![]() Join Date: Dec 2010 Location: Marietta, Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Last edited by Andy@Killshot; 05-11-2011 at 03:23 PM. |
| The Following 17 Users Say Thank You to Andy@Killshot For This Useful Post: | Alpha (01-28-2011), DaleNixon (01-28-2011), Fobio (02-03-2011), FreeFlyFreak (01-28-2011), Hoangy (03-25-2011), kilik2 (02-24-2011), kmac (03-23-2011), madvillain (02-08-2011), mike8748 (01-28-2011), MPSdriver (02-03-2011), mr_mazda329 (01-31-2011), MS3-a(sore)ASS-rex (01-28-2011), PunjabiPlaya (01-28-2011), rodrigo (01-28-2011), Scoobs (05-14-2012), speed23 (04-27-2011), triplejumper18 (03-28-2011) |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score Nice... become a vendor.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
(Thread Starter) | Not Ranked : 0 score How do I do that????? |
![]() Join Date: May 2008 Location: Jacksonville, Florida
Rep Power: 198 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 185
| Not Ranked : 0 score Nice work...
__________________ ![]() 07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold |
| The Following User Says Thank You to mike8748 For This Useful Post: | Andy@Killshot (01-28-2011) |
Groans: 60
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score Is that an NC?
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
| The Following User Says Thank You to DaleNixon For This Useful Post: | mr_mazda329 (01-31-2011) |
(Thread Starter) | Not Ranked : 0 score Yes |
Groans: 91
| Not Ranked : 0 score Looks like a bad ass build. I'm starting to like the NC more and more.
| The Following User Says NO Thank You to DaleNixon For This Un-useful Post: | mr_mazda329 (01-31-2011) |
Groans: 356
| Not Ranked : 0 score pm haltech, understand that this forum is unique, and kudos to you for showing engine bay shots that actually dont look so queer like
| The Following 3 Users Say Thank You to rodrigo For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Got it, I will PM him as soon as I get back to my office and off this G D iPhone, these things suck to do anything but look on. |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score That collector, you didnt happen to get it from ProFabrication did you?
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
(Thread Starter) | Not Ranked : 0 score No sir. I bought the form and bullets separate from my stainless distributor then assembled it as I built the header. Last edited by Andy@Killshot; 01-28-2011 at 03:58 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 356
| Not Ranked : 0 score i gotta say, if there was even the slightest chance one of my buttcheeks could even fit inside this miata i might drive it with an engine bay like that
| The Following 4 Users Say Thank You to rodrigo For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Thanks guys for the kind words, y'all are awesome! |
Groans: 1,143
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() | |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score Which EFR are you using?
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
(Thread Starter) | Not Ranked : 0 score 6758 |
| The Following User Says Thank You to Andy@Killshot For This Useful Post: | FreeFlyFreak (03-23-2011) |
| The Runner ![]() Join Date: Feb 2010 Location: Santa Ana, CA
Rep Power: 140 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 353
| Not Ranked : 0 score Good, well think the same until you screw up. Then youll get eaten alive. Just a forewarning haha, but welcome!
__________________ '09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links. WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV. |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score during my research, this seemed to be the ideal upgrade/GT30 replacement...is it considered a big(ger) turbo for the MX5? And would you say the 70xx would be more suited to the MS3? From your experience, how do the EFR's compare to the GT turbo's? Thanks for pics.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| Not Ranked : 0 score Damn i want an efr for my car so bad. Maybe I'll be the first ms3 with one... We'll have to see what the tax fairy brings me. Cuz i got lots to do before mine is bt worthy. Awesome build btw
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
| The Following User Says Thank You to Fatguy729 For This Useful Post: | Andy@Killshot (02-03-2011) |
(Thread Starter) | Not Ranked : 0 score I believe the 7064 EFR would work great on a MS3. As far as the GT vs. EFR in my opinion, there is no comparison. Keep posted I should have more pics soon and some dyno numbers in a week or two. |
| The Following User Says Thank You to Andy@Killshot For This Useful Post: | Fobio (02-03-2011) |
(Thread Starter) | Not Ranked : 0 score I really need a better camera, anyway here are some more pics. |
| The Following 2 Users Say Thank You to Andy@Killshot For This Useful Post: | Cataphract_40 (02-06-2011), DaleNixon (02-07-2011) |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
| Not Ranked : 0 score Ugh so much fucking win.
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
![]() | | #24 | ![]() |
Groans: 356
| Not Ranked : 0 score u actually might be the first non faggot driving a miata on this forum. come to think of it.... u are still a fag. but at least u will be flying to your boyfriends house nightly. congrats!!!
| The Following User Says Thank You to rodrigo For This Useful Post: | DaleNixon (02-07-2011) |
![]() | | #25 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Lenny... this gentleman is doing this work for a Miata owner out of a shop. I know reading is a task only a few people should be good at... but please try to apply yourself in this section of the forum.
| The Following 2 Users Say Thank You to Neverlift For This Useful Post: | CosmicArkie (03-27-2011), M4Nathan (02-10-2011) |
![]() | | #26 | ![]() |
Groans: 356
| Not Ranked : 0 score tony..... shouldnt u be at GMR instead of posting on here? andy and I are old friends, ive known him for almost a decade.
![]() | | #27 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Rodrigo, I should be, but alas... @ work. I pass the time by trolling this moderation staff like it were a treacherous canyon. PS... fsb isnt big enough.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry for not updating lately, the customer went ahead and approved the engine build. Miata block, Speed 6 crank (heavy mods made in house), proprietary rods and Speed6 pistons. Here is a pics of the rods, I will get some pics of the crank up when I am done with it. |
| The Following 4 Users Say Thank You to Andy@Killshot For This Useful Post: |
![]() | | #29 | ![]() |
Groans: 91
| Not Ranked : 0 score Damn that's a serious build!
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looking to make 500 at the crank, at least that is what I am shooting for. I will for sure post up the dyno and shit when I am done. |
![]() | | #31 | ![]() |
![]() Join Date: Sep 2009 Location: Dirty Dirty South
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 993
![]() | | #32 | ![]() |
Groans: 1,143
| Not Ranked : 0 score Dseries/Onecamonly members know their shit and build amazing cars.
![]() | | #33 | ![]() |
Groans: 356
how are aluminum rods these days for daily drivers?.... in my days we never had success running them on the street because they would always stretch over time and leave u with the piston knocking a valve eventually for drag racing they are the shit but running time between cool downs is minimal obviously. keep posting shit man, looks good. interesting build
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE | |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
Groans: 356
| Not Ranked : 0 score haha , makes sense. variable compression ftw !!! good work man
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() Thanks: 40
| Not Ranked : 0 score I like to get one of these! We need a vendor to step up and lay a set of cards on the table. Down time sucks, I am aiming but, I am not trigger happy. MS6 |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score hope to have some final results here in the next week. Break in tune is done, just have to get the time to get it tuned. |
| The Following User Says Thank You to Andy@Killshot For This Useful Post: | DaleNixon (05-11-2011) |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry it has been a minute, 18psi car blew through the clutch and kinda hovered around 330whp. currently having a clutch setup made so we can turn up the boost, the car as built to run 25 to 27 psi. I will tell yall something though, that son of a bitch will fly at 18psi. I rode around Road Atlanta with the owner WOW! that is all I have to say about that! |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f15/mx-5-efr-turbo-build-70812/ | ||||
| Stroked-n-turboed NC - Miata Turbo Forum - Turbo Kitten is watching you test compression. | This thread | Refback | 06-03-2015 02:28 PM | |
| Stroked-n-turboed NC - Miata Turbo Forum - Home to the Turbo Miata | This thread | Refback | 08-25-2011 07:01 PM | |
| GTK-450 turbo build | matgod | MazdaSpeed 3/6 - Big Turbo Builds | 18 | 09-09-2013 08:00 PM |
| essejkcamraw's big turbo build | essejkcamraw | MazdaSpeed 3/6 - Big Turbo Builds | 163 | 10-07-2011 10:13 AM |
| My big turbo build | Speedie6 | MazdaSpeed 3/6 - Big Turbo Builds | 4 | 12-09-2010 01:54 AM |
| Big turbo kit, build one or not? | ptperformance | Mazdaspeed3/6 General Discussion | 33 | 10-12-2008 02:55 PM |
