![]() Join Date: Apr 2016
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I think my turbo seals are gone and im needing to remove and reinstall my turbo but im curious if you have to remove/lower transaxle in order to get the turbo out. I have the 2010 cx - 7 AWD. I asked this in a thread i already had but didnt get an answer so i thought i'd create new thread. I have done alot of reading and i've read both answers that yes you have to remove'/lower transaxle for the AWD model.. is this true??? Thank you in advance. |
![]() Join Date: Oct 2015 Location: Seattle Area
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I don't think you do, but it's still a pain. Does anyone have the factory repair manual guide? |
Groans: 211
| Not Ranked : 0 score Go VIP and the FSM's are available. The turbo is removed from the top of the engine.
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score The turbo is easily removed with a stick of dynamite ![]() You can remove the turbo from the top : removing the cowl will help but is not necessary...however be ready to curse a lot with the bolts and O2 sensor...those are frequently seized! The workshop manual is in the CX-7 intro thread
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| HOW TO: Remove your turbo | CX7Haley | CX-7 > How-To's | 11 | 09-16-2014 10:43 AM |
| How do i remove the lower lip? | tragik | 2010 MS3 - How-To's | 16 | 10-12-2011 10:21 AM |
| How Hard to Remove Turbo ? | Scatt Nasty | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 02-26-2009 05:55 PM |
| Lower peak boost after Turbo Inlet install | 802MS3 | MazdaSpeed 3/6 - Turbo Induction | 22 | 01-16-2009 06:54 PM |
| MS3 Transaxle oil | pbblaster | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 04-10-2008 07:39 PM |
