| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
| Banned ![]() Join Date: Jan 2015 Location: Space Mountain, Honey
Rep Power: 0 ![]() ![]() Thanks: 142
Groans: 30
Groaned at 132 Times in 57 Posts
| Not Ranked : 0 score
![]() Join Date: Sep 2011 Location: Cape Town, South Africa
Rep Power: 237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
Thanks for the Racing Beat RSB End Links info, which I have also now included.
@Spencer@CorkSport; Have you discontinued the CorkSport Lower Front Brace / Front Lower Arm Brace and / or importing the Autoexe Front Lower Arm Brace? .
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass Last edited by Inquisitive; 03-18-2015 at 04:51 AM. | ||
| The Following 2 Users Say Thank You to Inquisitive For This Useful Post: | some call me...Tim (03-18-2015), TiGraySpeed6 (03-18-2015) |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to SpencerC For This Useful Post: | Inquisitive (03-18-2015) |
![]() Join Date: Jan 2012 Location: Georgetown, Ky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 689
Groaned at 45 Times in 22 Posts
What was it hitting?
__________________ 2010 Mazda Speed3 Autotech HPFP internals, Cobb AP V3, Corksport Springs, Skid Plate, TIP, TMIC, SRI, JBR 88 duro dogbone, RSB, Shifter bushings, Shift knob, 80 Duro TMM and PMM, OCC, Silicone Bypass Hose and Boost Tubes, Ulimate Racing axle back, Catless RP, Catted DP, Forge Motorsports V2 BOV, 6000k DDM low beams and fogs, iRotors cross drilled and slotted rotors, Akebono Ceramic pads, Tanabe Front Strut Tower Bar, Ruff Racing 355 wheels, 18x8, +40, 235/40-18 tires FREEKTUNED! 2003 Chevy S-10 2014 Toyota Camry 2011 Dodge Challenger R/T 1997 Geo Prizm | |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
That said, what calculations/datalogging have you run on your current suspension that makes you believe a 15-20% difference in RSB stiffness is going to drastically impact the capability of one bar over another for your needs? tl;dr Buy the one you think is the prettiest. You probably aren't going to be able to tell the difference on your commute.
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 | |
| The Following 4 Users Say Thank You to Crarrs For This Useful Post: |
| The Following User Says NO Thank You to Crarrs For This Un-useful Post: | license2ill (03-18-2015) |
They do make sense if you do the calculations for the bar, but it is the bar's rate, at the end link hole, holding 1 side static. Since there is a motion ratio involved, it will reduce the bar's effectiveness, and in roll you get deflection on both sides of the bar... If you want to relate it to body roll, it is most common to express the resistance to roll in terms of lb-in/1° body roll, where it takes motion ratio and track width into account. Otherwise, just the bench rate is great, none of this "lb/in/in body roll".
Most of the time, you can get a good idea of how much stiffer a simple bar is by looking at the change in diameter. Whiteline has a pretty decent chart showing this, here: If you are changing from solid to hollow, or vice versa, this chart doesn't apply. Like I said, though, it's not 100% accurate anyway. Just a decent means of estimating % change.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | ||
| The Following 4 Users Say Thank You to phate For This Useful Post: |
Groans: 30
I found this page on Whiteline's site that goes a little more in depth about adjutment holes and that chart you included. From the looks of it, the Whiteline bar is much more mild with a 16% and 35% increase from stock 26mm(adding 1 and 2mm on the chart), unless JBR's right about stock being 25mm. The Whiteline rear bar should be 36% and 57% stiffer if stock is actually 25mm. http://www.whiteline.com.au/docs/bulletins/BL-281.pdf I also found some info about the Progress 32mm hollow rear bar on another forum that states the stock rate of 862lbs/in. They also state the factory bar as measuring 25mm. The Progress bar has two settings: 56% stiffer than the stock sway bar with a rate of 1342.89 lbs/in and 79% stiffer than the stock sway bar with a rate of 1542.27 lbs/in. Progress Technology Rear Sway Bar Review That info on the Progress bar seems to roughly align with the Hotchkis numbers of 95% stiffer than the stock sway bar with a rate of 1625 lbs/in and 140% stiffer than the stock sway bar with a rate of 2030 lbs/in. But how the Hotchkis is supposed to be so dramatically more stiff than the with what looks like the same measurements and attachment points is another question though. How Corksport's 28mm hollow bar is only 14% stiffer at one point and a whole 80% more stiff at the inside attachment point is another question too, unless they are in fact basing their claims on JBR's numbers. For a piece that folks are saying is interchangeable amongst manufacturers, establishing a baseline of credibility to allow for a look at features and warranties is proving difficult yet again. | |
(Thread Starter) | Not Ranked : 0 score No fear, shipping costs would make me uncompetitive. Speaking of shipping costs, JBR ships for free yet for CS you must add $100.20 ($100.30) for US shipments. As an aside, shipping and customs fees usually doubles the cost of anything I purchase and I need 12 of my currency units for every US dollar (with lower local earning potential and lower purchasing power). Back to marketing: Where is the mention of R&D in their ads? Where is the sponsorship (of Nator)? Where do they claim that Nator endorses their products? Back to general point, where is the standard testing facility mentioned (or ISO manufacturing standards)? I thought that aluminium is usually more brittle than most other metals (not a good choice for a RSB?). Would mild steel work (backed by a lifetime warranty)? Is weight really a consideration (no marketing value) given that it is below the centre of gravity? Where is the DIY stuff? Surely welding a cross bar near the end to the middle would stiffen the RSB (bad or impractical design?). Are we doing our bit? If we asked vendors to provide the testing measurements, make modifications or provide a bulk discount, are we prepared to place orders in advance?
__________________ MS3 Gen2: AT: HPFP Int; Cobb: AP V3/ATR; CS: SRI/TIP, Catless DP; DIY: Air-box; GS: EBCS; Hankook: V12; NGK: 1 step cooler; OTC: EGR Del, OCC with VTA, PCV Plate, TP Coolant Bypass |
| The Following User Says Thank You to Inquisitive For This Useful Post: | license2ill (03-23-2015) |
Groans: 30
I'm still wondering if the stock rear sway bar is actually 25mm or 26mm, and if the Hotchkis is thicker material than the Progress bar, and how a 28mm CS bar achieves the numbers or if they really even mean 14% stiffer. The gap from hole to hole on the CS bar can't make for that dramatic of a difference, and at 28mm, it should be slightly stiffer than the 27mm Whiteline, but less than the 32mm bars. Where are JBR's numbers coming from and how do they relate to the numbers for the other 32mm bars out there? | |
Groans: 111
| Not Ranked : 0 score The factory rear sway bar is 25mm, front is 26.
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
I did the math on my bar vs the stock bar to calculate spring stiffness and made it according to what I wanted. Also, material can be changed as well, but I was set on 4140 as my material, so that wasnt an option for me
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC | |
| The Following 2 Users Say Thank You to maisonvi For This Useful Post: | Inquisitive (03-25-2015), phate (03-25-2015) |
And you're right, 80% of commutes I wouldn't be able to tell the difference. But if I install a mega stiffness bar and come around a freeway overpass doing 60+, encounter a traffic jam requiring immediate near-maximal braking, and the car snap-oversteers I'd know it. And that type of traffic situation happens WAY more than I'd like. But you're right that 15-20% probably won't change anything. | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f12/official-suspension-bars-braces-thread-185726/ | ||||
| Bars, but not the thirst-quenching kind | This thread | Refback | 06-29-2015 09:58 AM | |
| The Official MS6 Suspension Thread | RhoadBlock | MazdaSpeed 3/6 - Suspension & Brakes | 182 | 07-24-2018 11:38 AM |
| Official Suspension Bars and Braces Thread | Inquisitive | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 71 | 03-24-2015 06:10 AM |
| The Official MS6 Suspension Thread | RhoadBlock | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 1 | 09-19-2012 01:36 PM |
| Strut tower braces or f/r sway bars? | dMuze | 2010 MS3 - Suspension & Brakes | 4 | 12-14-2011 10:26 PM |
| MS6 Aftermarket Suspension Braces Worth It? | Alpha | MazdaSpeed 3/6 - Suspension & Brakes | 8 | 07-12-2011 08:22 AM |
