> CX-7 > Car Audio & Electronics
 Old 10-30-2013, 07:22 PM   #1
ryoonc's Avatar
Posts: 15   (View Stats)
ryoonc is just really niceryoonc is just really niceryoonc is just really niceryoonc is just really niceryoonc is just really nice
Default Flickering headlight while turning
Has anyone had the issue where one of the low-beams would turn off while turning?
I noticed that while turning (right turns especially, left turns sometimes), the passenger-side headlight (not the driver-side low-beam, that one seems fine) would flicker then turn off, and I would have to turn off the headlights and turn them back on again, after which it resumes normal operation until my next turn.
I tried unplugging the ballast and plugging it back in but it didn't seem to help. I searched the forums and found that it may have something to do with improper grounding and that I should spray the contacts with contact cleaner... I will be trying that this weekend, but has anyone run into a similar problem?
MazdaEdit ECU Flash (14psi flat boost)
Corksport Power Series TBE
AEM Short Ram Intake
Autoexe Strut Tower Bar
Forge BPV
ETS 3" TMIC
H&R Sport Lowering Springs
Complete interior/exterior LED swap (VLEDS v3 triton amber, red, and switchback)
ryoonc is offline   Reply With Quote
 Old 10-30-2013, 08:15 PM   #2
jeymz's Avatar
Posts: 163   (View Stats)
jeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond repute
Are you running an HID kit? If so, try swapping ballasts and see if the issue occurs on the drivers side. Cleaning the terminals is a good idea as well. Good luck.
2011 LSM w/ Tech Pkg
Cobb AP - OTS Stage 2 | Ultragauge | Autotech HPFP Internals | DENSO ITV22s | Forge BPV v2 | CS TMIC | CS Boost and BPV Tubes | CPE Nano SRI w/ Amsoil filter | CS TIP | OBX race pipe | CPE Stage 2 RMM | JBR PSMM 80 | JBR TMM 80 | JBR Shift knob, weight, bushings | JBR RSB | JBR Rear camber arms | Sure SSP | MD OCC | Corksport Springs | Bilstein Sports | FCM Rear Bumpstops | FoMoCo tranny fluid | CS Tow Plate | CS LED Kit | CS Fog LEDs
jeymz is offline   Reply With Quote
 Old 10-30-2013, 08:33 PM   #3
ryoonc's Avatar
No, they are the stock ballasts for an '07 CX-7 GT. I recall that they were wired and mounted in a way that would make it very difficult to remove, but I will definitely see about trying to do that.
Forge BPV
ETS 3" TMIC
 Old 10-30-2013, 08:40 PM   #4
jeymz's Avatar
Gotcha, since they are stock I would leave the ballasts alone and try cleaning the connections like you mentioned. Maybe try swapping bulbs?
 Old 12-20-2016, 09:50 AM   #5
Dertdog77's Avatar
Posts: 1   (View Stats)
Dertdog77 is an unknown quantity at this point
What was the outcome? I'm having the same issues.....
BNRS3v2, Cobb AP V3, Cobb 3 Port EBCS, Bosch 3 Bar, CS TBE, ETS TMIC, JBR CHARGE TUBES, HTP 3" Intake System, Forge V2, CPE Stage 2 RMM, Autotech Internals, ITV22, CS SSP, CS SHIFTER BUSHINGS, CS Adjustable Shifter and Knob, CS SWAY BAR w/ Billet Brackets, CS MID CHASSIS BRACE, Koni Yellows with H&R's, 18 x 8.5 ET38 Raijins, FREEK'D E85
Dertdog77 is offline   Reply With Quote
 Old 05-28-2018, 11:45 AM   #6
Dropenhouser's Avatar
Posts: 4   (View Stats)
Dropenhouser is an unknown quantity at this point
If you are turning and the lights turn of, maybe is a problem with the wires into the steering wheel.
Remove the plastic panel behind the sterring and see if there any problem with tight wires moving the steering.
Dropenhouser is offline   Reply With Quote
 Old 05-28-2018, 12:20 PM   #7
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Bruh, 2016....
 Old 05-28-2018, 12:32 PM   #8
Originally Posted by kTaLgsTo View Post
Bruh, 2016....
Well, is historic help... i found help here in the forums from 2016 to fix something today... Everything is usseful when you have a car w/o much info on inet.
HID Flickering Issues Airman3454 Exterior 25 01-22-2015 04:48 PM
oil light on and flickering when below 2000 rpms Peterspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 04-09-2013 08:37 PM
My car is turning against me! Please help! Downthecrapper MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 02-08-2013 08:14 PM
AFS turning headlight conversion Nataphen Exterior 15 11-19-2010 08:10 PM
flickering hid's jman46 MazdaSpeed 3/6 - Car Audio & Electronics 3 05-31-2010 06:10 AM
Page generated in 0.27855 seconds with 24 queries
