Autosports Area
> Drag Racing
Like Tree117Likes
 Old 03-02-2008, 03:49 PM   #1
littleloogy's Avatar
Posts: 4,005   (View Stats)
Default Official MS3 1/4 mile Times
Rules:
no bullshit talking, simply post your time with a link to the timeslip and list your mods in the correct format. With proof of timeslip you will be added to the list.
Any posts that do not have time slips or videos, will be deleted.
Use these abbriviations for mods:
I = Intake
IN - 3in Turbo Inlet
DP = Downpipe
EM = Exhaust Manifold
CBE = Cat Back Exhaust
MP = Midpipe
TBE = turbo back exhaust
CDFP = cam driven fuel pump upgrade
EMS = tuned
MBC = boost controller (specify spike and hold) ie: 18s15h
IC = Upgraded Intercooler
MM = upgraded motor mount
S = suspension such as springs coilover
T = turbo upgrade
W = Weight Reduction (spare and jack does not count)
DR = Drag Radials
SL = Slicks
N20 = Nitrous
MTH = Methanol
WB = Wot Box
GT30 = GT3071 and 6R Turbo
BSD = Balance Shaft Delte
Please post time in the following format:
SN - 60ft, 1/8th(et and mph), 1/4, (et and mph) (Mods)ASL (feet above sea level)
Here are the time frames:
9 second club:
Why you not 8s?
10 second club:
mazdafreak; 10.35@140.86 (I, IN, TBE, CDFP, EMS Freektuned, BM, PTE6266, SL, PI) 626 ASL da 10ft GENWON
RE-ACTIONENGSPEED3 - 1.644 , 6.953@104.97 , 10.625@136.65 (forged,slicks,pte6466,meth,30psi)AWD converted GENWON
LumberJack 1.632, 4.633, 6.976@103.32 8.983, 10.629@137.78, 10.629@137.78 PI, 6266, DA=1885 Freekbuilt/Freektune Fontana, CA AutoClub Dragway 2/20/16
SnakeDoc 1.80 60FT, 7.15@105 1/8th 10.88@132 1/4 mile Mods, pte5858, Self built block, meth and 24.5x8.5in slicks GENONE
Justin@Freektune; 1.761, 7.246@102.60, 10.931@137.39. (I, IN,—TBE,—CDFP, EMS Freektuned, BM freekbuilt, PTE6062, SL, 6thport, MTH), 81ft ASL, GENPU
11 second club:
Justin@Freektune; 1.619, 7.169@101.29, 11.009@132.92 (I, IN, TBE, CDFP, EMS Freektuned, BM freekbuilt, PTE6062, SL, MTH), 150ft ASL, da 1200 GENPU
Lumberjack - 1.658, 7.277@99.08, 11.075@133.90 (PI, 6266, Freekbuilt/Freektune ftmfw) GENPU
Realgib3 - 1.815, 7.562@97.22, 11.32@130.54 (Self built motor, 6466, 36 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON
HOCKEYNUBE- 1.829, 7.564@101.68, 11.436@128.09 (I,IN,TBE,CDFP,EMS @Realgib3; ),IC,MM,S,T(PTE5862),DR(Hoosier QTPs),MTH,WB,BM(self built)) 600 ASL GENPU
JCMS07 - 1.729, 7.449@94.91, 11.491@115.94 (I,IN,TBE,CDFP,EMS,IC,MM,Built Motor, GTX3076r,S,W,SL,MTH) GENWON
DevinS1.849 60ft 7.651 1/8 @ 93.50mph 11.681 @ 124.18 built longblock,GTX3582r, 6 Port, Hoosier QTP, 50/50 E85 Freektuned.2010 GenPu
NJSPEED3 - 1.899, 7.695@96.6, 11.682@117.17(I,EM,T,TBE,MBC 29psi,5th port 50% e85 mix, HTA3586,MM,S,SL) 552ft ASL DA 386 GENWON
Driver311 - 1.71, 7.589@94.14, 11.73@119.85, stock motor, slicks, gtx3071 22psi e85 mix GENWON
Etipp98 - 1.83, 7.74@96.03, 11.73@118.17 (Stock motor, 6266, 30 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON
Papasmurf - 60ft Broken, 7.697@94.953, 11.776@123.161 (GT3582, supporting mods, Port injection 50/50 e85, Slicks/Skinnies) 5500 ft. ASL GENPU
wetzms3 - 1.942, 7.724@95.90, 11.781@122.46 (Sluntworks motor, 3076, meth, QTPs and bags) GENPU
doubleflusher - 1.755, 7.7@93.86, 11.85@119.69, built motor, slicks, hta3582r 30psi meth GENWON
Etipp98 - 1.828, 7.808@92.63, 11.89@122.72 (Stock motor, 6266, 30 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON
801ms3 - 1.85, 11.93@120, stock motor, slicks, gt3071, 26psi falling to 22psi, meth GENWON
DevinS-1.905, 7.917 @ 90.81, 11.974 @ 123.34 Fontana, CA Dragway, 1121ASL2010 GenPu
2010 GenPu Overspeed Motorsports built shortblock,GTX3582r, 6 Port, Hoosier QTP, 50/50 E85 Freektuned.
Dturboman - 1.96, 7.901@96.85, 11.95@123.18, stock motor, slicks, gt3071r 26psi meth GENWON
MZRSPEED - 1.688 7.676@91.71 11.977@113.85 (Stock K04, stock block, I, TBE, CDFP, EMS, E85, MM, W, SL) 106 asl GENPU
12 second club:
Snyeed -1.876 60ft, 7.818@92.33, 12.037@117.20 (I, IN, TBE, EM, CDFP, EMS, IC, MM, S, T, SL, MTH, GT3071, 25psi) 4500ft ASL GENWON
masterbaiter - 1.8839, (7.89@ 92.55), (12.09@ 118.73)I,IN,DP, EM, TBE, CDFP, EMS, IC, MM, S, T,SL,WB, GTX3071, BSD 5500 ASL GENWON
Darkstar5440 - 60' timer wasnt working, 1/8 - 8.08@92.92, 1/4 - 12.127 @ 125.52 built engine, 5858, meth, drag radials, 20' ASL GENPU
SilverMS307 - 60' 1.889, 7.934 @ 92.65, 12.183 @115.48 (BNR S3, fully bolted, meth, 25 psi, FREEKtune, stock motor, stock clutch, stock suspension) GENWON
JCMS07 - 1.915, 8.008@89.65, 12.188@111.52 (I,IN,TBE,CDFP,EMS,IC,MM,BNR Stage2,S,SL,MTH) 365 ASL GENWON
2XS - 1.843, 7.944@89.2, 12.316@111.79, (I, TBE, EM, IC, S, SL, MM, GT28/76r @19PSI) GENWON
Etipp98 - 2.005, 8.13@91.49, 12.22@122.41 (Stock motor, 6266, 28 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON
Justin@freektune- 2.089, 8.247@91.47, 12.334@123.52 (built motor, gtx3076, meth, TBE, FMIC) GENPU
jkowalski - 2.188, 8.236@92.9, 12.404@120.09 gt3582 supporting mods wmi GENPU
pharaoh313 - 1.971 60ft 8.147@88.45 12.493@113.59 (Stock K04,MM,HpFp,I,TBE,E85+M ETS,WR,SL) 151ft ASL 2193DA 81Deg GENPU
dmeadors 60 - 1.8 1/8th - 8.1 @ 86.6 1/4th - 12.56 @ 110.5 07 gen1 Slicks, bnrs3, I, IN, TBE, IC, MM, E85, EMS by Rob 1201 ASL GENONE
kritz - 2.076, 8.236@89.42, 12.586@112.46 ( 60' 50% e85, tbe, fmic, cdfp, slicks, c.o., tbi) GENPU
mxlplx71 - 2.04, 8.315@90.06, 12.637@113.75 (built, bolted, freeked, drs, e30, bnr s2) GENWON
bewsted - 1.933, 8.245@88.09, 12.639@112.27 (??) GENPU GENPU
9900rpm - 1.960, 8.182@87.54, 12.653@109.90 (I, TBE, CDFP, EMS, IC, MM, SL, MTH) 33 ft. ASL GENPU
mrdouble99 - 1.918, 8.193@86.49, 12.737@108.51 (I, other unkown mods) GENWON
86AmishMs3 - 2.201, 8.567@92.55, 12.820@113.8, (gt3076, E85 mix, 23 psi, street tires), 550ASL GENWON
Amp1623 - 12.82 @ 107, 1.79 60ft, Stock Block, Stock K04, on 255/50r16 Mickey Thompson ET street radials
TRU-BOOST - 1.90, 8.28@86.36, 12.829@107.90 (I/DP/MP/CDFP/MBC@19PSI/T/MM/EMS/SL) GENWON
Luke@Corksport - 2.0 60ft, 8.3 in the 1/8 @ 88.85mph, 12.835 @ 110.35 in the 1/4. I, IN, TBE, CDFP, IC, MM, SL, E85, KO4, EMS by Ryan Martin @ Purple Drank Tuning. GENWON
alaskazero - 2.4554, 8.6371 @91.79, 12.8408 @116.38, (Drag radials, Built motor, GTX3071, Freek tune) GENPU
Smelson - 2.069, 8.384@88.44, 12.842@109.89 ( I/IN, DP, CDFP, EMS, IC, MM, 35%e85) ASL 460f GENPU
atvfreek - 2.239, 8.660@88.67, 12.903@117.33 I, TBE, MTH, BNR S3 500ft ASL GENPU
Laloosh - 2.019, 8.467@ 87.69, 12.906@111.14 (I/TBE/18psi/CDFP/S/MM) 320ASL GENWON
MS3inDC - 1.869, 8.32@85.89, 12.948@109.00 (I, DP, MP, EMS RichTune 93 oct, IC, MM, SL) 18 ASL GENONE
dmeadors 60 - 2.163 1/8th - 8.519 @ 85.96mph 1/4th - 12.95 @ 112.82mph Slicks, bnrs3, I, IN, TBE, IC, MM, E85, EMS by Rob 1201 ASL GENONE
Rodrigo - 1.888, 8.394@85.03mph , 12.968 @ 108.71 mph (mods everything) 365 ASL GENWON
Livingframe - 1.983/8.442@85.47/12.988@107.85 GENPU
13 Second Club:
@moo_cow1216; 2.141, 8.582@84.79, 13.000@112.47 (Cs turbo, 3.5in I, tbe, rmm, cdfp, ems purple drank on 93, fmic, mbc @23s23h) asl
ArcticSpeed3 - 1.98, 8.48@84.27, 13.09@105.88 (I,DP,MP,CDFP,EMS,EBCS,IC,IN,MM,DR) 75ft. ASL GENPU
sg1320 - 2.158, 8.55@86.2, 13.099 @ 107.65 mph (I, IN, TBE, CDFP, EMS, IC, MM) DA 450' GENPU
JgamB - 2.104 60', 8.736@87.11, 13.107@117.12 (I, TBE, IC, E85, BNR S3) GENPU
SharkDiver - 2.042,8.5@85.93mph, 13.12@109.51mph (MM,FMIC,EMS,DP,MP,I,EM,BSD,stock tires) GENWON
N2o - 1.897, 8.468@83.86, 13.143@106.07 (I,TBE,TIP,HPFP,IC,S,FreekTuned 94 oct,RMM,S,SL) 270 ASL GENPU
jhallems3 - 2.1375, 8.6202 @ 84.84, 13.1473 @ 109.94 (I, DP, CBE, CDFP, RMM, ko4 Freektuned and street tires) 910' ASL GENPU
MGMSIII - 1.91, 8.41@82.34, 13.16@103.8, (I,DP,MM,S,DR) 10' ASL GENWON
Ziggo - 2.11, 8.33@87.55, 13.163@111.1, (bnr stg3, street tires) GENWON
Allmotor95pgt - 1.866-60ft, 8.463@82.63, 13.177@104.40, knn dropin filter, tmic, gutted 2nd cat, mm, dr, w, rubber rear spring blockers, boost tubes, 126asl. (Stock tune) GENWON
Enki - 2.421, 8.961 @ 88.62, 13.189 @ 120.16, (I - IN - EM - TBE - CDFP - EMS - IC - MM - S - T EFR 6758 @ 24 psi - BSD - MTH - E85), 3079 ASL - DA 6383 GENWON
08cosmic3 - 2.193 8.73@87.38 13.196@110.84 (bolt on 20% e85) 450asl GENWON
UDNTKNW - 60' 2.09, 1/8 8.60 @ 85.54mph, 13.19 @ 106, (I, IN, TBE, CDFP. MM, EMS) ASL 3079' GENWON
Cevaes_64 - 2.0, 8.71@82 13.2@108.80 EMS with 4GLs of E-85, I, DP, ITV-22, MM, CD GENPU
BigJimMs3 - 2.21, 8.76@85.89, 13.201 @108.23 (I, DP, MP, CDFP, EMS, IC, MM,3gal E85mix) GENPU
Payne Racing 67 - 2.170, 8.657@85.18, 13.237@107.45 (I, DP, CDFP, EMS, IC) GENPU
snailD - 2.21, 8.89 @ 87.78, 13.24 @ 113.65 (GTX2867, e85, 4500 ASL) GENPU
JacksonMS30 - 2.18, 8.73@83.99, 13.31@106.42,(I, DP, MP, CDFP, MTH, S, MM) GENWON
JNR5005 - 2.206, 8.762 @ 85.05, 13.330 @ 107.98, (I, Cobb AP LC/FFS) 330' ASL GENWON
Slash - 2.13, 8.72@83.79, 13.39@103.35 (I, IN, CDFP, IC, EMS, 1250FT ASL) GENPU
sleeper3 - 2.234, 8.742@84.18, 13.365@106.75 (I, IN, IC, MM) GENWON
08cosmic3 - 2.154, 8.773 @ 84.91, 13.392 @ 107.15 (I,IN,IC,EMS,MP,MM) 450'ASL GENWON
SLS MS3 - 2.060, 8.691@83.54, 13.394@104.33 (I, DBE) GENWON
White'swhitemps - 2.1929 60ft, 8.8499@85.72, 13.4471@108.14. I,IN,DP,TBE,EMS,IC(top mount),MM,S GENPU
racebitz - 2.261,8.838@84.94, 13.460@106.30 (I,CBE,2.5"IN,FMIC,MM) GENWON
Chaser27 - 2.063, 8.839 @ 83.24, 13.461 @ 106.39 (I, DP, CDFP, EMS (Self-tuned), FMIC, RMM, W) GENPU
loopymps-2.164, 8.881 @82.74, 13.485@108.84 MPH (DP, IC, EMS, HPFP, MM, IN, METH, DR) GENPU
aaronc7 - 2.239, 8.890@83.56, 13.506@106.30 (I/TBE/FMIC/MM/EMS/METH) 55' ASL GENWON
Skierdood - 2.1 60', 8.87 @83.62 660' 13.510 @106.14 1/4 (I, TIP, TP, CDFP, EMS, MM, 3/9 E85) 250' ASL GENWON
Spec - 2.221, 8.941@84.48 13.518 @ 108.95 (e85, IN, CDFP, TP, EMS, 199FT ASL) GENPU
mswierse - 2.21, 8.36@81.96, 13.58@106 (I, RMM, CDFP, EMS) GENPU
Andrewbox - 2.04/13.6 @ 104 full weight, 3/4 tank Mods: IN, TBE, CDFP, EMS, IC, MBC, MM, S GENPU
Breeze10 - 2.365, 9.06/84.14, 13.61/108.77 ASL 1180(I,IN,CBE,MP,CDFP,EMS,IC,MM,S,25%E85) GENPU
Jsn Rob - 2.29, 8.94@84.27, 13.61@107.42, RMM,DP,TP,SRI,LS,WOT BOX,BPV GENWON
Eazy - 2.153, 8.876@81.27, 13.623@103.47, (I, IN, MM, S, DP, MP, CDFP, MBC@19, BSD, DR) 29' ASL GENWON
spd frk - 2.138, 8.900@81.02, 13.624@105.33 (I, IN, DP, CBE, MM, Cobb AP LC/FFS) GENWON
Nataphen - 2.249, 8.949@82.30, 13.638@101.67 (I, CBE, MP, EMS, IC, MM) GENPU
Gr8Speed - 2.2668, 8.9417, 13.6458 @ 104 (FULL BOLT, METH, 50/50e85, DR) GENWON
Ray Danger 2020 - 60'=2.2645; 8.9648@83.66; 13.6722@105.53; ASL=1180' (I, TBE, CDFP, EMS, IC, MM, S, E85 mix 5gal/tank, Finkle Tuned) GENPU
dsmluck - 2.383, 9.212@88.37, 13.688@111.78 (will update mods later, gt3076r @25 psi) GENWON
kashbringer; -2.30,9.16@83.35,13.71@110.46,(I/IN3.5",TBE,CDFP,EMS,IC,MM,25%E85,Stock tires) ASL 199ft GENPU
240mazspd3- 2.143, 8.94@80.94, 13.714@ 102.43 (I, MM , S BOV...pre AP & TP) GENWON
baluums3 - 2.25 9.0998 @ 82.77 13.7656 @ 105.49 (CAI, MM, DP, RP, FMIC, CDFP, Meth 50/50) ASL 600 GENWON
Daytripper79- 2.219, 9.038 @ 82.37, 13.765 @ 103.46 (I,MM,TBE) GENWON
Blackms3_71 - 2.380 60ft 9.129@9.465,13.768@106.45 (I,in,dp,mp,cbe,cdfp,ic,mm,s) GENWON
jtspells - 2.253, 9.028@83.97, 13.798@103.67 (I) GENWON
Focused - 2.319, 9.102@81.84, 13.8@102.67 (I/MM) GENWON
BLACKMS3 - 2.287, 9.063@82.16, 13.802@104.16 (I, MP, MM, W) 200 ASL? GENWON
ArcticSpeed3 - 2.04., 8.92@79.10, 13.87@99.13 (I, MM, DR) 75ft. ASL GENPU
k_skidz97 - 2.186, 9.121@81.96, 13.889@102.16 (I,MP) GENPU
EnzoR - 2.163, 9.048@78.61, 13.898@101.38, (I, TIP, IC, DP, TP, CBE) ASL 465ft GENPU
alexwlwsn - 2.309, 9.127@81.38, 13.909@101.38 (I/IN/CDFP/MM/S) 350ft ASL GENWON
Jarods7920 - 2.139, 9.034@79.93, 13.916@100.7 (Bone Stock) 410' ASL GENWON
DingoDave - 2.2179, 9.1097@80.65, 13.9181@101.63 (I, IN, MM) 150' ASL GENPU
Scatt Nasty - 13.940 @ 106, 2.39 60ft, 9.2 1/8 @ 81.9 ( I,IN,TBE,CDFP,EMS,IC,MM,S,MTH ) 3075' ASL GENWON
opt_ms3 - 2.362, 9.128@79.89, 13.955@100.48, (I,MM, DP, MP catted, CDFP) 204ft ASL GENWON
reddeerspeed3 - 2.209, 9.06 @ 79.75, 13.96 @ 101.51 (I, IN, TBE, CDFP, MBC@15psi, MMx3) 2373' ASL GENWON
ms3077 - 2.07, 9.033@ 80.17, 13.97@99.92 (I,MM) GENWON
phillyb - 2.385, 9.203 @ 81.48, 13.97 @ 104.23 (I, DP, IC, MM) GENWON
Frequentlfyer - 60' - 2.364 1/8 - 9.323 @ 80.32MPH 1/4 - 13.991 @ 107.35MPH Spicytune VP 109 unleaded dp HPFP internals SRI TMIC GENONE
14 Second Club:
Super_X - 2.251, 9.135@79.99mph, 14.012@99.37mph (Stock) GENWON
clos561 - 2.28, 9.14@79.9, 14.03@100.26 (I) GENWON
Deek - 2.28, 14.05@98.25 (in/tip/fp/ap/tp) GENWON
Jesse MS3GT - 2.278, 9.156@78.58mph, 14.058@99.40mph, (I/MM) 740' ASL GENWON
PoMan - 2.38, 9.32@81.48, 14.06@105.14 (I, IN, TBE, CDFP, EMS, MM) 600' GENWON
EuroTuneR - 2.198, 9.210 @ 80.34, 14.090 @ 96.99 (Stock) 50ASL GENWON
jam_asian85 - 2.302, 9.206 @ 79.94, 14.099 @ 99.43 (I/DP/MP/MM) GENWON
joeylow - 14.11 @ 97mph (MM/S) GENWON
monkey.bones.007 - 2.186, 9.268@81.66, 1/4, 14.185@100.85 (I, MP, CDFP, IC, MM,S, STRATIFIED OTS+) 715.2 GENPU
ill_eagle94 - 2.390, 9.361@79.27, 14.194@102.16 (I/DP/MP/MM) 90' ASL GENWON
RonTonkinMazda - 2.435,9.466@82.95 ,14.206 @104.38 (I/IN/IC/MP/CBE/20psi) GENWON
Paul - 2.312, 9.376@79.25, 14.209@102 (I, DP, CBE, MP, TBE, CDFP, EMS, IC, MM, S) 3850ft. ASL (E85/91 1/3mix) GENPU
MidwestSpeed3 - 2.304, 9.349@78.05,14.279@100.17 (I/MM) GENWON
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) GENWON
stephano18 - 2.3580, 8.8191@?, 14.3093@98.45 (I/MM/MP/CBE) 2200ASL GENWON
ccann - 2.512, 9.283@80.48, 14.314@94.83 (I/IC/MM/EMS) GENWON
robh - 2.352, 9.369@78.67, 14.325@97.41, I CBE 900 ASL GENWON
Sensei - 2.393, 9.509@77.01mph, 14.370@102.92mph, (I/TIP/CDFP/TP/FMIC/RMM/PMM/EMS) 90' ASL 469' DA GENWON
5doorsoffury - 2.210, 9.470@76.38, 14.380@100.44 (IN,MP,EMS,CDFP) 500ft asl GENPU
Doc_sean 2.404,1/8th -not available,1/4 (14.381@ 101.02 mph) (I,DP,EMS-Hypertech,MM,)170 ASL GENWON
Darth_Nuruodo - 2.61, 9.68 @ 80.1, 14.39 @ 107.7 (3" I/IN, TP, EMS, E40 (50% E), CDFP, MM)Asl 199 GENPU
Redninjagirl - 2.32, 9.447@77.02, 14.407@100.55, bone stock, 720 ASL GENPU
BigJimMs3 - 2.290, 9.487@76.22, 14.408@101.52 (??) GENPU
kingpin748 - 2.312, 9.487@77.78, 14.469@101.62 (I/TBE/IC/MM/WB) 2100ASL GENWON
Babyface13 - 2.36, 9.50@76.89, 14.47@99.71 GENWON
Plaqyero02- 1/4 (14.563 @103.45)(i,mm)
2k4_8 - 2.3999, 9.6337@77.60, 14.5671@103.26 mph 4860asl w/6783 Da (I, DP, EMS, MM) GENPU
Texasboy21 - 2.1994, 9.5667@75.52mph, 14.6258@99.29mph, I, 600' ASL GENPU
cbusby - 2.325, 9.529 @ 78.55, 14.634 @ 96.17, (I/MM/S) 25' ASL GENWON
KaisorSoze - 2.543, 9.676 @ 78.86, 14.672 @ 98.37, (MM) 2100' ASL GENWON
Snotrocket - 2.353, 9.605@77.07, 14.673@98.93, (I, IN, DP, CBE, MP) ASL 260ft GENPU
2010MS3! - 2.587, 9.715@77.82, 14.721@95.80, 14ft ASL GENPU
akabickle - 2.370, 9.610@76.86, 14.753@96.21, (I, MM) ASL 700ft GENPU
CaptObvious75 -.944, 2.26, 9.7 @ 73.0mph, 14.8 @ 94.5mph Stock GENPU
Once you post your time in the correct format with a link to the time slip you will be added to the list.
ALL TIMES ON THIS LIST HAVE BEEN VERIFIED
The Following 16 Users Say Thank You to littleloogy For This Useful Post:
aaronc7 (10-13-2008), dantes5823 (04-11-2013), Eazy (08-12-2008), Enki (10-12-2014), jlarson1983 (03-25-2008), MazdaMan13 (06-26-2008), MS3inDC (04-15-2013), NJSPEED3 (01-08-2013), Payne Racing 67 (10-07-2012), rigor (06-08-2013), Scatt Nasty (07-25-2009), SgtP (09-14-2008), stang9779 (11-28-2011), WetzMS3 (11-09-2015), ZetaDrift (10-08-2015), [R]usty (09-23-2014)
 Old 03-04-2008, 04:01 PM   #2
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
Speeed3 - 2.326, 9.537@75.68, 14.613@96.96 (I,MM)
Eazy is offline   Reply With Quote
The Following User Says Thank You to Eazy For This Useful Post:
 Old 03-24-2008, 07:57 AM   #3
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
BlackMS3 - 2.213, 9.230@77.61 (I/MP/MM)
60ft: 2.213
Time: 9.230@77.61
BlackMS3 is offline   Reply With Quote
The Following User Says Thank You to BlackMS3 For This Useful Post:
 Old 04-26-2008, 09:20 PM   #4
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
full interior, spare tire, stock tire pressure, only mod is a mazdaspeed cbe this was at raceway park in englishtown, NJ
the 12.18 car was a subaru legacy that at its previous run smoked all four tires and the 10.19 car was a fully built muscle car
MazdaMan13 is offline   Reply With Quote
 Old 06-12-2008, 05:39 PM   #5
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
UDNTKNW - 2.24, 9.01@? (no mph recorded), 13.84@99.95 (I), 1243' ASL
 Old 07-21-2008, 10:24 AM   #6
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
all this time i forgot to post my most recnt time in here.....duh !!
here you go..
lets see if i can list all my mods
I/DP/MP/CDFP/MBC @ 19PSI/T/MM/EM/SL..... i think thats all the important stuff !!
i am going again this friday night with the WOT box this time. hopefully i can do a little better. i will be running against my cousins new gt500 mustang.
TRU-BOOST is offline   Reply With Quote
 Old 08-01-2008, 02:18 PM   #7
MSF Punished Member
EuroTuneR's Avatar
Posts: 22   (View Stats)
EuroTuneR is an unknown quantity at this point
EuroTuneR is offline   Reply With Quote
 Old 08-12-2008, 10:14 AM   #8
Eazy's Avatar
Improved my previous time by quite a bit:
Speeed3 - 2.196, 9.088@81.42, 13.900@102.21, (I, MM, S) 29' ASL
#1123E
 Old 08-13-2008, 10:08 AM   #9
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
SharkDiver 2.23,8.94@83.64,13.62@106.91..MM,FMIC,DP,MP,MSCAI, EMS
It looks like I have the 2nd highest trap speed so far or maybe 3rd after Tru-boost gets listed,But he is on slicks...WooHooo
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 08-24-2008, 09:05 PM   #10
SharkDiver's Avatar
SharkDiver 2.221,8.93@83.80,13.610@107.17mph..MM,FMIC,DP,MP,M SCAI,EMS
Car 25
 Old 08-31-2008, 03:52 AM   #11
stefano18's Avatar
Posts: 8   (View Stats)
stefano18 is an unknown quantity at this point
2.3580, 8.8191, 14.3093 @98.45 (I/MM/MP/CBE) 2200ASL
stefano18 is offline   Reply With Quote
 Old 10-05-2008, 08:29 PM   #12
SharkDiver's Avatar
SharkDiver 2.01/8.63@82.87..13.31@105.35.MM,FMIC,DP,MP,cobb sri,EMS
Car 51,My brothers Mach1 is car 52...
My highest trap speed for the day was 107.69mph..
 Old 01-29-2009, 06:56 PM   #13
2007blkmsp3's Avatar
Posts: 36   (View Stats)
2007blkmsp3 has a spectacular aura about2007blkmsp3 has a spectacular aura about
Mods testpipe
2007blkmsp3 is offline   Reply With Quote
 Old 03-08-2009, 12:43 PM   #14
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Jarods7920 60ft 2.139 1/8 9.034 79.93 1/4 @13.916 @100.7 Bone Stock ASL 410ft
 Old 03-08-2009, 01:39 PM   #15
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
phillyb, 2.385, 9.203 @ 81.48, 13.97 @ 104.23 i/dp/ic/mm/
 Old 04-09-2009, 05:21 AM   #16
racebitz's Avatar
Posts: 48   (View Stats)
racebitz is just really niceracebitz is just really niceracebitz is just really niceracebitz is just really niceracebitz is just really nice
racebitz is offline   Reply With Quote
 Old 06-06-2009, 10:34 AM   #17
BlackMS3's Avatar
Best to date - 13.802@104.16 (I/MP/MM/W)
 Old 07-16-2009, 05:01 PM   #18
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
I, MM, S, BOV
13.71 @ 102.4(pre AP and TP)
60': 2.143
1/8: 8.948
2015 Mazda 6
 Old 07-22-2009, 09:24 PM   #19
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
reddeerspeed3 - 2.376, 9.26 @ 79.86, 14.07 @ 102.48 (I, IN, TBE, CDFP, MBC@15psi, MMx3) 2373' ASL
reddeerspeed3 is offline   Reply With Quote
 Old 07-25-2009, 10:36 AM   #20
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
Scatt Nasty I,IN,TBE,CDFP,EMS,IC,MM,S,MTH
13.940 @ 106, 2.39 60ft, 9.2 1/8 @ 81.9 3075' ASL
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
The Following User Says Thank You to Scatt Nasty For This Useful Post:
phillyb (08-01-2009)
 Old 07-27-2009, 11:44 AM   #21
Eazy's Avatar
Eazy - 2.131, 9.028@82.26, 13.757@104.62, (I, MM, S, DP, MP, CDFP, MBC@19) 29' ASL
 Old 07-27-2009, 07:56 PM   #22
cbusby's Avatar
Posts: 156   (View Stats)
cbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond repute
Groaned at 10 Times in 1 Post
First time ever racing...
2008 Mazdaspeed3 / Bolted (mostly) / Parting out.
cbusby is offline   Reply With Quote
 Old 07-28-2009, 08:15 AM   #23
baluums3's Avatar
Posts: 51   (View Stats)
baluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond reputebaluums3 has a reputation beyond repute
Default San Antonio Raceway 7/26/09
baluums3 is offline   Reply With Quote
 Old 08-01-2009, 11:10 PM   #24
08cosmic3's Avatar
Posts: 2,920   (View Stats)
Beech Bend Dragway, Bowling Green KY. 8-1-09. 80 degrees and humid, stock tires w/27,000 miles
Cobb AP Stg1+sf93v104
08cosmic3 - 2.209, 9.069 @ 82.10, 13.835 @ 103.58 (I,IN,EMS,MP,MM) 450'ASL
 Old 08-12-2009, 10:27 AM   #25
spd frk's Avatar
Posts: 74   (View Stats)
spd frk is just really nicespd frk is just really nicespd frk is just really nicespd frk is just really nice
60' 2.138 - 1/8 8.900 - 1/8MPH 81.02 - 1/4 13.624 - MPH 105.33 - ASL - I, IN, DP, CBE, MM, Cobb AP LC/FFS
Again here is the timeslip Car #986 along with my backup run of 13.67
2008.5 Black Mica MS3 - Cobb AP, RPMC Inlet, CPE TBE, CPE CAI, SU Mount, HKS SSQV, Autometer boost guage 1/4mile slut
spd frk is offline   Reply With Quote
 Old 08-24-2009, 05:28 PM   #26
Eazy's Avatar
Eazy - 2.153, 8.876@81.27, 13.623@103.47, (I, MM, S, DP, MP, CDFP, MBC@19, DR) 29' ASL
 Old 08-29-2009, 07:06 PM   #27
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
opt_ms3 - 2.362, 9.128@79.89, 13.955 100.48, (I,MM, DP, MP catted, CDFP) 204ft ASL
'08 CWP MS3 w/ T3 3071r
 Old 08-30-2009, 08:36 PM   #28
SharkDiver's Avatar
Default Went to the drag strip
hey all,
Well I went back to the strip for the first time since my build.Im still using the stock tires up front since I dont have any slicks yet. I didnt do to bad but I did really want to get into the 12s but the track conditions today were bad for everyone. I ran a best time of 13.12 @ 109.51. I will be adding a video of the race and the datalog from it aswell. I datalogged all 5 runs today and incar video taped them. Also the temp outside was about 73F and we are about 600' above sea level.This puts me back at the top of the 13 class again....
Car #85
In this video I did a 13.71@109.18..I messup and put the wrong video up.I missed 2nd gear here also.
In this video I did a 13.12@109.51mph.. A civic got me again..
The Following User Says Thank You to SharkDiver For This Useful Post:
felt (01-10-2010)
 Old 09-08-2009, 05:29 AM   #29
2XS (From OZ)'s Avatar
Posts: 21   (View Stats)
2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future2XS (From OZ) has a brilliant future
Finally found a thread I like.
I ran at the Jamboree (here in Australia) and won the Street Compact class (108 cars total)
My best time of the day 13.06@106mph
2XS - 1.871, 8.394 @81.87, 13.06 @106.8 (I, TBE, EM, IC, S, SL, WB, MM, @16PSI)
2XS (From OZ) is offline   Reply With Quote
The Following 2 Users Say Thank You to 2XS (From OZ) For This Useful Post:
802MS3 (09-08-2009), ms3077 (09-21-2009)
 Old 09-26-2009, 09:52 PM   #30
slowly learning to launch...
 Old 10-24-2009, 06:55 PM   #31
08cosmic3's Avatar
Running Stg1+SF93v105 FMIC.
Attached is a log of the run. My AF's are too lean and I need help with ATR to add fuel. I spun 1st gear badly and my 60 and the data log shows it. I was able to get only two passes at the track, very crowded. With practise I believe I can get 13.5 with my set up. Please update me on the list.
datalog3.csv
08cosmic3 - 2.320, 9.058 @ 84.43, 13.685 @ 106.64 (I,IN,IC,EMS,MP,MM) 450'ASL
 Old 11-06-2009, 08:18 PM   #32
JNR5005's Avatar
Posts: 869   (View Stats)
JNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the world
Groaned at 9 Times in 9 Posts
JNR5005 - 2.277, 8.880 @ 84.09, 13.536 @ 105.67 (I, Cobb AP LC/FFS) 330' ASL
13.53 @ 105.67
*The picture of the slip is in 13.53 thread, it says I cannot add it as an attachment because it is already attached in that thread?? Help?
2008 Mazdaspeed3 GT
2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON)
Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks
JNR5005 is offline   Reply With Quote
The Following User Says Thank You to JNR5005 For This Useful Post:
DevinS (03-18-2016)
 Old 11-07-2009, 02:29 PM   #33
08cosmic3's Avatar
08cosmic3 - 2.201, 8.862 @ 83.64, 13.511 @ 106.64 (I,IN,IC,EMS,MP,MM) 450'ASL
Stg1+SF93v105 FMIC
 Old 01-10-2010, 07:54 PM   #34
PoMan's Avatar
Posts: 135   (View Stats)
PoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant futurePoMan has a brilliant future
Trapping at 105 I KNOW I should be faster. PM me WTF I am doing wrong I assume i just cant drive...
PoMan is offline   Reply With Quote
 Old 02-28-2010, 08:13 PM   #35
JCMS07's Avatar
Posts: 349   (View Stats)
JCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the world
JCMS07 - 2.030, 8.513@83.92, 13.051@108.25 (I,IN,TBE,CDFP,EMS,IC,MM,S,DR,MTH) 1121 ASL
JCMS07 is offline   Reply With Quote
The Following 2 Users Say Thank You to JCMS07 For This Useful Post:
rodrigo (02-28-2010), tozfeekum (02-28-2010)
 Old 03-06-2010, 12:11 AM   #36
JNR5005's Avatar
Default My New Best Time
Got my new best time tonight after a few hot laps. The new Hankook tires were performing well. I tried running w/ DSC off twice, but was getting too much spinning and a 'lil hop. The launch was near perfect w/ DSC on. Half a tank of gas, full weight w/ the spare and junk. Launch control is set at 3500rpm on the 93oct stg1+sri map. I used 93 gas w/ octane booster. 25 psi in the tires. I did indeed use fifth gear as well.
2008 Mazdaspeed3 GT
 Old 03-06-2010, 02:59 PM   #37
08cosmic3's Avatar
ms3077 (03-19-2010)
 Old 04-13-2010, 05:32 PM   #38
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
jacksonMS30 2.1972, 8.9422 @ 81.92, 13.7324 @ 102.55 (I, IN)
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 05-01-2010, 06:58 PM   #39
JCMS07's Avatar
JCMS07 - 1.945, 8.374@86.10, 12.931@107.82 (I,IN,TBE,CDFP,EMS,IC,MM,S,DR,MTH) 1121 ASL
 Old 07-17-2010, 04:04 PM   #40
2XS 1.805, 8.035@87.25, 12.525@111.44, (I, TBE, EM, IC, S, SL, MM, GT28/76r @19PSI)
Untuned since the std turbo flashtune.
Australia's Quickest MPS 12.3 @111.44 mph
The Following User Says Thank You to 2XS (From OZ) For This Useful Post:
rodrigo (07-19-2010)
« Drag tire question | - »
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f232/official-mazdaspeed-3-1-4-mile-times-18/
$70k Bugeye Runs 10's and Beats a GTR From a Roll - Page 7 - NASIOC This thread Refback 09-11-2014 01:42 PM
who knows a lot about mazdaspeed3's? - Cobalt SS Network This thread Refback 03-16-2014 12:39 PM
Ford Focus ST vs Mazdaspeed3 This thread Refback 01-09-2014 07:05 PM
Ford Focus ST vs Mazdaspeed3 - Page 52 This thread Refback 11-14-2013 04:03 PM
Ford Focus ST vs Mazdaspeed3 - Page 13 This thread Refback 10-30-2013 03:08 PM
Official Focus ST Track Times - Page 36 This thread Refback 10-14-2013 01:00 AM
Can my 03 G35 stick beat a 13 Mazda Speed 3 hatchback stick? - G35Driver This thread Refback 08-25-2013 01:42 PM
Can my 03 G35 stick beat a 13 Mazda Speed 3 hatchback stick? - G35Driver This thread Pingback 08-25-2013 01:28 PM
1/4 mile 2013 - Mazda 3 Quebec This thread Refback 07-04-2013 12:44 PM
Picking Up New Car Tomorrow - Page 2 - KCSR - THE Kansas City Forum This thread Refback 10-26-2012 08:21 AM
Ford Focus ST vs Mazdaspeed3 - Page 8 This thread Refback 10-04-2012 01:22 PM
Modded MS3 vs. Accord 6spd - Page 3 - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com This thread Refback 07-20-2012 10:30 PM
Modded MS3 vs. Accord 6spd - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com This thread Refback 07-15-2012 12:37 PM
E85 is teh stoopid! - Page 23 - JDM Chicago-Japanese Car Community This thread Refback 06-30-2012 10:42 AM
?????, ??????, ????????, ?????? ? ?????????... - Opel Performance Center Club Russia - ???????? 162 This thread Refback 03-04-2012 04:03 AM
*** NEW Richmond area riders thread *** - Page 598 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums This thread Refback 01-24-2012 08:27 PM
*** NEW Richmond area riders thread *** - Page 597 - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums This thread Refback 01-24-2012 08:25 PM
New record for FG2 w/ stock K20Z3 - Page 6 - 8th Generation Honda Civic Forum This thread Pingback 01-19-2011 02:34 PM
who knows a lot about mazdaspeed3's? - Cobalt SS Network This thread Pingback 12-24-2010 06:34 PM
MSP3 == LOLz - Page 9 - 8th Generation Honda Civic Forum This thread Pingback 05-14-2010 02:45 PM
OMG!! 12s Si (All Motor) - Page 19 - 8th Generation Honda Civic Forum This thread Pingback 03-25-2010 01:54 PM
Realtune runs an 11.87! - Page 2 - Dodge Caliber Forums This thread Refback 08-26-2008 05:25 PM
Realtune runs an 11.87! - Page 2 - Dodge Caliber Forums This thread Refback 08-26-2008 05:01 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-26-2008 06:49 PM
Official MS6 1/4 mile times Raider Drag Racing 89 09-28-2018 07:23 AM
0-60 times and 1/4 mile times (MS3 and other cars too) chris410 Gen2 MS3 General Discussion 20 12-24-2011 02:09 PM
1/4 Mile Times & Slips Neverlift Miata - Track Cars and Racing 17 06-04-2011 07:11 PM
My 1/4 mile times! Fagwagon Drag Racing 13 07-30-2010 08:06 PM
Page generated in 0.92337 seconds with 46 queries
