![]() Join Date: May 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 18
(Thread Starter) | Not Ranked : 0 score This would fit on a CX-9 too. Rust New rotors, caliper bracket, pad Old rotors, caliper bracket, pad.. quite a difference Last edited by ryoonc; 07-11-2013 at 05:34 PM. |
| The Following 7 Users Say Thank You to ryoonc For This Useful Post: | Colin1337 (07-11-2013), dale_gribble (07-11-2013), Easter Bunny (07-26-2015), H3R3TIC (07-11-2013), Raider (07-11-2013), Tomas (07-11-2013), torquemaniac (03-19-2019) |
| Not Ranked : 0 score Very cool. In theory, since CX-7 shares a lot with MS6, CX-9 brakes may fit Speed 6! |
| The Following User Says Thank You to Raider For This Useful Post: | Colin1337 (07-11-2013) |
(Thread Starter) | Not Ranked : 0 score If the backing plate is the same size, then it probably would haha It was the most economical bigger-brake upgrade that I could think of (was originally my friend/mechanic's idea). Corksport and Brembo seem to be the only choice otherwise, but there are other things I'd rather do first with ~$1.5k.. The only reason I did this was because it was relatively cheap ($300 total parts+labor) and my front pads/rotors were almost done anyways. The rear rotors, after 76k miles, still look pretty clean and even now the pads seem to have plenty of padding left so I'll probably leave those until they wear out. Also long time no see raider, you still got your 7? (im ryoonc from mcx7.com a while back, the site seems to have died) |
![]() Join Date: Jun 2012 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 981
| Not Ranked : 0 score Would be awesome if this actually ended up working on the 6 as well. Cool idea
__________________ 2005 CTS-V KCCO 2006 Mazdaspeed6 SOLD COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion 1995 Miata SOLD Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts. |
| Not Ranked : 0 score What size are the CX9 brakes? Also aren't their calipers twin piston?
| The Following User Says Thank You to ryoonc For This Useful Post: | Lex (07-11-2013) |
| Not Ranked : 0 score So the rotor diameter on the CX-9 is the same as the MS3. The calipers are the same CX7 and CX9.
![]() Join Date: Nov 2013 Location: Odenton, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 169
| Not Ranked : 0 score Old thread bump - So will they fit on a ms6 or no?
__________________ 2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014 Motor: 2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM Suspension: Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels Visual: 25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob Fluids: Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 / |
![]() Join Date: Apr 2015 Location: Fort Riley
| Not Ranked : 0 score I'm assuming this is just a front brake upgrade...I don't see the rear needing much Also, I would just need to buy the bracket, rotor, & front pads for a 9 correct?
__________________ 2009 CX-7 AWD Sport CS Intake, TIP, EGR delete, Synapse DV Last edited by JVal1283; 07-26-2015 at 05:40 PM. |
![]() Join Date: Jan 2011 Location: Carolina, Puerto Rico
| Not Ranked : 0 score is there anyone that actually made it and can confirm the new minimum wheel size with those cx9 brakes. I need to replace brakes on my wife cx7 but she just bough brand new 17inch winter tires this year and i would like to be able to re-use it... I ask because while hauling the camping car with it, having better brakes could help a bit...But if it need 18inch minimum, i may just look into more agressive pads and keep factory size. By the way, i can confirm the cx7 2010 factory size front brakes are smaller in diameter than Ms3 or MS6, but the disc thickness is heavier on the cx7. (i have both in hands.) So ms6 swap could give more ''bites'' but could probably fade a bit faster because of the thickness difference The ms3 and 6 are close in diameter and the ms6 caliper + braket would bolt up there (I mean replacing both caliper + brakets and disc) but not with the 3 hardware.....
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score what year CX-7 does the OP have? Gen 1 or Gen 2? or all the front brakes on the CX-7 the same? Also anyone experiment with the Gen 2(16-19) CX-9 front brakes? |
old mazda was using fomoco parts with ford but new cx9 are no longer half a ford so i expect less chance to fit...maybe more from an escape or something similar.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | redboat (11-12-2019) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f126/cx-9-sized-brakes-cx-7-a-149983/ | ||||
| Has anyone removed their brake backing plates? | This thread | Pingback | 08-06-2014 06:36 PM | |
| Display Modes | |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 110 | 09-19-2012 01:42 PM |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MazdaSpeed 3/6 - Suspension & Brakes | 109 | 03-02-2012 06:14 PM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
| over sized throttle body... | SpeedSixxx | MazdaSpeed 3/6 - Turbo Induction | 13 | 07-25-2009 10:29 AM |
