 Old 05-20-2019, 03:13 PM   #1
aDerpyPenguin's Avatar
Posts: 2   (View Stats)
aDerpyPenguin is an unknown quantity at this point
Default 135k Stock. Bought Koni Y+Eibach kit. What else needs to be replaced?
I've been searching and reading multiple threads, but I'm still a bit stuck. I my suspension has been noisy and when I have 4 people in my car I get some rubbing. Several people recommended that I buy new struts/shocks. After some research, I bought Koni Yellows and Eibach springs, which was a package. They will be delivered tomorrow. After some further research, I may have more issues with the rubbing due to it being lowered, but it's too late now lol.
What else should I be replacing when I have someone install the Konis? From my understanding I should replace the front mounts and bearings. Ran across someone mentioning that Sachs are essentially OEM so I have those in my cart at RockAuto. For the two fronts its $72 shipped.
https://www.rockauto.com/en/moreinfo...42059&jsn=2521
I also have seen people mention the bump stops. Specifically the front. Would cheaper ones like this be fine or should I go with Ground Control for $20 more?
https://www.rockauto.com/en/moreinfo...42059&jsn=3591
And I only need the fronts? I shouldn't have to do anything with the rear mounts or bump stops? Also, I've seen people mention replacing end links or sway bar bushings, but I have no idea what parts those would be. Should I be replacing them? I bought the car at 70k and was told its stock. In the 65k I've owned it I have not replaced anything other than brakes.
Thanks for any help and clarification.
<E> These bump stops were posted in another thread. It seems to come with rears too. Would that be better?
aDerpyPenguin is offline   Reply With Quote
 Old 05-21-2019, 09:44 AM   #2
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
There's a lot of info on here on this kind of stuff.
Research fender rolling, which you'll likely need with lower springs to prevent rubbing. I assume you have wider wheels/tires if you're already rubbing with 4 people in you're car.
You'll also want to research suspension mounts, top hats, camber arms, etc., all of which are recommended to replace/upgrade for what you're doing.
Correctly implemented sway bars, or Anti-Roll bars, prevent body roll. The stock bushings and end links often wear and start making clunking or rattling noises. Considering the age of the car, it definitely won't hurt to replace your end links with oem equivalent. But if you want to upgrade the bars, too, you can greatly improve handling. A mild upgrade is something a bit stiffer in the rear. A larger upgrade is stiffing up the front some and the rear a lot. Just start searching around for end link, RSB, etc. on the forum and you'll get tons of info on these topics.
More specific questions showing research will get you more helpful answers and you'll be better educated.
EDIT:
As for bump stops, yeah, there are various aftermarket solutions, which you'll likely want to replace. Coilovers will usually come with their own solution, but not this kit. Same goes for the bearings for the top hats.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 05-21-2019, 09:54 AM   #3
Posts: 2,826   (View Stats)
Welcome!
Read this thread regarding the front strut bearings and top hats. Get the Ford Focus bearings mentioned here. The Sachs are junk. The new Ford parts fit perfectly, are better than Mazda OEM and cheaper:
Affordable redesigned top hats/struts mounts and bearings from FORD
Then, learn to search. This is a gold mine. The richest Mazdaspeed gold in the world. But, don't expect us to mine it for you.
 Old 05-21-2019, 10:48 PM   #4
EDIT:
My car is stock, including the wheels. This will be my first modification. I think they were rubbing due to the current shocks being worn. At least thaat's what I was told.
Welcome!
I've been searching, which is also kinda the problem. I ran across a couple posts about the Sachs being the same as OEM, so I was hoping to save some money with those. I'll order the Fords though.
Specifically though, for the bump stops, there seems to be a lot of contradictory information. Some people say stay stock, some say replace, others say cut. Due to the volume of information, I thought it best to make a post.
 Old 05-22-2019, 01:06 PM   #5
Understood, regarding the bump stops.
I installed Bilstein struts and shocks. They don't use bumpstops in the front. In the rear, I simply reused the stock ones. They were fine. Same for the top mounts in the rear. They were fine.
You have quite a few miles, though. Hopefully someone else will come along with better info regarding Koni struts and shocks on OEM suspension.
FWIW, Rock Auto does a lot of things well. They don't know the difference, however, between Mazdaspeed 3 and regular Mazda 3. The suspensions are not the same. I would not trust them with suspension parts for this platform.
 Old 05-23-2019, 09:05 AM   #6
Carskick's Avatar
Even if your rear shocks are blown, you shouldn't rub. The bump stop should prevent a total bottom out.
Before I went Coilover, I had the Koni SRT.R shocks with my OEM springs. They were comfortable, but too soft, especially with my wider wheels. The dampening felt fine, I think the OEM springs were just not up to what I wanted. Now, I could have just done my sway bars and bushings and left the suspension as it was, but the back was squatting quite a bit, and I wanted to really do it right.
I actually bought the Ford Transit van front bearing when I did my coilovers, only to learn my coil-overs came with their own... Live and learn.
Anyways, The Koni's with stock springs is fine, just make sure your top hats, bearings, rear strut mounts, etc. are all in good shape. Considering the age of the car, I'd just replace them all, including the bump-stop. Before I decided on coilover, I considered this: https://5xracing.com/i-20994502-5x-r...-stop-kit.html
Stock Springs and Koni's are the comfortable option, but less sporty than new springs, too.
Quick review--Eibach Pro-Kit + Koni STR.T TORQUERULES 2010 MS3 - Suspension & Brakes 2 07-23-2015 07:11 AM
Koni shocks and eibach springs?? khammzz 2010 MS3 - Suspension & Brakes 8 06-11-2014 06:22 AM
Koni Yellow + Eibach ... what adjustment? theurgy MazdaSpeed 3/6 - Suspension & Brakes 4 05-23-2012 09:08 AM
eibach pro-kit spring + Koni sport shocks lutexas MazdaSpeed 3/6 - Suspension & Brakes 5 05-04-2009 01:02 PM
Page generated in 0.28799 seconds with 22 queries
