| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #401 | ![]() |
(Thread Starter) | Not Ranked : 0 score @Nliiitend1; and I were discussing on Sunday how the car would behave at the higher speeds since most everything has been focused on autocross and most recently focused on shifting the roll bias to the rear. I was lucky that Sunday was an autocross day on asphalt, because I set hot temps there and didn't touch them again before Monday. The car felt great, really. I could feel it was still pushy in steady state cornering but was able to get the rear around if I tried. This was just another indicator that the car could use more rear stiffness. There's more grip available in the rear with pressure and alignment changes, too. If the rear were to respond to LCA bushings as well as the front did, I would probably pick up a little bit of grip from them, also. Hopefully it's enough to offset the stiffer rear bar once it's moved into the stiffer settings. I would love to see the car pick up even more front grip from more rear roll bias.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following 7 Users Say Thank You to phate For This Useful Post: | Code Monkey (08-25-2015), Deldran (08-25-2015), Easter Bunny (08-26-2015), Funkster777 (08-26-2015), Mauro_Penguin (08-26-2015), Nliiitend1 (08-25-2015), SpeedRebirth (08-26-2015) |
![]() | | #402 | ![]() |
![]() Join Date: Feb 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,089
| Not Ranked : 0 score Love that you continue to make the 6 a true race car. With that said I really got to come to Midwest. Mobile Forum App Blows |
| The Following User Says Thank You to dagrimey1 For This Useful Post: | phate (08-26-2015) |
![]() | | #403 | ![]() |
![]() Join Date: Nov 2013 Location: Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 228
Groaned at 79 Times in 52 Posts
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | |
| The Following 2 Users Say Thank You to KevinK2 For This Useful Post: | Easter Bunny (08-26-2015), phate (08-26-2015) |
![]() | | #404 | ![]() |
![]() Join Date: Mar 2010 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,370
| Not Ranked : 0 score I had to opportunity to do a ride along with @phate; In short, it was amazing. His car handles dramatically different than mine. I was very impressed with what he could do with it and how it moves. Thanks again for the ride.
__________________ Funkster777 2010 Black Cherry Metallic Mazda 6 DD (well as needed) ![]() 2006 Black Mica Mazdaspeed6 Sport ![]() Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port? [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Funkster777 For This Useful Post: | phate (08-26-2015) |
![]() | | #405 | ![]() |
| Not Ranked : 0 score New sway bar testing ... I found some text results from when I modeled an Eibach sway bar for one of my cars, using a "simple beam theory" program. It reminded me that for a long slender bar like your new one, there is a contribution to lever-end deflection due to torsion bar slope at tube ends. If you transpose the applied point load to a force and a moment on the axis of the torsion rod section, the bending moment in question is based on the distance between the transposed force and the support bushing center (due to the dogleg in the lever arm). This puts the rod in "second mode" bending, with added deflection due to the slope at the ends: A simple manual dial indicator at the "hump" in the torsion rod position would capture this effect: http://i21.geccdn.net/site/images/n-.../TLS_53304.jpg This effect was small in the more typical bar I had modeled, but your bar is much more prone to this, based on geometry. .
| The Following 5 Users Say Thank You to KevinK2 For This Useful Post: | Code Monkey (08-26-2015), Mauro_Penguin (08-27-2015), Nliiitend1 (08-26-2015), phate (08-26-2015), zenit (08-26-2015) |
![]() | | #406 | ![]() |
I've thought for a long time that the car needed more rear stiffness for autocross. I was happy to see that the car was still pushy at Autobahn - I interpreted this as being still far away from having enough rear stiffness to see that shift at higher speeds, based on what Shaikh and you have just said.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |||
| The Following 5 Users Say Thank You to phate For This Useful Post: | Code Monkey (08-27-2015), Funkster777 (08-28-2015), KevinK2 (08-27-2015), Mauro_Penguin (08-27-2015), Nliiitend1 (08-27-2015) |
![]() | | #407 | ![]() |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #408 | ![]() |
![]() | | #409 | ![]() |
| Not Ranked : 0 score I would say no, but it is very easy for me to lose the rear the moment the track gets just a little bit of rain, or maybe I should try driving the car more like a FWD car.
| The Following User Says Thank You to Code Monkey For This Useful Post: | phate (08-27-2015) |
![]() | | #410 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Higher vehicle speeds definitely need less rear roll stiffness relative to the front than low vehicle speeds do for proper rotation/balance/good "steady state" behavior.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post: | Code Monkey (08-27-2015), Mauro_Penguin (08-27-2015) |
![]() | | #411 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Im just going to ask it: can I run just the rear setup u did? As in just the stiffer springs and perches and adapters on lca. Wish I didnt sell my BC COs for $200 as my rear is too soft on oem springs and koni struts.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
| The Following User Says Thank You to aviator79 For This Useful Post: | phate (08-27-2015) |
![]() | | #412 | ![]() |
I sort of do. The two big places I utilize the awd is the launch and corner exit. Otherwise it's very similar to fwd.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. Last edited by phate; 08-27-2015 at 11:24 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 5 Users Say Thank You to phate For This Useful Post: | aviator79 (08-28-2015), Code Monkey (08-28-2015), ItsNox (09-11-2015), Mauro_Penguin (08-28-2015), Nliiitend1 (08-28-2015) |
![]() | | #413 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lots going on recently. Last weekend we autocrossed and it was HOT! I left the SD card in my laptop the first day, so no video. The second day I did get some video. I still haven't gone through accelerometer data, and not sure that I will do much with it. It's an asphalt surface that we autocross on only twice per year. My fastest with a cone. It would have landed me second in class, but the cone knocked me back to 4th. That's just how it goes some days. Johanna's fastest: Me spinning after pushing way too hard: I got the rear bar bushings from @zenit; over the weekend, also. I put it all together on Wednesday and rate tested it similar to how I did the stock/whiteline bars: The company who did the bar and arms stocks a few shapes of the arms, and these were the longest arm they carry. I expected them to be a little short after bending - they're ~2" short of what I need them to be, and they also aren't quite as wide as I'd hoped for. That just means that, for now, I can't get a good rate for the softest setting. For the stiffest setting, I was expecting 188lb/in. The bar tested at 180lb/in. The "softest" setting at the shorter than expected arm length was 107lb/in. That's a little stiffer than I want it to be, starting out. I'm going to do a test fit on the car in just a few minutes. I have some ideas for extending the arms to achieve the softer rate. [With the outboard extension, all of the rates will be softened just slightly due to some bending in whatever assembly I make.]
| The Following 12 Users Say Thank You to phate For This Useful Post: | aviator79 (09-11-2015), Code Monkey (09-11-2015), Funkster777 (09-11-2015), jbbuie (09-11-2015), Justin@Freektune (09-11-2015), Mauro_Penguin (09-23-2015), Mazdazilla6 (09-11-2015), mxlplx71 (09-11-2015), TiGraySpeed6 (09-11-2015), WetzMS3 (09-11-2015), xfeejayx (09-11-2015), zenit (09-11-2015) |
![]() | | #414 | ![]() |
| Not Ranked : 0 score Fuck those lampposts, you're gonna hit one some day.
| The Following 5 Users Say Thank You to Code Monkey For This Useful Post: | Crarrs (09-12-2015), Deldran (09-11-2015), ItsNox (09-11-2015), Mauro_Penguin (09-23-2015), phate (09-11-2015) |
![]() | | #415 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score I was thinking this the entire time!!!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
| The Following 3 Users Say Thank You to ItsNox For This Useful Post: |
![]() | | #416 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score Lol, it looks bad from the video. I have never seen anyone hit one of those. I have only seen 2 accidents. One where a wheel popped off. And one where guy got squirly at the end the run and clipped the curb. Still safer than driving on the road with the hundreds of idiots driving around you. Sent from my SM-N910V using Tapatalk
__________________ Damond Built Speed 6 |
| The Following 3 Users Say Thank You to Deldran For This Useful Post: |
![]() | | #417 | ![]() |
| Not Ranked : 0 score Clint, that run with one cone was impressive ... you were coming so close to several cones. And there is one big left turn about 30 sec into the run where you have a lot of discretion on what line you will use, any comment on your approach there? Was the run in 2nd gear? What rpm were you maxing at ? Rear Bar looks real good! .
| The Following User Says Thank You to KevinK2 For This Useful Post: | phate (09-11-2015) |
![]() | | #418 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well that didn't take long With pulling the exhaust off, lunch, taking pictures and being really careful double checking everything, it only took about 3 hours. If the exhaust wasn't in the way and I was just throwing it on, I bet it's <1 hour of work. I stuck these guys up there to make sure the side pieces sit flush with the toe boxes and that the lower brackets were on the correct side. That all looked good, so I pulled the lower brackets off and lubed up the bushings and the bar. Stuck the lower brackets onto the bar, then set the bar in place. I put the arms on and re-centered the bar, tightened down everything... Driver side is at normal ride height, here: Passenger side suspension is at full droop in this pic: Plenty of clearance with the lower shock bolt: And with the diff: Everything turns smoothly, no binding at all. The holes must be aligned pretty closely! You can sort of tell in this picture how the arms don't extend backward quite far enough. And in this pic, you can get an idea of how far out the arms need extended: I think this is going to be easily remedied, and with a better-than-originally thought idea of how to keep the end links vertical at all positions. The other big question has been the exhaust. I'm going to end up dumping it right before the axle so I can lose weight, but I'm pretty convinced an exhaust shop could loop a section of the exhaust upward in this space: Seems there's plenty of room, even for a 3" pipe to go through. I may try this first, just to know for sure it could be done.
| The Following 9 Users Say Thank You to phate For This Useful Post: | Code Monkey (09-11-2015), Crarrs (09-12-2015), Funkster777 (09-14-2015), KevinK2 (09-11-2015), Mauro_Penguin (09-23-2015), mxlplx71 (09-11-2015), Nliiitend1 (09-11-2015), TiGraySpeed6 (09-11-2015), xfeejayx (09-11-2015) |
![]() | | #419 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score this sway bar and brackets look bad ass!! keep up tht work phate... maybe sell me one too lol... u know wat i would roughly cost for a mocked up 304 stainless short exhaust like ur thinkin?
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | phate (09-11-2015) |
![]() | | #420 | ![]() |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score Get in line ;-)
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
| The Following 3 Users Say Thank You to xfeejayx For This Useful Post: |
![]() | | #421 | ![]() |
After the start, we short shifted into 2nd and left it there. In the straight between the first and second lot, I data logged 6400-6500 rpm (I think that's ~55mph). The short straight coming into the finish saw as high as 7300 rpm.
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #422 | ![]() |
I have everything on the way for arm extensions and end links. I'll probably machine everything on Monday, retest the bar on Wednesday, then install Friday. That's an autocross weekend, so hopefully everything works out and we'll have this bar on for it. Not sure when I'll pull the whiteline bar...
![]() | | #423 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think everything is ready to go for install, tomorrow. I had a small bend put in the exhaust so the bar would be clear of obstruction. I'll get pics when I'm putting the bar on. @MSP611;, I forgot to ask about a dumped exhaust when it was on the rack. I got distracted trying to explain the situation to the exhaust guy. Anywho, I made some extension that look something like this: 3 positions for the end link to attach... Then I made some turnbuckles for the rod ends. These will be my end links: Did some measuring to make sure I was going to cut the arms to give the same positions relative to the bar: And I cut some slots into the arms so I can fine tune the lever arm length: Stuck it all together: ^That end link is attached to the wrong side, lol. They'll be attached to the outboard side of the arms. The holes are separated by the same distance as the length of the slot. Each hole will overlap with another holes position so it can be adjusted to any length in a 7" range. For now, I can't fully utilize it because the upper attachment points for the end links are in two very narrow ranges. I'm planning to make a rail or something up top so I can slide both ends to keep the end link vertical at all positions. I rate tested the bar with the new additions. Softest: 72 lb/in Stiffest: 190 lb/in I tested at 4 positions. Graphed together, the stiffness vs lever arm length looks like this:
| The Following 6 Users Say Thank You to phate For This Useful Post: | Code Monkey (09-24-2015), Funkster777 (09-29-2015), KevinK2 (09-24-2015), Mauro_Penguin (09-24-2015), Nliiitend1 (09-29-2015), xfeejayx (09-25-2015) |
![]() | | #424 | ![]() |
| Not Ranked : 0 score Nice work again. With the MR's included, how does your bar rate compare to the Whiteline in the poly bushings? Wheel rate or otherwise. .
| The Following User Says Thank You to KevinK2 For This Useful Post: | phate (09-24-2015) |
![]() | | #425 | ![]() |
WL Soft Setting: 43 lb/in WL Stiff Setting: 52 lb/in New Bar Soft: 72 lb/in New Bar Stiff: 190 lb/in If I leave the springs the same (850/800), the soft setting shifts the F/R roll bias by 2.4% rearward, and the stiff setting shifts it by 13.6% rearward. My plan is to go back to a 700 lb/in rear spring. In that case, the soft setting shifts bias by .5% rearward, and the stiff setting by 12.3% rearward. The soft setting is pretty darn close to what I wanted. I was expecting 73 lb/in for the softest setting.
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #426 | ![]() |
| Not Ranked : 0 score wow this is cool... now start sellin em!!! i need to figure out my dumped exhaust sitch but its hard not bein home
| The Following 2 Users Say Thank You to MSP611 For This Useful Post: | Funkster777 (09-29-2015), phate (09-24-2015) |
![]() | | #427 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bar is on ![]() Most of the above pics are at full droop; the last couple are at or near ride height. The clearance between the tire and end link is tight, only ~1/8". At normal ride height, it's ~1/2" (plenty!). I swapped to the 700 lb/in springs while I had everything apart to remove the Whiteline bar. We're driving up right now for an autocross tomorrow and Sunday.
| The Following 11 Users Say Thank You to phate For This Useful Post: | Code Monkey (09-25-2015), Crarrs (09-28-2015), Funkster777 (09-29-2015), KevinK2 (09-25-2015), Mauro_Penguin (09-29-2015), Mazdazilla6 (09-28-2015), nindoja (09-25-2015), Nliiitend1 (09-29-2015), TiGraySpeed6 (09-26-2015), xfeejayx (09-27-2015), zenit (09-25-2015) |
![]() | | #428 | ![]() |
| Not Ranked : 0 score Definitely only a street/autox use, I would bang the shit out of it at the track.
| The Following User Says Thank You to Code Monkey For This Useful Post: | phate (09-25-2015) |
![]() | | #429 | ![]() |
I'll take a picture of this tomorrow, but... If you look at everything in side view, the low part of the arm is within the area of the wheel and tire. Since the arms move with the wheel, any bumps you encounter at the wheel also raise the arms. It would have to be something the tires straddle to make contact with the arms. Edit: or it would take dropping a wheel off of the road surface where the bar arm will contact the edge. Not good if that happens, anyway.
![]() | | #430 | ![]() |
| Not Ranked : 0 score Yeah, spinning out and going over the curbing would do it, the LCA has this metal stripe that goes around the bottom, I already bent it in on one side.
![]() | | #431 | ![]() |
| The Following 2 Users Say Thank You to phate For This Useful Post: | Code Monkey (09-25-2015), Mauro_Penguin (09-29-2015) |
![]() | | #432 | ![]() |
| Not Ranked : 0 score I have special, hmmm, "talents".....
| The Following 3 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #433 | ![]() |
(Thread Starter) | Not Ranked : 0 score So...we found that the car can't be driven the same way, or the back end likes to go around the front. Transitionally, the car is sharper and it turns in better/faster. It turns in with a purpose, now. Steady state is nearly the same, there was a long sweeper and the car still pushed in that section. If we lifted off the throttle too much while the car was transitioning weight the back end would get loose very quickly, which is how the spins started. Before, we were having to lift very suddenly to get any rotation out of the car. Tires were an issue. We ended up flat spotting and cording a tire in one spin. They were pretty much dead, anyway, and overall grip was down. We ended up mid pack in the class despite everything. Subjectively, the car is more fun like this. I always compare to the speed 3 in this category and the 6 has always had a more serious and settled demeanor on course. The 6 feels light and agile with it. It's a new day. We were offered a set of wheels with Dunlop Z2's on them. Going to leave the bar at the softest setting to see if tires were the main culprit. Videos and whatnot later.
| The Following 8 Users Say Thank You to phate For This Useful Post: | Code Monkey (09-27-2015), Funkster777 (09-29-2015), KevinK2 (09-27-2015), Mauro_Penguin (09-29-2015), Mazdazilla6 (09-28-2015), Nliiitend1 (09-29-2015), TiGraySpeed6 (09-27-2015), xfeejayx (09-27-2015) |
![]() | | #434 | ![]() |
| Not Ranked : 0 score good info now u have too much rotation lol
![]() | | #435 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nah, just gotta get used to it and drive or more effectively. Fresh tires helped immensely. Just got done with our heat and everything was much better.
![]() | | #436 | ![]() |
well thts good to know i would like to know how a 6 setup like this drives... i might be a lil bit of a copy cat here soon when i come home...
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna | |
![]() | | #437 | ![]() |
I know you are busy now, but when you can please clarify the new bar rates ... is 72/190 at the wheels? Thanks
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo | ||
| The Following User Says Thank You to KevinK2 For This Useful Post: | phate (10-26-2015) |
![]() | | #438 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's single wheel bump at the wheels. Since it's a 1.0 MR, there is no reduction in bench rate except for the loss through the angle of the end links.
| The Following 2 Users Say Thank You to phate For This Useful Post: | KevinK2 (09-28-2015), Mauro_Penguin (09-29-2015) |
![]() | | #439 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's a couple videos from the weekend I edited quickly. The second video is probably a new favorite of mine...Johanna said not to put the camera there...
| The Following 8 Users Say Thank You to phate For This Useful Post: | cocoanton (09-28-2015), Code Monkey (09-28-2015), Crarrs (09-28-2015), Funkster777 (09-29-2015), Mauro_Penguin (09-29-2015), SpeedRebirth (09-28-2015), TiGraySpeed6 (09-28-2015), xfeejayx (09-28-2015) |
![]() | | #440 | ![]() |
| Not Ranked : 0 score First, congratulations on some great engineering work, similar to a Tri-Point Engineering product. Very timely since WL's adjustable 24mm bar (23mm oem) is out of production, as is Cork Sports' 25mm, leaving only the $365 24mm non-adjustable Autoxe bar. I finally plugged in your input numbers for your program, from post # 203, into my old Puhn based calculator, with the Whiteline bar at stiff for starts: 3469 lbs Total Wt 850F/800R springs 24mm OEM front bar WL rear bar , stiff @ 485 lb/in MR rear spring = .573 ---------------------- Front Total WT Bias = 58.6% Front Total WT Transfer Bias = 60.8% Steady State => Slight Understeer Front Sprung Wt Bias = 59.4% 16280 Fr Roll Rate, in-lbs/in @ Wheel 7984 Rr Roll Rate, in-lbs/in @ Wheel Rear end link @ 1G = ~240 lbs How does this compare? I used your sprung wt central CG location and lever arm to the roll axis, as those were inputs to my program for comparing other variables (to be corrected). I could run your current set-up, if that is more convenient. .
__________________ From Delaware Current Fleet: 04 Mazda6, 93 Rx7 TT, 76 Triumph 750 Trident Tracked Cars: 68 Triumph GT6 (~full race prep'd), 81 Porsche 924 Turbo, 93 Rx7 twin turbo Last edited by KevinK2; 09-30-2015 at 10:05 AM. |
| The Following 2 Users Say Thank You to KevinK2 For This Useful Post: | Mauro_Penguin (09-29-2015), phate (09-28-2015) |
| Suspension/combo or coilovers?? | gurusev | 2010 MS3 - Suspension & Brakes | 35 | 07-31-2013 11:06 AM |
| BC Coilovers or Bilstein Dampers/H&R Springs | Bleupit80 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 02-12-2013 07:35 AM |
| BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers | Doberman | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 07-28-2012 08:35 AM |
| Suspension Techniques Coilovers? | asiandude74 | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 02-06-2011 12:15 AM |
| MSD Dashhawk Data Logger Data Base | JimmyMac | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 06-30-2008 10:43 AM |
