> CX-7 > How-To's
Like Tree3Likes
  • 3 Post By bzwyatt
 Old 04-09-2011, 08:43 AM   #1
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
Neutral  :  +3 score
Default Glovebox damper replacement how-to
Here's pics of the process of replacing the broken damper. Fist pic is my broken damper. You can see an 'R' on it; that's the side that faces the right/passenger side of the car when installed.
Next shot is the glove box assembled; you can see the damper connected (a screw you have to take out to replace it is also visible). Push that part away next time you take the glove box out so you don't break it, as seen in the next pic.
Once you have the glove box out, take out the four screws behind the glove box on the dash. Also take off the plastic nut up under dash in the footwell area. Then take off some of the door seal and pull away the plastic parts of the dash until you can access the screw holding the damper on.
Take out the screw, replace the damper and reverse the process.
stingerbtry, dotta and Johnboy like this.
bzwyatt is offline   Reply With Quote
The Following 4 Users Say Thank You to bzwyatt For This Useful Post:
davidvh (05-18-2016), diyer_123 (12-31-2016), Nitr0EngiE (03-20-2014), vbt101 (04-09-2011)
 Old 04-09-2011, 04:45 PM   #2
Moved to how-to! Thanks!
 Old 03-15-2014, 11:03 AM   #3
dotta's Avatar
Posts: 1   (View Stats)
dotta is an unknown quantity at this point
Default Broken Glove Damper
This is awesome. I was going to go to the dealer because I could not find how to get the broken part off.
Thanks for the pics....
dotta is offline   Reply With Quote
 Old 03-23-2014, 09:02 AM   #4
edh76's Avatar
edh76 is an unknown quantity at this point
Thank you very much. I just replaced mine with no problems thanks, to you!
edh76 is offline   Reply With Quote
 Old 03-23-2014, 12:53 PM   #5
bzwyatt's Avatar
Glad to help
 Old 05-18-2016, 12:40 AM   #6
davidvh's Avatar
Posts: 5   (View Stats)
davidvh will become famous soon enough
Thanks!
Out of curiosity...
What is the OEM glovebox damper part number?
davidvh is offline   Reply With Quote
 Old 05-18-2016, 01:07 AM   #7
Nice two year thread bump
sent from my Nexus 6P
 Old 05-18-2016, 01:31 AM   #8
davidvh's Avatar
Just asking for a little help. Isn't that what these forums are for? To share, offer advice, and ask to be pointed in the right direction?
My damper on a 2007 CX-7 broke. I think the part number is EH456408X. Can someone confirm?
 Old 05-18-2016, 04:27 AM   #9
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
Hi, I have the following part numbers, hope it helps
Part: GLOVE BOX FRAME DAMPER
Part Number:
EH45-64-08X (2004 - 2009 Mazda 3, 2007-2011 CX7)
BHN1-64-08X (2010 -2013 Mazda 3)
2008 Gen1 MS3
Self tuned on E85
The Following User Says Thank You to Spectrix For This Useful Post:
 Old 05-19-2016, 12:28 PM   #10
davidvh's Avatar
Much to my surprise my local Mazda dealer had the part for less than I found online - $15 CAD.
I was planning to install the part myself. However, when I showed the Mazda service department the broken piece, he agreed that a mechanic may have not taken enough care when the cabin filter was replaced. The dampener's loop was cracked in several places. To my surprise I wasn't charged for either the dampener or the time it took to install.
Installation was quick, too - less than ten minutes.
Thanks for your help, guys.
The Following User Says Thank You to davidvh For This Useful Post:
Spectrix (05-19-2016)
 Old 06-02-2016, 02:13 PM   #11
Johnboy's Avatar
Johnboy is an unknown quantity at this point
Thumbs up
Thank you for providing this thread.Got my damper for the glove compartment replaced.
Johnboy is offline   Reply With Quote
 Old 06-23-2018, 10:01 AM   #12
doc4bax's Avatar
Posts: 7   (View Stats)
doc4bax can only hope to improve
Thanks for posting! I coundn't find any info on this.
doc4bax is offline   Reply With Quote
 Old 07-05-2018, 11:23 AM   #13
doc4bax's Avatar
Great directions. Just replaced mine. Thanks!
The Following 2 Users Say NO Thank You to doc4bax For This Un-useful Post:
Db09ms3 (07-05-2018), JSmith (07-05-2018)
Torque damper thenewzolt 2010 MS3 - Engine, Transmission & Driveline 26 02-24-2013 05:38 PM
Jaguar ditches touch control glovebox on 2011 XF Haltech Automotive News 0 01-05-2011 09:20 AM
Engine damper for MS6? Speedie6 Mazdaspeed3/6 General Discussion 6 04-10-2009 02:27 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Engine Damper? Qluber MazdaSpeed 3 - Engine, Transmission & Driveline 3 09-24-2008 06:12 PM
Page generated in 0.32250 seconds with 29 queries
