| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
(Thread Starter) | Not Ranked : 0 score As a companion to the brake database I wanted to collect everyone's thoughts and opinions on their brake setups to help others make choices. Please fill out form below and add anything else that you see pertinent. Year Mileage No. of brake set (1st, 2nd, ect) Current Rotors (Front/Rear) Current Pads (Front/Rear) Properly bedded (yes, no, wait what?) Impressions (try to compare to last set) Last set Life of last set (in mileage if possible) Driving Style Tracked? Other comments ----------------------------------------------------------------------------------------- Year 2009 Mileage 26K No. of brake set (1st, 2nd, ect) 1st Current Rotors (Front/Rear) OEM Current Pads (Front/Rear) OEM Properly bedded (yes, no, wait what?) Yes (I would like to hope so anyway) Impressions (try to compare to last set if applicable) Overall I feel the OEM setup is stellar on this car. Good bite and braking power. Only downside is short life and lots of dust. Last set N/A Life of last set (in mileage if possible) N/A Driving Style Spirited, highway accelerations followed by heavy braking to avoid the po po Tracked? Not yet Other comments OEM front set is on its way out, starting to get squealing and pad is worn down very far, I would say they lasted very well given my driving style Last edited by TRex; 05-10-2011 at 07:39 AM. |
| The Following User Says Thank You to TRex For This Useful Post: | MATT DAMOND (05-27-2011) |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score I'll bite. Year 2009 Mileage 50,000 No. of brake set (1st, 2nd, ect) 2nd (fronts) Current Rotors (Front/Rear) OEM Current Pads (Front/Rear) OEM Properly bedded (yes, no, wait what?) Yes Impressions (try to compare to last set) Widest operating temp I've driven to date. Good initial bite with consistent grip as you apply pedal pressure. Little to no brake fade under spirited driving. Previous comparisons include driving MS3's with EBC Green and Hawk HPS on OEM rotors. Last set OEM Life of last set (in mileage if possible) 42-45K Driving Style Moderate Tracked? Yes, but only 1-2/yr Other comments Changing out the pads I noticed an immediate loss in brake feel. Pedal traveled further to the ground in order to stop, although braking performance remained unchanged. Some pedal firmness returned as the brakes adhered to the new rotors. After having several "pros" evaluate the condition I'm told it's normal. |
| The Following User Says Thank You to Design For This Useful Post: | TRex (03-23-2011) |
![]() Join Date: Dec 2010 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score Year 2007 Mileage 26,000 No. of brake set (1st, 2nd, etc.) 2nd (front) Current Rotors (Front/Rear) Rotora/OEM Current Pads (Front/Rear) Carbotech Bobcat/OEM Properly bedded (yes, no, wait what?) Yes Impressions (try to compare to last set) Completely silent operation, pads polish rotors rather than scoring them, almost invisible brake dust, no observable fade, initial bite slightly less than OEM but very livable. Last set OEM Life of last set (in mileage if possible) 21K, but replaced at my convenience, not when worn out. Driving Style Moderate DD Tracked? Never Other comments None |
| The Following User Says Thank You to dkapetansky For This Useful Post: | TRex (03-24-2011) |
![]() Join Date: Feb 2011 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34,434
| Not Ranked : 0 score Year: 2009 Mileage: 42900 No. of brake set (1st, 2nd, ect): 1st Current Rotors (Front/Rear): OEM/OEM Current Pads (Front/Rear): OEM/OEM Properly bedded (yes, no, wait what?): Yes Impressions (try to compare to last set): Dusty, but otherwise very good. In the last 1,000 miles or so there's been an occasional squeak from the rear, but I've still got plenty of wear left. Last set: N/A Life of last set (in mileage if possible): N/A Driving Style: Way too much highway, not enough fun. Hope that changes soon. Tracked?: No Other comments:
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial |
| The Following User Says Thank You to magicka For This Useful Post: | TRex (03-24-2011) |
![]() Join Date: Nov 2010 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,647
| Not Ranked : 0 score Year:2009 Mileage:48,356 No. of brake set (1st, 2nd, ect):1st Current Rotors (Front/Rear):OEM Current Pads (Front/Rear):OEM Properly bedded (yes, no, wait what?)Yes at least 50 miles Impressions (try to compare to last set):Same stopping power as when new. Last set Life of last set (in mileage if possible) Driving Style:slow, until a nice race or corner presents itself. Tracked?: No Other comments: Have a minor squeak when stopping. Very infrequent, maybe one out of ten red lights, have not been able to put a pattern together to identify the squeak. My brake pads get checked every oil change. SHIT TON OF BRAKE DUST!
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to obijack For This Useful Post: | TRex (03-24-2011) |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Year - 2008 Mileage - ~40,000 No. of brake set (1st, 2nd, ect) - 3rd Front; 2nd Rear Current Rotors (Front/Rear) - OEM (2nd front set; 1st rear set) Current Pads (Front/Rear) - Hawk HPS (front & rear) Properly bedded (yes, no, wait what?) - Of course! Impressions (try to compare to last set) - Slightly less initial bit than OEM, but they hold up at least as well to abuse and dust WAAAAAY less than OEM, while providing good feel/modulation at the limit. The fact that they cost less than OEM is a plus too. Last set - OEM; Hawk HPS Life of last set (in mileage if possible) - I got ~14K miles out of the OEM fronts and ~30K out of the OEM rears. The first set of HPS fronts lasted me about ~16K miles (though they had less open track time on them than the first OEM set). I'd say they hold up comparably to OEM. Driving Style - I use my brakes. ![]() Tracked? - Yes Other comments - If I tracked on a more regular basis or tracked the car with R-comps, I'd definitely go with something a bit more aggressive for the track, but I find the HPS to be almost perfect for the street, yet perfectly capable of handling the occasional track abuse.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | TRex (03-24-2011) |
![]() Join Date: May 2009 Location: Tustin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
| Not Ranked : 0 score Year: 2007 Mileage:34,780 No. of brake set (1st, 2nd, ect): 2nd Full Set Current Rotors (Front/Rear): Centric Premium Current Pads (Front/Rear): Hawks HPS Properly bedded (yes, no, wait what?): Yes Impressions (try to compare to last set): May still need some breaking in time, but the stopping is smoother just not as quick as OEM. Last set: OEM/OEM Life of last set (in mileage if possible) 34,780 (Had a fair amount left actually, but eh) Driving Style: Generally tame, spirited driving every so often Tracked? No, not yet Other comments: Nothing right now
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 |
| The Following User Says Thank You to meelo88 For This Useful Post: | TRex (03-28-2011) |
![]() Join Date: Jan 2011 Location: Kent, England
| Not Ranked : 0 score Year 2007 Mileage 34000 No. of brake set (1st, 2nd, ect) 3rd front 3rd rear Current Rotors (Front/Rear) Nitrac Grooved Discs/OEM Current Pads (Front/Rear) Ferodo DS2500/OEM Properly bedded (yes, no, wait what?) Yes Impressions (try to compare to last set) Superb. Couldn't be any happier with the setup, just discs are a problem really as I just seem to ruin them but these seem ok so far (done 2k miles) Last set Same except with standard front discs, they were awful and the discs lasted 3k miles before being cracked, even though there was no wear on the lip. Life of last set (in mileage if possible) 3000. Driving Style Fast when I need to be, I like to make use of my brakes at times ![]() Tracked? Loads. Other comments: I would like a big brake setup to be more openly available for a not too ridiculous price.
__________________ Mazda 3 MPS Sports Aero in True Red 284bhp & 302ft/lb torque |
| The Following User Says Thank You to Graham For This Useful Post: | TRex (04-04-2011) |
![]() Join Date: Apr 2010 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
| The Following User Says Thank You to event For This Useful Post: | meelo88 (04-08-2011) |
![]() Join Date: Apr 2010 Location: Toronto
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Sorry, but what do you mean by `centric`, and my car has 27,000 m on it now, is there still some coating, I don`t understand how that could be. |
He wasn't quoting you...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
You have OEM rotors. No coating, no worries.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial | |
(Thread Starter) | Not Ranked : 0 score ^wow you go through them fast, must be a result of the tracking haha |
| Not Ranked : 0 score I do go through them real fast, it annoys me so much. Just have the problem that being in the UK everything has to be imported = high cost. So I tried a new company here in the UK which cryogenically freezes discs which is supposed to prevent cracking/warping. Fingers crossed they work this time, or I'm going to have to find a big brake kit!
| Not Ranked : 0 score 2010 MS3 : Signed up fro my 1st track day with this car at the end of April at Mosport International Raceway, been tracking Rsx Type S and 4 BMWs for the past 10 years. Want to change OEM pads before I go. Something for daily use but will not fade too much at the track. What should I go with |
(Thread Starter) | Not Ranked : 0 score it has been said many times...but oem pads = best pads (in terms of bite) too bad about the centric rotors and hawk pads...was going to try that set up...might go with stock pads and centric rotors instead... you sure the coating isn't just the packing goo? i will give centric a call tomorrow and ask them how they differ...i didnt expect there to be much variation between blank rotors....while we are on the topic is there anything particularly special about the oem rotors? ok did some reading...centric rotors have what is called an e-coating, e-coating is basically eletromagnetic painting...and for the centric rotors only applies to the black painted part...not the rotor face (http://www.brakewarehouse.com/centric_e_coating.asp) think about it...why need special protection for the rotor face? it is constantly being worn away due to brake application Last edited by TRex; 04-07-2011 at 08:59 PM. |
| The Following User Says Thank You to TRex For This Useful Post: | meelo88 (04-08-2011) |
they recommend sanding with 120grit before installing the rotors. The coating will wear off eventually. | |
what about Hawks ceramic pads?...typically i have heard that semi-metalic>ceramic in the fact that abrasive stopping power > adhesion stopping power....thoughts?...you think the ceramic pads would perform better with the GeoMet? it is strange that Hawk would say that their pads won't do good with GeoMet coating...when their own rotors also have GeoMet coating more info: WHAT IS GEOMET®? GEOMET® is a proprietary water-based coating dispersion containing metal oxides, metallic zinc and aluminum flakes. The zinc and aluminum platelets align in multiple layers forming a metallic silver-gray coating. Applied as a liquid, the coating becomes totally inorganic after curing at 575-600° F (300-315°C). http://www.buybrakes.com/hawk/rotors.html here is another bit of info stating that their is no significant difference with the geomet coating....but then again it is a product brochure http://www.metal-coatings.com/pdf/Ge...orBrochure.pdf Last edited by TRex; 04-08-2011 at 06:45 AM. | |
Honestly though, even after the geomet coating is gone, I've noticed that initial bite may actually be less than OEM, but the increased stopping power that can very easily be modulated precisely is absolutely worth the decreased initial bite. The pedal feels awesome now. I am very satisfied with these pads. I can't yet say anything about dusting, because I have yet to wash my wheels since the brake job. | |
I just didn't want to take any chances.
| Not Ranked : 0 score wow interesting...i will say i agree that it doesn't bit as hard initially but then again i haven't put a whole lot of miles on my car and generally i only tap the brakes on my normal routes. I guess i'll have to burn them down a bit more to see if the initial bite gets better.. Thanks for the heads up!
![]() Join Date: Mar 2008 Location: Kitchener, Ontario
| Neutral : -1 score I just bought rotors from Brake Rotors Discs Pads Brakes Cross Drilled & Slotted. I am not sure how they will work but they look great. I will be installing them with EBC red stuff pads. After their break-in I will write a review. In the mean time, has anybody else bought rotors from brakeperformance.com? If yes, what is your experience with them? |
(Thread Starter) | Not Ranked : 0 score got a response from Hawk Regarding the GeoMet coating Matt, Thank you for the good question. I reviewed the thread you sent and my response concerning the GeoMet coating is that a black 7 white answer is not applicable here. Manufacturers who have quality control in place and place a consistent amount of GeoMet coating onto the disc (avoiding overspraying) will not require sanding down of the coating. The pads will do the work for you during the bed-in process. At times there are issues with brakes that are difficult to conquer and all variables need addressed. In this case, it appears Justin went through all of the other possibilities to address and finally concluded that perhaps the coating could have been the issue. Regards, Jerry DeMarino Director Hawk performance 6180 Cochran Road Solon, OH 44139 (original email) Hello, I was looking install new pads and rotors and have centered on Centric blank rotors and Hawk HPS (semi-metallic)pads. During my research I came across a possible problem between Ferro-Metallic pads and the GeoMet coating found on the Centric pads. On my forum (www.mazdaspeedforum.org/forum) I was pointed to this thread (Fourtitude.com - Attention!! Hawk hps initial bite issue) regarding issues between HPS pads and rotors with GeoMet coating. I went on to read several pieces of info regarding GeoMet coating and was assured that it DOES NOT interfere with braking ability. I also found that Hawk branded rotors also come with the GeoMet coating and figured why would Hawk state there is an issue between their pads and GeoMet rotors when their own rotors are also GeoMet? So my question, is there and issue with running your semi-metallic compound pads on GeoMet rotors? Should they be sanded down prior to installation? Would proper bedding be all that is neccessary to remove the GeoMet from the friction area? Thanks for the info tl;dr version: if the rotor manufacturer is doing a good job, it shouldnt be an issue Last edited by TRex; 05-10-2011 at 07:39 AM. |
| The Following User Says Thank You to TRex For This Useful Post: | meelo88 (04-14-2011) |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Year 2009 Mileage 29K No. of brake set (1st, 2nd, ect) 2nd in front Current Rotors (Front/Rear) Hawk HPS/OEM Current Pads (Front/Rear) Centric/OEM Properly bedded (yes, no, wait what?) Yes Impressions (try to compare to last set if applicable) As many have said it lacks the initial bite that is very prominent in the oem set up. However, the braking power is great. Smooth and fast stops. Dust has been cut down as well. Last set OEM Life of last set (in mileage if possible) 29k Driving Style Spirited, highway accelerations followed by heavy braking to avoid the po po Tracked? Not yet Other comments edit 7-7-11 had an emergency stop today....they really came through with flying colors....great bite...great response...stopped way ahead the other car that went into the intersection....great set of pads Last edited by TRex; 07-07-2011 at 11:20 AM. |
![]() | | #25 | ![]() |
![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Good idea. Here's my take: (Sorry for the long response...) Year 2007 Mileage 48,000 No. of brake set (1st, 2nd, ect) 2nd set in Front, 1st in Rear Current Rotors (Front/Rear) OEM Front(2nd set)/OEM Rear (1st Set) Current Pads (Front/Rear) OEM/OEM Properly bedded (yes, no, wait what?) I sure hope so... Impressions (try to compare to last set) The current pads (new in front, original from the dealer in the rear) are working well - good modulation, smooth feel, quiet, and good initial bite. Brake dust is noticeable, but not excessive. It seems like the new set requires a bit more pedal pressure when braking - I suspect due to the chamfers (?) in the new pads. I am very happy with the OEM pads/rotors, overall. Note: I installed the front pads (along with new OEM rotors) about 3k miles ago. The rears are the original pads/rotors that came with the car when new, and still have about 50% material left. Last set OEM from the factory. The first set of front pads were pretty much worn down to <10%, after about 45k miles, and had developed a lot of brake pedal pulsing (warping?) The front rotors had worn pretty significantly, too. So I replaced the front pads and rotors. The original rears pads and rotors, however, are still going on strong - about 50% pad material is still left, so I have not replaced them Life of last set (in mileage if possible) 45k miles front, 48k miles and still counting in the rear. Driving Style City and freeway, not too spirited Tracked? Nope Other comments The OEM pads and rotors work very well for our kind of driving (daily driving, city/freeway.) It is interesting that the rears didn't wear much at all, relative to the fronts. Not a bad thing - I just had to replace the front pads and rotors 45k miles, which saved me some money. It seems the OEM pad compound is somewhat aggressive, and thus, rotors tend to wear down along with the pads themselves. I am expecting having to change rotors every time I replace the pads. Not necessarily a bad thing; just something to plan ahead for. BTW, the "official" bedding procedure for OEM seems to be "drive easy for the first 500 miles." I could not find any good/solid instructions from Mazda. However, my first drive after installing the front pads involved doing about ten 60mph-10mph braking runs to get the new pads warmed up, followed by a cool down drive (freeway) for 15 miles. I then drove easy for the first 500 miles. Seems to have worked fine. Again, I am very happy with the OEM pad. I'll probably stick with this pad/rotor combo for a while. |
| The Following User Says Thank You to spin-ms3 For This Useful Post: | TRex (05-26-2011) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^hmm if i were doing oem again i would use the same bedding process as hawk |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score Year 2006 Mileage 69752 No. of brake set (1st, 2nd, ect) 2nd Front, 1st rear Current Rotors (Front/Rear) StopTech Current Pads (Front/Rear) EBC red Properly bedded (yes, no, wait what?) Yes, definitely Impressions (try to compare to last set) Much less dust than OEM Last set OEM Life of last set (in mileage if possible) 40K Driving Style Sprited (w/o kids in car) Tracked? No Other comments |
| The Following User Says Thank You to VRed MS6 For This Useful Post: | TRex (05-27-2011) |
![]() | | #28 | ![]() |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
Groans: 70
| Not Ranked : 0 score For Daily Driving: Year 2006 MS6 Mileage 74k-2k on pads No. of brake set (1st, 2nd, ect) I think no 3 Current Rotors (Front/Rear) Centric Blanks Current Pads (Front/Rear) OEM Pads Properly bedded (yes, no, wait what?) Yes Impressions (try to compare to last set) Better initial bite than the HPS pads. Great linear pedal feel. More dust than HPS Last set Hawk HPS Life of last set (in mileage if possible) Only ran for 15-20k miles, 50% of pad left Driving Style Sprinted, hard on the brakes. Tracked Not on these Other comments I always recommend the OEM pads for anyone looking for a great brake pad, and willing to put up with the dust. I personally hated the initial bite of the HPS Pads, and I was able to get the HPS's to fade at a lower temp than the OEM compound. For tracking: Year 2006 MS6 Mileage 74k-1k on pads No. of brake set (1st, 2nd, ect) 1st Current Rotors (Front/Rear) OEM Blanks Current Pads (Front/Rear) Carbotech XP12/Carbotech XP10 Properly bedded (yes, no, wait what?) Yes, it was fun Impressions (try to compare to last set) Amazing initial bite when cold. Extremely good bite when hot. Great linear pedal feel, and feedback. Zero fade. Tons of dust, and sounded like a freight train. Last set N/A Life of last set (in mileage if possible) N/A Driving Style Road Track, HPDE style Tracked Yes, 2 times Other comments For tracking, these Carbotech pads were well worth the money. The car felt very controllable under braking, with these, Nitto NT05's, and my old suspension set-up. Bedding in requires track time(or a 20min trip on the highway with a lot of braking lol). Also, they have a pretty decent amount of life in them. Here's a pic after bedding in the Carbotechs(20miles) lol:
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/brake-review-opinion-database-75651/ | ||||
| Brake Review/Opinion Database | SpeedForums.org | This thread | Refback | 07-27-2012 04:22 PM | |
| Brakes Database MS3/MS6! | jax ms3gt | MazdaSpeed 3/6 - Suspension & Brakes | 103 | 09-23-2017 01:14 AM |
| HOW-TO DATABASE MS6 | MATT DAMOND | MazdaSpeed 6 - How-To's | 42 | 11-21-2016 07:07 AM |
| HOW-TO DATABASE MS3 | MATT DAMOND | MazdaSpeed 3 - How-To's | 39 | 07-15-2015 07:29 AM |
| Honda Accord hybrid brake, acceleration claim under U.S. review | Haltech | Automotive News | 0 | 11-22-2010 10:10 PM |
| Brake and service opinion | kpsoerensen | MazdaSpeed 3/6 - Suspension & Brakes | 19 | 07-31-2010 08:19 PM |
