> CX-7 > How-To's
 Old 07-18-2014, 04:47 PM   #41
Ozynigma's Avatar
Posts: 743   (View Stats)
And if you are really keen, take off the inlet manifold and hand clean the valves. I haven't done it yet at 127,000 km's so I am not an expert on this. This is what the inlet cleaner (seafoam etc) is supposed to do.
 Old 07-18-2014, 04:53 PM   #42
Ozynigma's Avatar
Originally Posted by bkdow View Post
Dealer wants $860 and my local guy wants $1,000 to replace it. UGH!! Anyone got an idea?
Replace what? The EGR?
Why not just clean it, instructions in first post.
Last edited by Ozynigma; 07-18-2014 at 06:11 PM. Reason: Forgot what thread this was.
 Old 08-09-2014, 04:43 AM   #43
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Dam I got a P0401 code today. Well time to have fun today.
Project_dog is offline   Reply With Quote
 Old 08-09-2014, 06:39 AM   #44
torquemaniac's Avatar
Posts: 733   (View Stats)
Best thing to do is to unpluig the EGR solenoid and delete the code (P0401) with versatuner
On a direct injection engine, the EGR + blowby is was cause shit buildup on the valve
You unplug the solenoid to get rid of the EGR (no need to buy a EGR delete kit) and use a catch can for the blowby
I had my EGR deleted for about 18 months now, and no problem with reliability
2011 CX-7 AWD 2.3 turbo
 Old 08-09-2014, 10:23 AM   #45
My question is. Let's say I do that. Will I have a cel
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
 Old 08-09-2014, 10:46 AM   #46
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
Not if you have a VersaTune
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 08-09-2014, 01:15 PM   #47
You will have a CEL, but it can be deleted with versatuner
 Old 08-09-2014, 01:48 PM   #48
lildisco's Avatar
I too did the above advice & have had my EGR unplugged since April/May of this year w/o any issues. It did throw a couple of codes (all related to the EGR), but i have VersaTune ignore them in my tune.
I also installed an oil catch can for the past month or so & it hasn't collected one drop. I also switched to Rotella T6, which may explain that. I did have some oil build in my intercooler & in my intake manifold. I haven't checked since my occ install though.
Tuned with
 Old 08-09-2014, 04:00 PM   #49
Yeah, if you can disable P0401, totally block the egr off or remove it. But many just need it cleaned. Then all you need to do is run Chevron Techron Complete Fuel System cleaner every 3,000 miles. Keeps it from sticking.
 Old 08-09-2014, 04:17 PM   #50
How is your catch can hooked?
 Old 08-09-2014, 05:19 PM   #51
lildisco's Avatar
PCV to input & output to the intake manifold. Checked it a few times to be sure it was hooked up correctly. It also has a check valve on it. It's a stage 2 from JBR.
Tuned with
 Old 08-09-2014, 06:25 PM   #52
I dont want to bash JBR products, but I am not a fan of this kind of setup...
If the can is placed in between the PCV and manifold, the can will do nothing when there is pressure (boost) in the manifold, because the pressure in the manifold is greater than the one in the crankcase (the check-valve prevent the manifold pressure from going in the crankcase, but also block the flow of blowby out of the crankcase)
If the blowby cant escape via the PCV when there is pressure in the manifold, it will take the other route, which is the valve cover vent (the one that connect to the TIP)...this is why you have oil buildup in the TIP and intercooler
In my opinion, the catch can should not be in between the PCV and manifold, but in between the valve cover and TIP
The PCV only vent when under vacuum, and when under vacuum (which is mostly at idle), the blowby are at a minimum (blowby are a at maximum at WOT)
There are other efficient catch can setup, but the simplest is with the catch can in between the valve cover and TIP (with the PCV hooked to the manifold in the regular way to have some vacuum to vent the crankcase at idle)
Im pretty sure if you look at your TIP now, you will have some oil in there...
There was a great thread about the different setup, but I cant find it
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
lildisco (08-09-2014), Ozynigma (08-09-2014)
 Old 08-09-2014, 06:31 PM   #53
lildisco's Avatar
I'll have to look into this. JBR seems to be a pretty reputable place. The other occ installs I've seen put it in the same location.
Tuned with
 Old 08-09-2014, 11:19 PM   #54
bkdow's Avatar
Posts: 5   (View Stats)
bkdow is an unknown quantity at this point
Default Finally done
Brake booster. BUT, now we know it does NOTHING to improve anything, don't waste time and money. Clean the egr and be done.
Got to it today. It took about 4 hours total including an hour getting cleaner and gasket from the dealer. The hardest part was getting the turbo tube in and out. Probably spent 45 minutes on that alone. I did not clean the tube. The egr was awful.
bkdow is offline   Reply With Quote
 Old 08-10-2014, 10:17 AM   #55
Think of it this way : the oil you get in the TIP and intercooler are surely not coming from the PCV, because the PCV is not connect to the TIP...but its coming from the valve cover (this one is connected to the TIP)...if you put the catch can there I can assure you will accumulate in the catch can (and alot less will manage to get to the TIP and intercooler)
The check-valve in the JBR stage 2 kit is there to prevent boost from seeping pass the PCV when you up the boost higher than stock level (hence stage 2)
FYI, im not pretending to be a know-it-all guy...just trying to be helpful
 Old 10-23-2014, 02:36 PM   #56
Lancer-AM's Avatar
Posts: 306   (View Stats)
Lancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the world
Thanks for the guide @Raider; I did this to my wife's CX-7 two years ago following your guide. The code finally came back this week. Time to tear it down and do it again. Pretty painless overall.
2010 Mazdaspeed 3 Tech
Stocking out
If a person says they 'work smart, not hard,' odds are they are lazy and stupid.
Lancer-AM is offline   Reply With Quote
 Old 10-23-2014, 02:38 PM   #57
Try the Chevron Techron Complete Fuel System Cleaner. As the weather cools, these threads will liven up. But try that magic sauce, the $15 bottle. Within 200 miles, mine went away.
Lancer-AM (10-23-2014)
 Old 10-23-2014, 03:29 PM   #58
lildisco's Avatar
Unplugging it & disabling the code in Versa Tune is working quite well for me
Tuned with
 Old 10-23-2014, 04:03 PM   #59
Yeah, but that's not what this thread is for.
 Old 10-23-2014, 05:01 PM   #60
lildisco's Avatar
Understandable, just saying that if you do it through a tune, i haven't notice any ill effects
Tuned with
 Old 03-23-2015, 07:58 AM   #61
FatSauze's Avatar
Posts: 61   (View Stats)
FatSauze has a spectacular aura aboutFatSauze has a spectacular aura about
Gonna give this a try this week having loooong cranks prior to engine start.
/CS SRI/CS TIP/CS INTERNALS/CP-E EXHAUST/CP-E TMIC/FORGE BPV V2/AUTOEXE STRUT BAR/VERSATUNE/
FatSauze is offline   Reply With Quote
 Old 04-01-2015, 10:25 AM   #62
FatSauze's Avatar
Just did it, took me a while but I'm a novice and had to run around borrowing certain tools from friends and neighbours. Car runs great no more long cranks on start up. what a biotch to get that EGR pipe off near the front fan.
 Old 04-12-2015, 06:16 PM   #63
ms33's Avatar
Posts: 16   (View Stats)
ms33 is an unknown quantity at this point
Well, today, my pops and i decided to give it a shot, we ended up cleaning the Throttle Body and the tube... made a little video of it of how we did clean up the tube.
I am also looking for a mechanic with CX7/MS6/MS3 experience to help me take out the Turbo and inspect it.
Im located in New Jersey....
Mazda CX-7
-HID All Around 8k 55W
ms33 is offline   Reply With Quote
 Old 04-14-2015, 06:35 AM   #64
Why does the turbo need inspection?
 Old 04-15-2015, 10:33 AM   #65
ms33's Avatar
because i've seen a lot of white smoke coming out while idle, i have also purchased the Damond Motorsports restrictor bolt and want to install it.
Worth mentioning: Mazda stealership had already installed the new ventilation kit (at least what they told me) and now a lot of smoke comes out.
Mazda CX-7
 Old 04-15-2015, 11:24 AM   #66
Then it's too late and replace the turbo, is what they need to do.
 Old 04-15-2015, 01:21 PM   #67
ms33's Avatar
I agree, but then again, i would need help because i have a notion but i'd rather do it with someone experienced.
Mazda CX-7
 Old 04-15-2015, 01:33 PM   #68
Guessing warranty extension does not apply? Check local dealer.
 Old 04-15-2015, 01:35 PM   #69
ms33's Avatar
I had the Ventilation kit done via extended Mazda Warranty, which expired at 80k and now the car has 100k, dealer wants 4.5k for the work with a refurb K04, i bought the restrictor bolt in hopes that it would be easy to install and hopefully stop the smoke.
Mazda CX-7
 Old 04-15-2015, 01:37 PM   #70
The turbo itself is just $1300 or so. The rest is back breaking labor. Hit up locals in Nator new Jersey
 Old 04-15-2015, 01:39 PM   #71
ms33's Avatar
I know !!! They basically charge $115/hr !!! but then again, here in NJ/NYC area thats kinda what almost all dealers charge for labor... Thx Raider.
Mazda CX-7
 Old 08-19-2015, 09:03 PM   #72
Marculese's Avatar
Posts: 7   (View Stats)
Marculese will become famous soon enough
do you have to replace the gasket when you do this?
Marculese is offline   Reply With Quote
 Old 08-19-2015, 10:54 PM   #73
Ozynigma's Avatar
You shouldn't have to if you don't damage it. It is a thin metal gasket.
I have had my inlet manifold and EGR tube on and off a couple of times now with the same gasket going back on with no issues.
The Following User Says Thank You to Ozynigma For This Useful Post:
Raider (08-19-2015)
 Old 08-22-2015, 03:34 PM   #74
Marculese's Avatar
Ok, so it was a great success! However, the little red clip that secures the wiring harness on the throttle body up front shot off and is nowhere to be found. Any idea where I can buy that thing?
 Old 08-22-2015, 03:36 PM   #75
Dealer, maybe. But I would find it
 Old 08-22-2015, 03:46 PM   #76
Marculese's Avatar
I know I've been looking for a good hour, cant even hear it rattle around when I hit the bumper. O well, other than that it went great. Thanks guys!
 Old 05-11-2016, 09:54 AM   #77
kosmic's Avatar
Posts: 1   (View Stats)
kosmic is an unknown quantity at this point
The infamous code P0401 just popped out on my CX7 GT 2008 and I'm about to do the cleaning as per the guide. I was wondering, I have access to a ultrasonic cleaner, is there any part of the EGR valve that would get damaged in the US tank?
Thanks for your help
Kos
kosmic is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f128/how-clean-your-cx-7-egr-speed-63603/
p0401 cx 7 This thread Refback 08-11-2015 04:49 PM
How Many Quarts Of Oil Cx 7 2011 | Free Auto Repair Manuals Download This thread Refback 07-24-2014 10:09 PM
?????????? ???? : ???????, ??????? ??? ???????. - ????????????? ????????????? ???? Mazda CX-7, CX-9 - ???????? 3 This thread Refback 02-26-2014 04:27 AM
?????? ???????? - ????????????? ????????????? ???? Mazda CX-7, CX-9 This thread Refback 12-23-2013 08:51 PM
I'm a female who doesn't know shit about her Mazda. Help? : mazda This thread Refback 10-29-2013 11:12 AM
?????????? ???? : ???????, ??????? ??? ???????. - ????????????? ????????????? ???? Club-CX.ru - Mazda CX - ???????? 3 This thread Refback 06-03-2013 10:08 PM
How to: Clean your EGR (Speed 3 based instructions, but should help) | MCX7 Community Forums This thread Refback 05-11-2013 02:42 PM
Bumming out about my 08 CX7 | MCX7 Community Forums This thread Refback 04-18-2013 03:23 AM
DIY Replacement of EGR Valve_CX7 | MCX7 Community Forums This thread Refback 03-26-2013 05:42 PM
DIY Replacement of EGR Valve_CX7 | XenForo This thread Refback 03-16-2013 06:51 AM
DIY Replacement of EGR Valve_CX7 This thread Refback 01-12-2013 06:00 PM
?????? ???????? - ????????????? ????????????? ???? Club-CX.ru - Mazda CX This thread Refback 04-13-2012 03:09 PM
5earch This thread Refback 04-07-2012 03:37 PM
Bumming out about my 08 CX7 This thread Refback 08-25-2011 11:18 AM
How to: Clean your EGR (Speed 3 based instructions, but should help) This thread Refback 06-15-2011 06:39 PM
?????? • ???????? ???? - ?????? ? ???????????? Detroit Auto Show This thread Refback 01-17-2011 07:13 PM
How to: Clean your EGR (Speed 3 based instructions, but should help) This thread Refback 11-08-2010 09:23 AM
new break in instructions..... jracer Mazdaspeed3/6 General Discussion 4 06-24-2010 11:35 AM
Standback Installation Instructions, Please CosmicArkie MazdaSpeed 3/6 - ECU Computer Tuning 1 01-10-2010 09:31 AM
cpe tow plate instructions wisniaPl Custom Performance Engineering (cp-e.com) 3 06-28-2009 06:13 PM
Hamann introduces Bentley Continental GT Speed-based Imperator Haltech Automotive News 0 04-15-2009 12:30 PM
Page generated in 0.53113 seconds with 31 queries
