts.
This is obvious to some but if you are testing the window after fixing it, the window control switch on both sides of the car must be installed for the window to work.
The Following User Says Thank You to mattbatt For This Useful Post:
SJP0tato (08-29-2017)
 Old 08-29-2017, 03:26 PM   #15
SJP0tato's Avatar
Yep, that link's dead. Looks like amazon carries 'em now though:
 Old 07-22-2018, 01:46 PM   #16
mack bolan's Avatar
mack bolan is an unknown quantity at this point
Default simple fix
really made my day ... simple instructions and great pictures. Definitely a great help and saved me a lot of $$$ thank you
mack bolan is offline   Reply With Quote
 Old 08-06-2018, 10:33 PM   #17
MadMazda's Avatar
MadMazda is an unknown quantity at this point
This is great.
How many of those new gears did you need? And was it only that larger gear or also the smaller gear that was required?
MadMazda is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-fix-replace-window-motor-gear-176795/
Drivers Window - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-28-2015 08:33 AM
To replace or not to replace the throwout bearing that is the question? stockms3 MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-30-2014 07:29 AM
Videos: Rewind - Old Top Gear looks back at even older Top Gear Haltech Automotive News 0 03-03-2011 03:20 PM
Some Say He's Tiff Needell: Fifth Gear host back at Top Gear to fill in for The Stig? Haltech Automotive News 2 12-28-2010 07:39 PM
How to Replace a Car’s Starter Motor Haltech Automotive News 0 07-12-2010 05:10 PM
'World of Top Gear' to open at UK's National Motor Museum Haltech Automotive News 0 04-16-2009 07:30 AM
Page generated in 0.38175 seconds with 33 queries
