![]() | | #81 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score |
![]() | | #82 | ![]() |
Groans: 60
| Not Ranked : 0 score If you do the math you will never have a scalar B = 1. So IMO that's always the wrong value.. x = voltage , y = boost in Kpa Logically if a 1 was acceptable the engineers at Mazda would have just eliminated an unnecessary variable from the code..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 08-14-2014 at 01:54 PM. |
![]() | | #83 | ![]() |
| Not Ranked : 0 score well, ax+b=0 fits any given linear expression. So there is only one multiplier in that, and you can define any slope you want with it. a = slope b = offset so what is one more doing in there? esp since judging by everything they are simply being multiplied with each other. |
| The Following User Says Thank You to mrQQ For This Useful Post: | SSinstaller (08-14-2014) |
![]() | | #84 | ![]() |
Groans: 60
| Not Ranked : 0 score I honestly have no idea what the ECM is doing with Scalar B, but from personal experience and everything I've seen on here--regardless of which MAP sensor you're running it's more accurate when scalar b ≠ 1.
![]() | | #85 | ![]() |
| Not Ranked : 0 score So what is more accurate: 43.85 and 1.5 6.577 and 10 131.54 and 0.5 3288.5 and 0.02 ? because in the end they all describe exactly the same "slope". |
![]() | | #86 | ![]() |
Groans: 60
| Not Ranked : 0 score If your only worried about the slope they're all equivalent. But were not dealing with a line extending to infinity in both directions... If I had to guess as to the actual purpose of Scalar B it would to place limits on the sensor range.
![]() | | #87 | ![]() |
| Not Ranked : 0 score That's exactly why I asked what is B used for.. till we know, we're just guessing.. has anyone ever proven that it matters? Till not, 1 is as good as anything else.. |
![]() | | #88 | ![]() |
Groans: 60
| Not Ranked : 0 score I know in my car my AEM sensor was not accurate using 1 for scalar b. I also remember people having issues with their sensors not reading the full vacuum range when using a value of 1, but that may have been a sensor limitation. IMO, there are enough people running these things now that there should be a consensus on the right way to do this...
![]() | | #89 | ![]() |
| Not Ranked : 0 score Well I might agree that it would make sense to keep B as close to stock as possible and only recalculate A using that. Just to not throw ECU off much if it uses B in some way. |
![]() | | #90 | ![]() |
Groans: 60
| Not Ranked : 0 score From what I've seen whenever scalar b is calculated using the slope/distance method the results are very close to the OEM value..
![]() | | #91 | ![]() |
| Not Ranked : 0 score I still don't understand what you mean by that. |
![]() | | #92 | ![]() |
Groans: 60
| Not Ranked : 0 score The sensor spec sheet usually has the full accurate sensor range shown.. The lowest accurate output and the highest accurate output is used. Scalar b can be calculated by taking the slope of the line determined by your datapoints divided by the distance between them..
![]() | | #93 | ![]() |
| Not Ranked : 0 score well, yes, but that's just one scalar. For example, 845 sensor lists 11kPa at 0.25v and 307kPa at 4.75v. Voltage range 4,5v (4,75-0,25), pressure range is 296 (307-11), so its 65,78 kPa per 1v. So that's your scalar A. What is B? |
![]() | | #94 | ![]() |
| Not Ranked : 0 score My thoughts on how to convert the Bosch data to ATR from this data: p2-p1 / slope of linear formula = offset --------------------------------------------------------------------------------------------------------------- For the 3 bar sensor (#845)... P1 -> 11 kPa at 0.25V P2 -> 307 kPa at 4.75V y = 65.778x - 5.4444 component A: 296 (307 kpa - 11 kpa) component B: .22 aka 65.778 / 296 offset : 5.444 Tuning for 3.5Bar Map sensor with cobb ap |
| The Following 4 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #95 | ![]() |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | rfinkle2 (08-17-2014) |
![]() | | #96 | ![]() |
| Not Ranked : 0 score Now this make sense somewhat, because it would say what each voltage step is. That is its the same as 1/voltagerange. I guess ecu could make use of something like that. |
![]() | | #97 | ![]() |
| Not Ranked : 0 score It had better makes sense. The values are as calculated by Mazda for the 2.5 bar sensor. I took the stock 2.5 bar data and worked with it in order to make sure the stage 0 values (ots cobb / mazda rom) matched and got a linear formula from: point 1: 20 kpa @ .4v point 2: 250 kpa @ 4.65v This gives the formula: y = 54.118 - 1.6471 recall stage 0 map sensor settings (factory rom 2.5 bar) component A: 230 =(aka p2-p1)=(aka 250 kpa - 20 kpa) component B: .24 = (slope/ p2-p1) = 54.118/230 offset: 1.65 (negative y intercept) Last edited by rfinkle2; 08-17-2014 at 12:20 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 6 Users Say Thank You to rfinkle2 For This Useful Post: | btstarcher (08-17-2014), dale_gribble (08-17-2014), Mauro_Penguin (08-27-2014), MD1032 (05-11-2015), mrQQ (08-17-2014), TiGraySpeed6 (08-17-2014) |
![]() | | #98 | ![]() |
| Not Ranked : 0 score Woot! @Steve@VersaTune; please increase the limit! |
| The Following User Says Thank You to mrQQ For This Useful Post: | btstarcher (08-17-2014) |
![]() | | #99 | ![]() |
| Approved MSF Vendor ![]() Join Date: Nov 2008 Location: Euless, TX
Rep Power: 975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 850
Bosch MAP Sensor Plug 'n' Play Adapter Harness @ therpmstore.com | |
| The Following 11 Users Say Thank You to RPM For This Useful Post: | Amnesiac (09-04-2014), btstarcher (09-04-2014), Cevaes_64 (09-04-2014), dale_gribble (09-04-2014), ItsNox (09-11-2014), Koke382 (09-04-2014), Mauro_Penguin (09-07-2014), MD1032 (05-11-2015), rfinkle2 (09-04-2014), The Nut (09-04-2014), We're All Thieves (10-24-2014) |
![]() | | #100 | ![]() |
![]() Join Date: Aug 2013 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score I'm using the Bosch "845" 3 bar sensor as used by the OP. The scalar values listed dont work for me. When I use: Scalar A 65.78 Scalar B 1 Offset 6 I get a dashboard boost reading of ~14.21!?! The values that work for me are: Scalar A -65.78(negative) Scalar B -1(negative) Offset 6.5 This gives me a reading of zero and a proper reading at idle. Are these original values supposed to be negative? And if not, what could the problem be? Thanks!
__________________ 2009 MS3 GT - True Red Fully Built Block//ATP GT3071r ported WG//TXS TBE//TXS FMIC//HKS SRI//CP-E TIP//TurboSmart Dual Port BPV//PTP HPFP//CP-E Injector Seals//CP-E motor mounts//AEM Truboost(running as 3 port)//AEM UEGO//Denso ITV24 plugs//ACT HDSS//ACT lightweight FW//Eibach Prokit//Drag DR-38 18x8 +35//Federal 595ss 235/40/18//RA Mudflaps Self Tune in Progress |
![]() | | #101 | ![]() |
| Not Ranked : 0 score In ATR there is a box to check/uncheck under options "Show standard units" Should this be checked or unchecked? Obviously, the scalar numbers in the OP work well enough for everyone else. Why would mine be different?
![]() | | #102 | ![]() |
| Not Ranked : 0 score 14.21 seems to be the barometric pressure Why would my boost reading when logging with ATR show baro KOEO? When I unchecked the show standard unit box, it shows .04psi.
![]() | | #103 | ![]() |
| Not Ranked : 0 score component A: 296 component B: .22 offset : 5.444 Show Standard Units should be checked.
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | Mauro_Penguin (11-05-2014), TiGraySpeed6 (10-31-2014) |
![]() | | #104 | ![]() |
![]() Not sure how I got owned by something so simple but It seems to be working now with the OP values and an offset of 6.5. Thank you for replying, dude. Happy Halloween!
__________________ 2009 MS3 GT - True Red Fully Built Block//ATP GT3071r ported WG//TXS TBE//TXS FMIC//HKS SRI//CP-E TIP//TurboSmart Dual Port BPV//PTP HPFP//CP-E Injector Seals//CP-E motor mounts//AEM Truboost(running as 3 port)//AEM UEGO//Denso ITV24 plugs//ACT HDSS//ACT lightweight FW//Eibach Prokit//Drag DR-38 18x8 +35//Federal 595ss 235/40/18//RA Mudflaps Self Tune in Progress | |
![]() | | #105 | ![]() |
| Not Ranked : 0 score I honestly never even checked to see if it worked; Fob proved the relationship mathematically, and I trust math. And Finkle.
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | Mauro_Penguin (11-05-2014), rfinkle2 (10-31-2014) |
![]() | | #106 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, that's from @rfinkle2; math there, and it works a treat- I've been using those settings for a while now all over the country and have had consistent results. I've been meaning to add them to the OP forever - should probably go do that .....
| The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #107 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score Anyone done any math for a 4 bar? How much different will the values be? Would the offset just change?
__________________ 2013 CWP and Stock |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | Mauro_Penguin (11-05-2014) |
![]() | | #108 | ![]() |
![]() Join Date: Apr 2014 Location: Tualatin, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I have tried the values in the AP help file and the ones posted here but I never get any better than -12.XX PSI with key on engine off. Also my BAT's are 130-138 when the car is ice cold and outside temps are in the 50's. Any suggestions? |
![]() | | #109 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
| Not Ranked : 0 score Check your adapter harness wiring, the one I bought had two wires flipped and caused that problem. I changed them around and was golden. Pic of harness with crappy drawing to illustrate how wires were reversed is attached. Ignore scribbles for proper alignment. uploadfromtaptalk1419390611209.jpg
__________________ "I apologize for nothing!" - Hedonismbot ![]() Last edited by aromig; 12-24-2014 at 03:12 AM. |
| The Following User Says Thank You to aromig For This Useful Post: | Mauro_Penguin (12-24-2014) |
![]() | | #110 | ![]() |
| Not Ranked : 0 score So orange goes on the outside and red next to blue? I'll try to get a peak at it (such a PITA to get to) later tonight. My new problem is I'm getting 0 pressure from the HPFP and the car won't start. I'm on the stock HPFP internals(only have intake and cat back for now) but fuel pressure has always been fantastic. Any suggestions? |
| The Following User Says Thank You to smckenzie04 For This Useful Post: | Mauro_Penguin (12-24-2014) |
![]() | | #111 | ![]() |
| Not Ranked : 0 score This is what my 3 bar map sensor harness from Edge looks like and I have no idea how I would change that. |
![]() | | #112 | ![]() |
| Not Ranked : 0 score After some digging I found out fuel pressure comes back when I unplug the map sensor. I am baffled how one could effect the other but I'm going to try and swap the original sensor back in tomorrow in the hopes of getting it back on the road. I don't need the 3 bar for a few months anyway. |
![]() | | #113 | ![]() |
| Not Ranked : 0 score I don't think those wire colors should cross. Basically, the shape of the the plug is different, but the pins should stay the same. I used a pair of needle nose pliers to swap the pins on one end. Original pic from vendor attached. uploadfromtaptalk1419408809987.jpg Second pic just for shits 'n giggles.
__________________ "I apologize for nothing!" - Hedonismbot ![]() |
![]() | | #114 | ![]() |
![]() Join Date: Dec 2015 Location: New Zealand
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score ![]() I know this is a thread that I am bringing up from the dead, but it still is very useful and relevant. I want to double check if those magic numbers work OK for the Bosch 0 281 002 845 Cobb recommend this: Range: 3 bar Component A: 65.78 Component B: 1.00 Offset: -5.41 Your magic numbers are this: Component A: 296 Component B: 0.22 Offset: 5.444 I have a BNR S4, Bosch 845 3 Bar, HTP 3.5, GrimmSpeed EBCS etc etc
![]() | | #115 | ![]() |
(Thread Starter) | Not Ranked : 0 score For the Bosch 845 3 BAR, the 296/0.22/5.444 numbers are a safe choice. Feel free to try both- they're both fine for most elevations. Your goal is to get close to 0 with the key on, engine off (KOEO) in the boost reading on your AP or in ATR dashboard. The original post includes instructions using the Cobb numbers to move up or down as needed if your elevation is substantially off of sea level.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | FSRRM (05-06-2016) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score Excellent I'll I've that a go today, I've got a S3 to tune today so this all makes perfect sense. |
![]() | | #117 | ![]() |
| Not Ranked : 0 score Awesome. Component A: 296 Component B: 0.22 Offset: 5.444 Worked a charm! Thank You |
| The Following User Says Thank You to FSRRM For This Useful Post: | TiGraySpeed6 (05-10-2016) |
![]() | | #118 | ![]() |
![]() Join Date: Mar 2013
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score So how bout for a 4 bar map sensor??? |
![]() | | #119 | ![]() |
![]() Join Date: Mar 2012 Location: merrimack, nh
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score I know, necro bump... but I wanted to update this old thread with some relevant info to help others. I noticed a mention of offset changes before the rfinkle numbers were posted but nobody posting their experience after. Maybe my post will save the next guy a few flashes? I loaded the rfinkle scalars and 5.44 offset showed KOEO bouncing between -0.37 and -0.44 I changed the offset to 4 and result was -0.23 (1.44 reduction resulted in a change of 0.17) I changed offset to 3.60 and got to -0.16 (0.4 reduction resulted in a change of 0.07) I then Changed offset to 2.75 and got to -0.01, nice (0.85 reduction resulted in a change of 0.15) Each change did not translate evenly so the offset does not appear to be completely linear. While rfinkle's numbers are regarded as great, I might still recommend people still take the time to tweak their offset. I was almost 1/2psi off so the extra accuracy is welcome. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f111/how-painless-3-bar-map-sensor-upgrade-128850/ | ||||
| VersaTune - View topic - bosch 3 bar MAP sensor | This thread | Refback | 06-05-2015 02:50 PM | |
| COBB AccessPort V3 - Seite 16 | This thread | Refback | 05-12-2015 04:07 AM | |
| VersaTune ? View topic - bosch 3 bar MAP sensor | This thread | Refback | 08-24-2014 04:05 AM | |
| AZ520 Budget turbo madness!! Build - Page 18 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 01-07-2014 01:35 PM | |
| 3 Bar MAF & MAP Sensors - Page 3 | This thread | Refback | 06-23-2013 01:53 AM | |
| Stock Fitment 3 Bar Map Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - ECU Computer Tuning | 529 | 02-23-2017 05:15 PM |
| Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 234 | 10-25-2014 01:54 AM |
| 3.5 Bar Map Sensor Upgrade help | Nitr0EngiE | MazdaSpeed 3/6 - ECU Computer Tuning | 9 | 12-05-2012 11:11 AM |
| Fuel Rail High Pressure Sensor Upgrade | JumpingJackson | MSF KB - Mazdaspeed 3/6 - Fuel | 234 | 09-19-2012 01:53 PM |
