![]() Join Date: Aug 2016 Location: New Hampshire
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score This happens if I'm accelerating hard to pull out into traffic or getting on the highway, etc. Any ideas what it could be? TIA |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Is your spoiler loose? Maybe the screws that hold the spoiler in place fell out. only thing i can think of. Where in NH are you?
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Sounds like it could also be a damaged rear diff...
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | KiwiFlavor (08-18-2016), robbspeed (08-18-2016) |
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
| Not Ranked : 0 score Your positive it's coming from the rear? Any chance you could grab a recording of the sound?
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
Groans: 50
| Not Ranked : 0 score If that's the case what would be the best way to confirm? Drain the diff and look for wear metal? Or jack up the rear, grab the wheels and turn them back and forth to check for excessive play?
(Thread Starter) | Not Ranked : 0 score My rear diff was worked on a while back and should be perfect - that was for a constant low humming sound that was increasing as days went by. The work took care of that noise instantly (thank goodness). But the rattle is a different sound. I could try to record it but it's only while I'm driving and it's intermittent. I don't have a spoiler, so it's not that. Perhaps I should get my husband to go under the car and see if anything is loose (nuts/bolts/etc)? I'm in Loudon NH
![]() I definitely think the sound is coming from the back and not the front - but perhaps it's in the midsection of the undercarriage? Last edited by Misty; 08-19-2016 at 12:23 PM. Reason: MSF Database - Automerged Doublepost | |
Groans: 50
| Not Ranked : 0 score It could help if you grab a recording of the sound the next time your in the car. Keep us posted either way.
(Thread Starter) | Not Ranked : 0 score So I attempted to record the sound while driving and was only able to duplicate the sound once out of maybe 12 accelerations, and my recording is not the greatest. It seems like when I TRY to make the sound nothing happens. And when I least expect it - there is is. LOL - frustrating. Not sure how to attach the sound, I used my video recorder on my phone. |
Groans: 50
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. | |
![]() Join Date: Jul 2016 Location: Arroyo Grande, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 27 Times in 10 Posts
| Not Ranked : 0 score 30 years of owning my own shop I can tell you no one on this site will be able to help. Recording it is a waste of time. Couldn't tell you how many times over the years I have had calls about rattles or noises that the customer wanted a diagnoses over the phone. Take it to your mechanic and have him drive it.
__________________ Mazdaspeedchris |
| The Following User Says NO Thank You to mazdaspeedchris For This Un-useful Post: | robbspeed (08-22-2016) |
![]() Join Date: Nov 2015 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Could be the exhaust muffler. |
![]() Join Date: Sep 2017
![]() Join Date: Oct 2015 Location: Seattle Area
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I would be very suprised if was coming from the rear and sounds like that. I’m about to post about a rattling I was hearing that very closely resembles the marble sound you describe except that it was under boost and coming from the FRONT of the car. You probably have detonation happening. Any codes from the OBD II? Otherwise if you’re certain it was from the back, I’d check the muffler to see if maybe some rocks didn’t fall into it from the exhaust tips. Best to have a mechanic look at it if you’re not sure as you could be doing some damage. |
| Metaalic rattle when accelerating | CaliTurbo | Mazdaspeed3/6 General Discussion | 7 | 08-10-2016 12:52 PM |
| Gen 1 rattle noise while accelerating | JDM_Rivera | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 06-07-2016 08:48 PM |
| Noise while accelerating | Boborn | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 11 | 05-25-2014 07:28 PM |
| shaking when accelerating | Sal's_MS6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 06-13-2011 07:06 PM |
| Problems when accelerating | egbertnr | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 31 | 07-29-2010 07:02 PM |
