> CX-7 > Car Audio & Electronics
 Old 10-22-2016, 01:35 PM   #1
i2c
i2c's Avatar
Posts: 1   (View Stats)
i2c is an unknown quantity at this point
Default Woofer out from Bose amp and replace rear spekares
Can not find in old posts. Find one well instructions, but need exact info on which one pins (number, cable colour) can I connected signal wire for additional woofer amp.
Also: did someone know what frequency response goes from Bose amp to back door speakers? I do not find reason for bad sonud in back doors. Speakers or response from amplifier?
Did someone cut this speakers from Bose amp and use out from bose amp to another amp and better speakers?
Thanks for replay.
i2c is offline   Reply With Quote
 Old 10-22-2016, 05:47 PM   #2
distortion's Avatar
Posts: 66   (View Stats)
distortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud ofdistortion has much to be proud of
Take a look here for a some recent discussion on the topic: Hooking up a sub and need help
I used the PAC converter myself and it worked great. No cutting or splicing of the factory wiring and made it easy to add an additional amp/sub and also uses a clean signal. The Bose amp does a lot of odd sound processing so I wouldn't recommend using anything from it as an output if you are trying to improve sound.
2011 Black Mica W/Tech Package
Cobb AP|CP-E HPFP|Corksport SRI/TIP|Corksport TMIC|UR Test Pipe|Corksport Cold Air Box|Corksport Rear Sway Bar|JBR Shifter Bushings|Corksport RMM|Techna Fit Stainless Brake Lines|Ultraguage|Stratified E85
distortion is offline   Reply With Quote
2012 Speed3 Bose Sub Replace SOCOPiranha 2010 MS3 - Car Audio & Electronics 3 07-17-2016 06:54 PM
New system to replace Bose BreakTheStatic MazdaSpeed 3/6 - Car Audio & Electronics 18 03-23-2011 12:28 AM
Page generated in 0.23038 seconds with 21 queries
