![]() Join Date: Dec 2010 Location: Australia
(Thread Starter) | Not Ranked : 0 score I just received my new CPe catback (only), and wonder if anyone has any tips for the install. One question I have is do I re-use the gasket between the stock muffler and the STANDARD mid section pipework..?? Thanks...!!! Last edited by Shazza; 04-27-2011 at 03:32 AM. |
![]() Join Date: Nov 2010 Location: toronto canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score i am guessing you are reffering to the quickpower pipe which deletes the second cat?or is it the axle back muffler.?. yes you need to reuse the gasket or you can use the high temp silicone stuff and then bolt the pieces together.. install is not too bad, a few wrenches and a floor jack or a friend to help and you are good to go
__________________ [SIGPIC][/SIGPIC][/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out. |
| Not Ranked : 0 score You can reuse it if it is not damaged. |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
| Not Ranked : 0 score Not to sound like a jerk, but the cat-back comes with instructions.
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
| The Following User Says Thank You to Grumpyjap For This Useful Post: | rfinkle2 (12-18-2012) |
(Thread Starter) | Not Ranked : 0 score The gasket is not mentioned in the destructions..... |
(Thread Starter) | Not Ranked : 0 score That was fun....... Certainly a different sound. Deeper, and a bit boomy. Time and carbon will settle it a bit. A nice long drive should help settling the sound down. I am pretty impressed by the fact is actually fitted without the need for "creative metalwork." I'll give it a week to settle on the hangers, and then check the alignments. |
![]() Join Date: Aug 2008 Location: Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Groaned at 81 Times in 33 Posts
__________________ Mike 2008.5 CWP Mazda CX-7 Sport FWD - hers 2008.5 CWP Mazdaspeed 3 GT - traded 2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold |
| The Following User Says Thank You to Silver Ecstasy For This Useful Post: | bertrand_CX_7 (04-29-2011) |
(Thread Starter) | Not Ranked : 0 score The exhaust is just audible at cruise speeds. Otherwise, it is probably a bit louder than what I anticipated. Funny thing is that my Partner is quite happy with it. Here you go. A couple of pics. is it normal for tips to sit that low and have the welds so visible? They sit ~1 inch below the bumper. |
(Thread Starter) | Not Ranked : 0 score A question for those that have the catback, and then added the Quick Power pipe. How much louder was it? |
(Thread Starter) | Not Ranked : 0 score I have to say, that after fitting this catback, my fuel economy has definitely become worse. There is no doubt as far as I am concerned. The economy for the same driving has gone from 13.9L/100km to 15L/100km. Cruising economy is shockingly worse than before. Now before you all tell me about "resetting" the ECU, that's been done by virtue of testing with a few different tunes. All return worse economy than before. I'm OK with having a nice exhaust note, and this one is really too LOUD, but when performance and economy suffer, I need to find out why. has anyone seen worse economy? |
| Re-installing Stock Exhaust | Silver Ecstasy | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 07-27-2010 09:41 PM |
| catback exhaust | axela2004 | 2010 MS3 - Turbo Induction | 18 | 05-08-2010 03:24 PM |
