> MazdaSpeed 6 - How-To's
 Old 04-23-2009, 11:57 PM   #1
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Neutral  +2 score
Default How-To: Mazdaspeed6 Replace Pads and Rotors
To begin, I decided to completely upgrade my brake system, considering that my car will do some track time this summer. If you are planning on doing all that I did, make sure that you have plenty of time, brake jobs can be very time consuming. If this is your first brake job, all I have to say is good luck and I hope that you find this how-to helpful. I’m ASE certified in brakes, and I’ve done a lot of brake jobs on many types of cars. If you are having any troubles or have some questions, shoot me a pm, I’d be glad to help.
Difficulty for just pad and rotor replacement = 5
Cost total = $400+
New parts! Thanks go to Mark at SU
Tools needed for just pad and rotor replacement + why?:
Jack + jack stands – lift car
21mm socket wrench/or impact gun – remove wheels
7mm hex head wrench – front caliper guide pins
17mm socket wrench – front caliper bracket
Needle nose pliers – front caliper retaining clip, depress rear caliper
pistons(the method I used)
C-clamp – depress front caliper pistons
14mm socket wrench – rear caliper guide pins, bracket, e-brake bracket
10mm brake wrench – rear caliper bleeder
9mm brake wrench – front caliper bleeder
Impact wrench with screwdriver bits – remove rotor screws. Note: If you can’t get these out use a power drill + various size bits to drill out the rotor screws.
Recommended supplies needed for just pad and rotor replacement + why?:
Brake-clean – to clean all friction mating surfaces
Caliper guide pin lube – self explanatory
Brake fluid DOT3 or DOT4 – you will want to bleed the brakes
A friend – to help bleed the brakes(these are hard to find. If no friends exist, buy a brake bleeder thingy)
A bolt – to push rotor off hub(I don’t know the type, but one of the brake line bracket bolts will work)
Rubber hammer – to free rotor from hub
Gloves – this is a very dirty job
Let’s get started! Pad and rotor replacement:
1. Jack up the car, find a good spot for the jack stands(I used the inner car frame), remove the wheels. Note: If you do not know how to support a car safely in the air, stop now and go to a mechanic.
2. Locate and remove the 2 hexbolt guide pins on the rear of the front calipers, you will have to remove the dust caps to access these.
3. Remove the metal spring clip thing.
4. Remove the caliper. Once it is off the hub, you can depress the piston; use the old pad for a flat clamping surface.
5. Remove the pads.
6. Clean the guide pin sleeves in the caliper with brake-clean and paper towels.
7. Locate and remove the 2 caliper bracket bolts, and remove the bracket.
8. Now here comes the fun part. In order to remove the rotor, these screws need to come out. Get the Impact ready. If they do not come out easily, get the drill ready to drill out the screw heads. You really don’t have to replace these screws, the wheel hold the rotor on just fine. With the screws off, remove the rotor. If it won’t come off itself, use a bold in the threaded rotor hole, and screw it in until the rotor brakes free.
9. With the rotor off, inspect and clean the rotor-hub-mating-surface of rust build-up.
10. Install new rotor
11. Install the caliper bracket, making sure the bolts are tight.
12. Place the outer pad on the bracket, and the inner pad into the caliper piston. Note with Hawk HPS pads I had to bend inward on the tabs to get the pad into the piston.(this is an example with the old pads)
13. Now place the caliper onto the bracket and line up the guide pin holes.
14. Clean the guide pins with brake-clean and paper towels.
15. Lube up the guide pins and insert them into the caliper sleeves. Once you have them pressed in, thread the pins into the bracket, and tighten them in. Do not over tighten! Put the dust caps back on.(this is an example with a socket)
16. Install the metal spring clip thing, front brakes are done!
17. Locate and remove this bolt that holds on the e-brake mechanism. Slide the e-brake
mechanism out of its bracket, and set it aside.
18. Remove the 2 caliper guide pin bolts, and remove the caliper.
19. Remove the pads, a flathead screwdriver can help with prying them from the retaining clips.
20. Locate and remove the caliper bracket bolts, and set the bracket aside
21. Remove the 2 rubber guide pin boots, clean the pins and lube them. Then insert them back into the caliper bracket.
22. Remove/Install rotor same as steps 8, 9, 10.
23. Install the caliper bracket, tighten the bolts.
24. Place the new pads in the retaining clips on the caliper bracket.
25. Depress the caliper piston. In order to do this, you have to turn the piston. I used some pliers on the notches in the piston. Turn slowly, so that the piston dust boot does not bind up, gently with your fingers turn the boot back and forth to keep it from binding/ripping. Get it in enough so that it barely fits over the new pads/rotor, then loosen it ¼ turn. Make sure that the notches are vertical/horizontal with the orientation of the caliper, so that it will go on the little stub on the pad.
26. Bolt the caliper on. Do not over tighten!
27. Slide the e-brake mechanism into its bracket. Install the bolt that holds on the e-brake mechanism.
28. Bleed the brakes, make sure everything is on right, and then use brake-clean to clean all friction mating surfaces.
29. Burnish in the pads. Hawk’s instructions are on the box. If you are using different pads do about four 50-30mph firm brake applications.
30. Celebrate, you are done!
Note: if you avoid the cleaning and lubrication of the guide pins as stated in steps 6, 14, 15, 21, you may be susceptible to un-even pad wear. If you avoid steps 28, 29 you could experience noisy brakes and glazed rotors.
Sorry for no how-to on painting the brakes, there are plenty of them out there.
additional info space:
Current Fail:
The Following 41 Users Say Thank You to MATT DAMOND For This Useful Post:
4G63 (05-09-2011), 6-Speed-6 (04-24-2009), 802MS3 (04-24-2009), Alpha (05-09-2011), AmillieMS6 (01-02-2010), Amnesiac (03-10-2013), atenza_freak (08-21-2009), biggman026 (06-11-2013), djuosnteisn (12-27-2009), Docnox (05-25-2011), doubleflusher (06-08-2009), dougefresh_ (04-21-2011), Fatguy729 (04-01-2011), Ferdball (04-24-2009), Haltech (04-24-2009), keymaster (05-05-2013), long101 (03-12-2010), meelo88 (03-29-2010), mick88 (10-01-2014), Mistersix (11-14-2009), mouse0330 (08-16-2009), mr_mazda329 (02-01-2010), MS666 (05-11-2010), MS6FL (05-25-2011), NoisyCricket (12-11-2013), obylium (09-01-2009), Qwik6 (05-04-2009), RayRayBauder (12-12-2009), retrobmx63 (05-01-2009), season_of_ages (12-14-2014), SgtP (08-14-2009), SIXual Panda (03-05-2011), SLS MS3 (04-24-2009), speed23 (01-22-2010), Speed_j23 (05-13-2013), tbot (02-25-2010), Toddy22587 (04-23-2011), tunersteve (02-28-2010), xfeejayx (05-26-2011), Zoomer_Esiason (12-13-2016), zpele (05-14-2011)
 Old 04-24-2009, 04:38 AM   #2
6-Speed-6's Avatar
Posts: 336   (View Stats)
6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute
That is awesome man, great write-up. I have to do this in the next couple of months myself.
2007 MazdaSpeed 6
Low and Slow!
6-Speed-6 is offline   Reply With Quote
 Old 04-24-2009, 04:44 AM   #3
serium's Avatar
Posts: 448   (View Stats)
serium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the world
Groaned at 34 Times in 12 Posts
very nice... im assuming probably the same concept for the speed3. Great write up!
2008.5 Red Mazdaspeed 3
Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech
Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors
Monitoring: Dashhawk
serium is offline   Reply With Quote
 Old 04-24-2009, 08:20 AM   #4
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Another good writeup
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
 Old 04-27-2009, 01:54 PM   #5
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Thanks for taking the time to do a write-up. This is a great help to the community.
 Old 05-15-2009, 02:22 PM   #6
spdfrk's Avatar
Posts: 61   (View Stats)
spdfrk will become famous soon enoughspdfrk will become famous soon enough
Default !
spdfrk is offline   Reply With Quote
 Old 05-15-2009, 02:36 PM   #7
cm-jp1's Avatar
Posts: 167   (View Stats)
cm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud ofcm-jp1 has much to be proud of
I really dont want to take the time to do this. But i also dont want to spend 300 dolalrs for mazda to do it...Hmmmmm .decisions. decisions.
cm-jp1 is offline   Reply With Quote
 Old 06-05-2009, 01:19 PM   #8
RUMBLEFISH's Avatar
Posts: 730   (View Stats)
RUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the world
Groans: 32
I have a question for you. Iwill be doing my front pads in the next few weeks. I have no shimmy in the front so do I still need to cut the rotors or could I just scuff them up good with the die grinder to get off any edges that appear and hit them with a da sander then install the pads? I keep cars for a long time and dont want to buy rotors 3 years from now. Or maybe Im just fooling myself but want to ask you because you know a hell of a lot better then me.
Thanks
2008.5 Metro Gray Speed 3 t bone motor mount, CPE Nano, TIP,Corksport RP, HYPER box tune.
RUMBLEFISH is offline   Reply With Quote
 Old 06-05-2009, 10:42 PM   #9
Groans: 70
Thanks
Make sure you measure the thickness of the rotors, to see if they're in specs. But yeah, using little sanding pads+die grinder, put a swirl finish on the rotors, clean off all the left over metal dust with brakelean, and you should be fine.
Current Fail:
 Old 08-10-2009, 09:17 PM   #10
cohjus55's Avatar
Posts: 31   (View Stats)
cohjus55 is a jewel in the roughcohjus55 is a jewel in the roughcohjus55 is a jewel in the roughcohjus55 is a jewel in the rough
Cut or replace, Doing it by hand can cause some pulse in the pedal if you take a little to much off. In my personal experience's in customer cars as well as my own. Pads also make some funny noises and create alot of dust for a very long time if you just pad slap. Lots of life is also taken out of the pad if the rotors are grooved pretty good as they try to wear match. Most part stores can cut rotors for you at like 10 bux a pop.
cohjus55 is offline   Reply With Quote
 Old 08-14-2009, 06:59 AM   #11
s.gaspar's Avatar
Posts: 12   (View Stats)
s.gaspar will become famous soon enough
great write up i'll be using this once i do my speed6 upgrade, thanks
s.gaspar is offline   Reply With Quote
 Old 08-14-2009, 07:12 AM   #12
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
awesome write up!
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 08-15-2009, 08:32 PM   #13
sleeperstang1994's Avatar
Posts: 569   (View Stats)
Groaned at 7 Times in 5 Posts
lol at the avatar that shows the mater auto tech. congrats anyway. im pretty sure there are plenty of mater techs on here though. me included
 Old 08-15-2009, 08:36 PM   #14
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
nice job matt, if i may add. maybe i skipped it but first thing u should always do is remove the cap from the master cylinder...once u compress the calipers the fluid will rise and if u are full already one of two things will happen.
a) u wont be able to overcome the pressure needed to compress the calipers since the cap will hold
b) u will bust a line,cap or w/e
fluid unlike gases doesnt compress so dont forget to take the cap off.
Docnox (11-28-2011), MATT DAMOND (08-16-2009), mouse0330 (08-16-2009)
 Old 08-16-2009, 12:21 AM   #15
mouse0330's Avatar
Posts: 1,104   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
heres another DIY for me, seems easy for a first timer like myself..lol
thanks Matt
mouse0330 is offline   Reply With Quote
 Old 08-16-2009, 12:38 PM   #16
Groans: 70
Thanks Lenny, there's always little things I forget to add.
Another thing to add, is that if you have the M/C cap removed and you still cannot de-press the caliper piston, open the bleeder valve on the caliper a little bit, then push the piston in. If this is the case, there is likely some buildup of crud inside the caliper/lines, and I would recommend bleeding the system, in order to flush it all out.
thanks Matt
Glad I could help.
Current Fail:
 Old 08-16-2009, 09:00 PM   #17
marc15skate's Avatar
Posts: 5   (View Stats)
marc15skate will become famous soon enoughmarc15skate will become famous soon enough
Great job!!!!
marc15skate is offline   Reply With Quote
 Old 08-21-2009, 01:55 PM   #18
atenza_freak's Avatar
Posts: 613   (View Stats)
atenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the world
i will use this now thank you
2010 ford focus
andy
atenza_freak is offline   Reply With Quote
 Old 08-22-2009, 03:03 PM   #19
BADFISH6's Avatar
Posts: 89   (View Stats)
BADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud ofBADFISH6 has much to be proud of
Groaned at 9 Times in 5 Posts
Nice write up. What kind of rotors are those?
BADFISH6 is offline   Reply With Quote
 Old 12-09-2009, 12:13 PM   #20
SCPAms6's Avatar
SCPAms6 will become famous soon enough
good write up, thank you!
SCPAms6 is offline   Reply With Quote
 Old 12-25-2009, 05:48 PM   #21
memin's Avatar
Posts: 994   (View Stats)
I will be replacing my front rotors soon, what type of rotor did you get?
 Old 01-02-2010, 09:14 AM   #22
chisss's Avatar
Posts: 49   (View Stats)
chisss has a spectacular aura aboutchisss has a spectacular aura aboutchisss has a spectacular aura about
Thank you for the instructions!
chisss is offline   Reply With Quote
 Old 02-25-2010, 03:54 AM   #23
kalonov's Avatar
Posts: 7   (View Stats)
kalonov will become famous soon enough
Can you give some info on those rotors? Brand, $$$, link?
Thanks
kalonov is offline   Reply With Quote
 Old 02-25-2010, 07:25 AM   #24
jmgute's Avatar
jmgute is an unknown quantity at this point
I have the same question as above ^^
I am trying to source front calipers and at the moment having a damn hard time find loaded calipers like the ones you have. Any help on this?
jmgute is offline   Reply With Quote
 Old 02-25-2010, 08:27 AM   #25
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Ok, so first off, great write up! My questions tho are:
1: with the abs, when you compress the calipers, don't you have to release the bleeder valve so the fluid goes out there instead of back thru the system? I remember something about not doing that with ABS systems can cause problems?
2: Like others have mentioned, what rotors are those, and are those the Hawk HPS or HP+ pads?
Again, great write up and thanks!
 Old 02-28-2010, 09:31 AM   #26
tunersteve's Avatar
Posts: 869   (View Stats)
tunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the world
Nice write-up Matt! I will most likely be doing a swap up to new rotors and pads (thinking StopTech slotted from Mark @ SU and Hawk HPS pads) this summer. Any experience in changing out the brake lines with SS ones? Do you suggest it, even if they're DOT certified?
I've done brakes a few times, but I'm sure there are a few things I can learn to make it easier.
2011 Mustang GT
tunersteve is offline   Reply With Quote
 Old 02-28-2010, 09:57 AM   #27
meeker13's Avatar
Posts: 282   (View Stats)
meeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the world
Very nice write up...im bout do for brakes!
GT28_COBB AP_COBB SFI_ETS IC_DNP MANI_TIAL 44MM EWG_CP-E INLET_CP-E DP_CP-E 3'' CB_TURBOSMART EBOOST2 EBC_OEM BPV_SURE DREDNAUGHT_KONIG ZERO'S_EIBACH SL SPRINGS
meeker13 is offline   Reply With Quote
 Old 02-28-2010, 12:45 PM   #28
Groans: 70
For all you folks that asked, those are Centric/Stop Tech plain surface rotors. I bought them from Mark at SU, so shoot him a call. I cannot remember the price, but it was a good deal for the package of all 4.
The pads are HPS's, all around, but I did switch the fronts to HP+'s after the how-to.
I bleed my brakes with a Motive pump bleeder. Bleeding the brakes on an ABS equipped vehicle, is the same procedure as a non-ABS car. Make sure to take the cap off of the master cylinder when you're depressing the calipers, to not pressurize the system, and make depressing the pistons easier. If you have a lot of fluid in the M/C, scoop some out, as to not cause an overflow of fluid.
Here Steve: How-To: Mazdaspeed6 Install Stainless Steel Lines
I love the SS lines, they firmed up the pedal a tiny bit, and I'm sure they helped when I tracked the car.
Current Fail:
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
mouse0330 (02-28-2010), tunersteve (02-28-2010)
 Old 05-09-2010, 03:43 PM   #29
Arinzeuno's Avatar
Arinzeuno has a little shameless behaviour in the past
Groaned at 12 Times in 4 Posts
d
Mercedes Benz E 320 TT
3.2L inline six with 392rwhp/406rwtq @ 12.6psi.
0-60: 3.8 sec (with sandbags)
0-100: 8.5 sec
1/4 mle: 12.2 @ 120 mph.
Top Speed: 171 (so far)
3400 lbs
I rep Michigan. Come see me.
Arinzeuno is offline   Reply With Quote
The Following User Says NO Thank You to Arinzeuno For This Un-useful Post:
 Old 05-13-2010, 06:32 PM   #30
jaywo33's Avatar
Posts: 13   (View Stats)
jaywo33 will become famous soon enough
NICE!! i was wondering why i striped the heads and broke 3 Philip head tips...
jaywo33 is offline   Reply With Quote
 Old 04-01-2011, 06:44 PM   #31
event's Avatar
Posts: 521   (View Stats)
event is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the worldevent is the leader of the world
I pulled the exploded views w/ torque specs from the shop manual for anyone that may need/want them.
event is offline   Reply With Quote
The Following 2 Users Say Thank You to event For This Useful Post:
Docnox (11-28-2011), MATT DAMOND (04-02-2011)
 Old 04-01-2011, 07:29 PM   #32
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Thank you... Too late LOL. But I was looking for something like this a month ago and couldn't find anything. I ended up having a mechanic friend replace my pads and turn my rotors for $65.
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
 Old 04-01-2011, 07:43 PM   #33
Tibu's Avatar
Posts: 178   (View Stats)
Tibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the worldTibu is the leader of the world
Thanks for the exploded views. They will come in real handy very soon.
2007 Black Mica Mazdaspeed 6
Mods to Date: Cobb AP, Mazdaspeed CAI, Cobb TIP, SU Boost Tubes, 1 step colder plugs, Saikou Michi OCC, HKS BPV, SU Test Pipe, JBR Chrome Molly RMM, RPM Street Springs, SPC Adj. Ball Joints, Racing Hart CP035R 18x9 +35, BF Goodrich G-Force Comp2 245/40 tires
Tibu is offline   Reply With Quote
 Old 04-02-2011, 11:03 PM   #34
event's Avatar
Finished the pads and rotors today. 21ft-lbs is not a lot so it is very easy to over-tighten the caliper guide pins like that last people that did the brakes on this car did. Ended up stripping one of them and had to run out and get some new pins. Other than having to drill out the rear rotor set screws, it went smoothly thanks to this guide.
On another note, anyone know how long it takes for Hawk HPS pads to fully break in? I bedded them properly but they still don't have a lot of bite until you really press down on them.
 Old 04-20-2011, 12:36 PM   #35
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
subbed, as will be doing this in the next few weeks.
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
 Old 04-21-2011, 12:08 AM   #36
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Great write up Matt!
 Old 05-09-2011, 10:27 AM   #37
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
did the brakes this weekend, thanks for the write up, went smoothly except for the rotor screws, first one was a mess, but with a torch and pb and a special tool, got it down to a science, hawks dont have as much initial bite, but im already getting used to that, but when you do step on them they stop in a hurry
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
 Old 05-24-2011, 07:10 PM   #38
Nosaj's Avatar
Posts: 83   (View Stats)
Nosaj has a spectacular aura aboutNosaj has a spectacular aura aboutNosaj has a spectacular aura about
Good write up. I did my rears just this weekend. I found this thread when I couldnt get the screws out of the rotors. iI beat the crap out of them with an impact screwdriver (the kind you hit with a hammer). They would not move at all! I ended up drilling them out.
Now I know they really dont need those screws in there but I dont like it that they arent there. The rotors are shifted just a hair without the screws.
So even though I know how to bed in brake pads, like an idiot I didnt worry about doing the first couple break in stops. And... now I have noisy rear brakes! So the question is do I need to have the rotors turned a bit to remove any glaze or should I just scuff them and the pads up a little and then break them in properly?
Nosaj is offline   Reply With Quote
 Old 03-02-2014, 10:34 PM   #39
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
sorry to bump a really old thread @MATT DAMOND; but the two screws you need to remove on the rotor to pull off. Did those strip on you? The ones holding my rotors on are super soft and are stripping really easily. Any insight you can provide is useful.
Performance:
Stratified Tune in progress
The Following 2 Users Say Thank You to Swinger13 For This Useful Post:
MATT DAMOND (03-04-2014), WeeGad (02-23-2016)
 Old 03-03-2014, 04:37 AM   #40
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
Rotor screws are a PITA on any car that has them equipped, lol. If you can get your hands on an impact driver (Can tire) it'll save you a lot of frustration and time.
Sent from my SGH-I337M using Tapatalk
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
The Following 2 Users Say Thank You to DamagedGoods For This Useful Post:
MATT DAMOND (03-04-2014), Swinger13 (03-03-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-mazdaspeed6-replace-pads-rotors-26351/
Brake pads egbertnr MazdaSpeed 3/6 - Suspension & Brakes 13 05-04-2009 11:58 AM
rotors armarine04 MazdaSpeed 3/6 - Suspension & Brakes 7 03-30-2009 04:49 PM
Centric rotors/pads speed6frk MazdaSpeed 3/6 - Suspension & Brakes 11 02-19-2009 07:58 PM
GB Interest: Stoptech Rotors/Hawk Pads Performance Racing Mazdaspeed3/6 General Discussion 34 04-26-2008 12:06 PM
Ordered Stoptech Rotors, Pads, SS Lines, Fluids.. Performance Racing MazdaSpeed 3/6 - Suspension & Brakes 10 04-02-2008 06:42 AM
Page generated in 0.61494 seconds with 56 queries
