![]() Join Date: Jul 2015
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I have a 2010 CX-7 with about 88k miles, 2.3 turbo engine. About a week or so ago the engine started hesitating and would not fire properly. My local shop, who is very honest and I trust, thought it was just a plug and replaced them. That did not help. They wound up replacing the fuel injectors, yes all 4 of them, and now the car runs great, better acceleration and fuel economy. The problem now is there is a strange sound only during startup when the car has been sitting for a while. It sounds like a mini back fire. We started it up the other day and a puff of smoke came out of the front of the engine during the back fire noise. Please see videos attached. Other than that the car runs great. Any ideas what could be causing the sample and feint back fire sound? My shop is at a loss as to the problem. Sent from my iPhone using Tapatalk |
(Thread Starter) | Not Ranked : 0 score Here is a link to the video https://drive.google.com/file/d/1tem...w?usp=drivesdk Sent from my iPhone using Tapatalk |
Groans: 60
| Not Ranked : 0 score Bad injector seals.
(Thread Starter) | Not Ranked : 0 score Thank you for the response. Does that mean the injector seal is not seated properly or it is old or both? Just need replacement? Sent from my iPhone using Tapatalk |
![]() Join Date: Jun 2009
| Not Ranked : 0 score New seals should have gone in with the injectors. They probably damaged one or more or did not get at least one seated properly. Let them know and ask them to make it right.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Suwanee CX-7 (09-13-2019) |
(Thread Starter) | Not Ranked : 0 score Thanks everyone Sent from my iPhone using Tapatalk |
| Noise from engine at startup - Help | mariosalguero | Mazdaspeed3/6 General Discussion | 14 | 04-22-2015 02:04 PM |
| Startup problem after engine rebuild | EmPeEs6 | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 06-07-2014 08:58 AM |
| What should be done prior to startup of new engine? | cplensdorf | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 01-22-2012 06:51 PM |
| Engine Bay Smoke | titusdrake | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 26 | 09-08-2011 11:27 AM |
| Industry veteran Runkle named CEO of diesel-engine startup firm | Haltech | Automotive News | 0 | 09-14-2009 04:30 PM |
