> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 10-04-2013, 01:56 AM   #1
matte08's Avatar
Posts: 17   (View Stats)
matte08 can only hope to improve
Default Koolertron/Eonon with bose soundsystem connection
Hi everybody!
I've just installed my koolertron stereo in my Mazdaspeed3, the problem is that there is no sound coming through the speakers. I have bose sound system. This stereo is very similar Eonon as many other uses. How do you get sound from the speakers? Can any kind person help me out there ?
Mazda 3 gps - Mazda3 dvd - Mazda 3 navigation -indash mazda3 autoradio - HD screen ipod rds bluetooth handsfree
matte08 is offline   Reply With Quote
 Old 10-04-2013, 02:09 AM   #2
theurgy's Avatar
Posts: 2,580   (View Stats)
My guess is you don't have a 5 volt signal going to the amp remote wire on the Bose
 Old 10-04-2013, 02:14 AM   #3
matte08's Avatar
I have a "amplifier" cable on the koolertron stereo..
 Old 10-04-2013, 05:52 AM   #4
SC08Speed3's Avatar
Posts: 298   (View Stats)
SC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the worldSC08Speed3 is the leader of the world
The link that you attached says it will not work with Bose without some sort of modification!
08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K
SC08Speed3 is offline   Reply With Quote
 Old 10-04-2013, 06:13 AM   #5
matte08's Avatar
Yes I know, my question is how do you get the sound to work with koolertron stereo and bose sound system ..
 Old 10-04-2013, 10:33 AM   #6
blkspeed307's Avatar
Posts: 509   (View Stats)
blkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the world
U have to tap into the Mazda factory harness on the wire for the Bose amp to turn the amp on & off. U can use the remote on & off from head unit, but u will have to find the Bose amp on wire it's on the main white harness . It's on the top of the plug & it's white & blue .
Sorry man no pics of it.
blkspeed307 is offline   Reply With Quote
 Old 10-04-2013, 11:08 AM   #7
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
The most direct way to splice into bose with an aftermarket HU is to convert the amplified outputs (or RCA outputs) to line level using one of the adapters below:
Kanatechs Bose Adapter For Mazda
PAC MAZATO Retain Mazda Bose/Centerpoint Factory Sound
I'm not sure if the latter will work on your year due to Centerpoint processing. But the approach is the same as the Kanatechs adapter. Otherwise use an RCA cable, cut in half, and run from the HU to the speaker L/R inputs on the factory harness.
09 CWP MS3 GT
Ownership & Build Thread
 Old 10-04-2013, 11:15 AM   #8
theurgy's Avatar
Here is the pinout of the Bose harness.
TOP - In order from left to right *EDIT* These are the speaker outputs
grey w/ red stripe (FR-)
white w/ red stripe (FR+)
grey w/ black stripe (FL-)
white w/ black stripe (FL+)
solid grey (BR-)
solid white (BR+)
grey w/ white stripe (BL-)
white w/ purple stripe (BL+)
BOTTOM - In order from left to right *EDIT* These are the inputs to the amp
solid blue (remote turn on)
solid purple (FL+)
green w/ white paint (FL-)
solid red (FR+) *edit switched from FR-*
solid green (FR-) *edit switched from FR+*
brown w/ blue stripe (BL+)
yellow w/ blue stripe (BL-)
yellow w/ green stripe (BR+) *edit switched from BR-*
white w/ blue stripe (BR-) *edit switched from BR+*
Use one of those cable taps and connect the blue remote wire on your koolertron harness to this wire: solid blue (remote turn on)
Here's some more details:
http://d5102.wikispaces.com/FAQ#Bose
flappypaddles (03-07-2014)
 Old 10-04-2013, 11:16 AM   #9
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Look on the eonon website, they have a how to on splicing into the Bose system
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
The Following User Says Thank You to Playaj For This Useful Post:
 Old 10-04-2013, 11:20 AM   #10
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
how to install eonon d5102 with bose + aftermarket sub
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 10-04-2013, 12:56 PM   #11
matte08's Avatar
Okey guys!
thanks for all the answers! I want to do this in the easiest way! does not matter if I need to buy someone adapter for little money .. If I can make it work! So I would be incredibly grateful if someone could write a guide that works for my problem, Thank you all!
The Following User Says NO Thank You to matte08 For This Un-useful Post:
jack_hammer (10-05-2013)
 Old 10-04-2013, 01:15 PM   #12
matte08's Avatar
Okey guys!
 Old 10-05-2013, 03:21 PM   #13
matte08's Avatar
Please help!
 Old 10-05-2013, 04:02 PM   #14
theurgy's Avatar
FFS... we just gave you the damn answer.
 Old 10-05-2013, 04:50 PM   #15
matte08's Avatar
Its not easy to do withouts pics on it..
 Old 10-05-2013, 05:01 PM   #16
matte08's Avatar
So the only thing I have to do is run a cable from my koolertron stereo system (amplifier) remote to the solid blue (bose under the seat) (remote turn on)?
BOTTOM - In order from left to right * EDIT * These are the inputs to the amp
After that, the stereo work?
 Old 10-05-2013, 05:52 PM   #17
Playaj's Avatar
I haven't clicked the links that you were spoonfed but the one I told you to look up on eonons website has pics. Friggin check if your connections look the same and yes it is a write-up, no one here is gonna make you one
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
 Old 10-05-2013, 06:05 PM   #18
matte08's Avatar
Ok thanks, but I dont come into www.eonon.com currently ..
 Old 10-05-2013, 08:53 PM   #19
Groans: 549
click the thread i linked. read it. read the threads / websites linked in that thread.
follow them.
 Old 10-06-2013, 11:14 AM   #20
matte08's Avatar
Hello guys!
I take a pic of my 2 connectios under the seat..
So only a cable from my koolertron amplifiler to which connector on the picture ?
 Old 10-06-2013, 12:43 PM   #21
theurgy's Avatar
The wire you need to splice into doesn't even have to be at the amp. Look at the harness in your dash, off of that harness there is a blue with silver dot wire on pin #13 . Use a scotch lock type of wire tap:
 Old 10-06-2013, 01:30 PM   #22
matte08's Avatar
Okey, every guids says different things.. so a cable from the stereo amplifier to the dash.. With a blue wire ?
 Old 10-06-2013, 02:09 PM   #23
Playaj's Avatar
I'm done, this thread gave me cancer
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
The Following 4 Users Say Thank You to Playaj For This Useful Post:
jack_hammer (10-06-2013), LatinKraze (01-09-2014), theurgy (10-06-2013), veritas-truth (10-06-2013)
 Old 10-06-2013, 02:27 PM   #24
matte08's Avatar
come on and give me an answer on where the cables is connected instead to talk about someting so horrible as cancer. please tell me how many cables I'll and where it should be connect!
 Old 10-06-2013, 03:03 PM   #25
You have to splice white with blue wire on factory in dash Mazda harness it has a white plug u connect into aftermarket radio. No need to splice into Bose amp.
 Old 10-06-2013, 03:25 PM   #26
Groans: 549
Fuck you. I have the eonon installed in my gt with Bose. I wrote a fucking thread on how to do it. I linked to the info in my thread. My thread is all you need.
I linked my thread in here.
If you're too stupid to click that link and educate yourself, then you don't belong here.
Sent from my LG-MS770 using Tapatalk now Free
The Following 5 Users Say Thank You to jack_hammer For This Useful Post:
blkspeed307 (10-06-2013), Playaj (10-06-2013), theurgy (10-06-2013), veritas-truth (10-06-2013), |-Goku-| (10-25-2013)
 Old 10-24-2013, 12:17 PM   #27
matte08's Avatar
Thanks for all the good answers I got from you. One of you got cancer .. Where is the context here? I'll just inform you that your poor response did not help me a shit and you were also wrong. But thanks so much! Send a PM to me if you want to know how to connect your koolertron to the bose sound system.
jack_hammer (10-24-2013)
 Old 10-24-2013, 12:29 PM   #28
theurgy's Avatar
Was it any of the answers given in this thread?
 Old 10-24-2013, 12:31 PM   #29
matte08's Avatar
Not you man, the man who said he got cancer, and fuck you I am referring to.
 Old 10-24-2013, 12:53 PM   #30
theurgy's Avatar
Don't need to get all aggro dude... chill out.
 Old 10-24-2013, 10:14 PM   #31
Groans: 549
instead of being a hard headed whiny bitch brownie, why not just post what you learned? otherwise, disappear.
 Old 10-24-2013, 10:52 PM   #32
Playaj's Avatar
I am cancer free now! Maybe it's cuz I don't have the shitty Bose system in my car!
to be installed :
3 Port EBCS
Autotech internals
Corksport Pmm
Test pipe
how to install eonon d5102 with bose + aftermarket sub jack_hammer MazdaSpeed 3 - How-To's 3 08-18-2014 11:05 AM
Bose soundsystem>>>Thoughts? mikak88 CX-7 > Car Audio & Electronics 34 02-27-2014 07:24 AM
Koolertron head unit... Beck MazdaSpeed 3/6 - Car Audio & Electronics 4 10-03-2013 12:55 PM
Anyone intalled Eonon D5115Z, or D5163 in a Genpu with Tech/Bose Guyverspeed3 2010 MS3 - Car Audio & Electronics 1 09-12-2013 02:56 AM
Page generated in 0.49655 seconds with 27 queries
