![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
(Thread Starter) | Not Ranked : 0 score no bullshit talking, simply post your time with a link to the timeslip and list your mods in the correct format. With proof of timeslip you will be added to the list. Any posts that do not have time slips or videos, will be deleted. Use these abbriviations for mods: I = Intake IN - 3in Turbo Inlet DP = Downpipe EM = Exhaust Manifold CBE = Cat Back Exhaust MP = Midpipe TBE = turbo back exhaust CDFP = cam driven fuel pump upgrade EMS = tuned MBC = boost controller (specify spike and hold) ie: 18s15h IC = Upgraded Intercooler MM = upgraded motor mount S = suspension such as springs coilover T = turbo upgrade W = Weight Reduction (spare and jack does not count) DR = Drag Radials SL = Slicks N20 = Nitrous MTH = Methanol WB = Wot Box GT30 = GT3071 and 6R Turbo BSD = Balance Shaft Delte Please post time in the following format: SN - 60ft, 1/8th(et and mph), 1/4, (et and mph) (Mods)ASL (feet above sea level) Here are the time frames: 9 second club: Why you not 8s? 10 second club: mazdafreak; 10.35@140.86 (I, IN, TBE, CDFP, EMS Freektuned, BM, PTE6266, SL, PI) 626 ASL da 10ft GENWON RE-ACTIONENGSPEED3 - 1.644 , 6.953@104.97 , 10.625@136.65 (forged,slicks,pte6466,meth,30psi)AWD converted GENWON LumberJack 1.632, 4.633, 6.976@103.32 8.983, 10.629@137.78, 10.629@137.78 PI, 6266, DA=1885 Freekbuilt/Freektune Fontana, CA AutoClub Dragway 2/20/16 SnakeDoc 1.80 60FT, 7.15@105 1/8th 10.88@132 1/4 mile Mods, pte5858, Self built block, meth and 24.5x8.5in slicks GENONE Justin@Freektune; 1.761, 7.246@102.60, 10.931@137.39. (I, IN,—TBE,—CDFP, EMS Freektuned, BM freekbuilt, PTE6062, SL, 6thport, MTH), 81ft ASL, GENPU 11 second club: Justin@Freektune; 1.619, 7.169@101.29, 11.009@132.92 (I, IN, TBE, CDFP, EMS Freektuned, BM freekbuilt, PTE6062, SL, MTH), 150ft ASL, da 1200 GENPU Lumberjack - 1.658, 7.277@99.08, 11.075@133.90 (PI, 6266, Freekbuilt/Freektune ftmfw) GENPU Realgib3 - 1.815, 7.562@97.22, 11.32@130.54 (Self built motor, 6466, 36 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON HOCKEYNUBE- 1.829, 7.564@101.68, 11.436@128.09 (I,IN,TBE,CDFP,EMS @Realgib3; ),IC,MM,S,T(PTE5862),DR(Hoosier QTPs),MTH,WB,BM(self built)) 600 ASL GENPU JCMS07 - 1.729, 7.449@94.91, 11.491@115.94 (I,IN,TBE,CDFP,EMS,IC,MM,Built Motor, GTX3076r,S,W,SL,MTH) GENWON DevinS1.849 60ft 7.651 1/8 @ 93.50mph 11.681 @ 124.18 built longblock,GTX3582r, 6 Port, Hoosier QTP, 50/50 E85 Freektuned.2010 GenPu NJSPEED3 - 1.899, 7.695@96.6, 11.682@117.17(I,EM,T,TBE,MBC 29psi,5th port 50% e85 mix, HTA3586,MM,S,SL) 552ft ASL DA 386 GENWON Driver311 - 1.71, 7.589@94.14, 11.73@119.85, stock motor, slicks, gtx3071 22psi e85 mix GENWON Etipp98 - 1.83, 7.74@96.03, 11.73@118.17 (Stock motor, 6266, 30 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON Papasmurf - 60ft Broken, 7.697@94.953, 11.776@123.161 (GT3582, supporting mods, Port injection 50/50 e85, Slicks/Skinnies) 5500 ft. ASL GENPU wetzms3 - 1.942, 7.724@95.90, 11.781@122.46 (Sluntworks motor, 3076, meth, QTPs and bags) GENPU doubleflusher - 1.755, 7.7@93.86, 11.85@119.69, built motor, slicks, hta3582r 30psi meth GENWON Etipp98 - 1.828, 7.808@92.63, 11.89@122.72 (Stock motor, 6266, 30 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON 801ms3 - 1.85, 11.93@120, stock motor, slicks, gt3071, 26psi falling to 22psi, meth GENWON DevinS-1.905, 7.917 @ 90.81, 11.974 @ 123.34 Fontana, CA Dragway, 1121ASL2010 GenPu 2010 GenPu Overspeed Motorsports built shortblock,GTX3582r, 6 Port, Hoosier QTP, 50/50 E85 Freektuned. Dturboman - 1.96, 7.901@96.85, 11.95@123.18, stock motor, slicks, gt3071r 26psi meth GENWON MZRSPEED - 1.688 7.676@91.71 11.977@113.85 (Stock K04, stock block, I, TBE, CDFP, EMS, E85, MM, W, SL) 106 asl GENPU 12 second club: Snyeed -1.876 60ft, 7.818@92.33, 12.037@117.20 (I, IN, TBE, EM, CDFP, EMS, IC, MM, S, T, SL, MTH, GT3071, 25psi) 4500ft ASL GENWON masterbaiter - 1.8839, (7.89@ 92.55), (12.09@ 118.73)I,IN,DP, EM, TBE, CDFP, EMS, IC, MM, S, T,SL,WB, GTX3071, BSD 5500 ASL GENWON Darkstar5440 - 60' timer wasnt working, 1/8 - 8.08@92.92, 1/4 - 12.127 @ 125.52 built engine, 5858, meth, drag radials, 20' ASL GENPU SilverMS307 - 60' 1.889, 7.934 @ 92.65, 12.183 @115.48 (BNR S3, fully bolted, meth, 25 psi, FREEKtune, stock motor, stock clutch, stock suspension) GENWON JCMS07 - 1.915, 8.008@89.65, 12.188@111.52 (I,IN,TBE,CDFP,EMS,IC,MM,BNR Stage2,S,SL,MTH) 365 ASL GENWON 2XS - 1.843, 7.944@89.2, 12.316@111.79, (I, TBE, EM, IC, S, SL, MM, GT28/76r @19PSI) GENWON Etipp98 - 2.005, 8.13@91.49, 12.22@122.41 (Stock motor, 6266, 28 psi, E85, SL, WB, Diesel gears) 600 ASL GENWON Justin@freektune- 2.089, 8.247@91.47, 12.334@123.52 (built motor, gtx3076, meth, TBE, FMIC) GENPU jkowalski - 2.188, 8.236@92.9, 12.404@120.09 gt3582 supporting mods wmi GENPU pharaoh313 - 1.971 60ft 8.147@88.45 12.493@113.59 (Stock K04,MM,HpFp,I,TBE,E85+M ETS,WR,SL) 151ft ASL 2193DA 81Deg GENPU dmeadors 60 - 1.8 1/8th - 8.1 @ 86.6 1/4th - 12.56 @ 110.5 07 gen1 Slicks, bnrs3, I, IN, TBE, IC, MM, E85, EMS by Rob 1201 ASL GENONE kritz - 2.076, 8.236@89.42, 12.586@112.46 ( 60' 50% e85, tbe, fmic, cdfp, slicks, c.o., tbi) GENPU mxlplx71 - 2.04, 8.315@90.06, 12.637@113.75 (built, bolted, freeked, drs, e30, bnr s2) GENWON bewsted - 1.933, 8.245@88.09, 12.639@112.27 (??) GENPU GENPU 9900rpm - 1.960, 8.182@87.54, 12.653@109.90 (I, TBE, CDFP, EMS, IC, MM, SL, MTH) 33 ft. ASL GENPU mrdouble99 - 1.918, 8.193@86.49, 12.737@108.51 (I, other unkown mods) GENWON 86AmishMs3 - 2.201, 8.567@92.55, 12.820@113.8, (gt3076, E85 mix, 23 psi, street tires), 550ASL GENWON Amp1623 - 12.82 @ 107, 1.79 60ft, Stock Block, Stock K04, on 255/50r16 Mickey Thompson ET street radials TRU-BOOST - 1.90, 8.28@86.36, 12.829@107.90 (I/DP/MP/CDFP/MBC@19PSI/T/MM/EMS/SL) GENWON Luke@Corksport - 2.0 60ft, 8.3 in the 1/8 @ 88.85mph, 12.835 @ 110.35 in the 1/4. I, IN, TBE, CDFP, IC, MM, SL, E85, KO4, EMS by Ryan Martin @ Purple Drank Tuning. GENWON alaskazero - 2.4554, 8.6371 @91.79, 12.8408 @116.38, (Drag radials, Built motor, GTX3071, Freek tune) GENPU Smelson - 2.069, 8.384@88.44, 12.842@109.89 ( I/IN, DP, CDFP, EMS, IC, MM, 35%e85) ASL 460f GENPU atvfreek - 2.239, 8.660@88.67, 12.903@117.33 I, TBE, MTH, BNR S3 500ft ASL GENPU Laloosh - 2.019, 8.467@ 87.69, 12.906@111.14 (I/TBE/18psi/CDFP/S/MM) 320ASL GENWON MS3inDC - 1.869, 8.32@85.89, 12.948@109.00 (I, DP, MP, EMS RichTune 93 oct, IC, MM, SL) 18 ASL GENONE dmeadors 60 - 2.163 1/8th - 8.519 @ 85.96mph 1/4th - 12.95 @ 112.82mph Slicks, bnrs3, I, IN, TBE, IC, MM, E85, EMS by Rob 1201 ASL GENONE Rodrigo - 1.888, 8.394@85.03mph , 12.968 @ 108.71 mph (mods everything) 365 ASL GENWON Livingframe - 1.983/8.442@85.47/12.988@107.85 GENPU 13 Second Club: @moo_cow1216; 2.141, 8.582@84.79, 13.000@112.47 (Cs turbo, 3.5in I, tbe, rmm, cdfp, ems purple drank on 93, fmic, mbc @23s23h) asl ArcticSpeed3 - 1.98, 8.48@84.27, 13.09@105.88 (I,DP,MP,CDFP,EMS,EBCS,IC,IN,MM,DR) 75ft. ASL GENPU sg1320 - 2.158, 8.55@86.2, 13.099 @ 107.65 mph (I, IN, TBE, CDFP, EMS, IC, MM) DA 450' GENPU JgamB - 2.104 60', 8.736@87.11, 13.107@117.12 (I, TBE, IC, E85, BNR S3) GENPU SharkDiver - 2.042,8.5@85.93mph, 13.12@109.51mph (MM,FMIC,EMS,DP,MP,I,EM,BSD,stock tires) GENWON N2o - 1.897, 8.468@83.86, 13.143@106.07 (I,TBE,TIP,HPFP,IC,S,FreekTuned 94 oct,RMM,S,SL) 270 ASL GENPU jhallems3 - 2.1375, 8.6202 @ 84.84, 13.1473 @ 109.94 (I, DP, CBE, CDFP, RMM, ko4 Freektuned and street tires) 910' ASL GENPU MGMSIII - 1.91, 8.41@82.34, 13.16@103.8, (I,DP,MM,S,DR) 10' ASL GENWON Ziggo - 2.11, 8.33@87.55, 13.163@111.1, (bnr stg3, street tires) GENWON Allmotor95pgt - 1.866-60ft, 8.463@82.63, 13.177@104.40, knn dropin filter, tmic, gutted 2nd cat, mm, dr, w, rubber rear spring blockers, boost tubes, 126asl. (Stock tune) GENWON Enki - 2.421, 8.961 @ 88.62, 13.189 @ 120.16, (I - IN - EM - TBE - CDFP - EMS - IC - MM - S - T EFR 6758 @ 24 psi - BSD - MTH - E85), 3079 ASL - DA 6383 GENWON 08cosmic3 - 2.193 8.73@87.38 13.196@110.84 (bolt on 20% e85) 450asl GENWON UDNTKNW - 60' 2.09, 1/8 8.60 @ 85.54mph, 13.19 @ 106, (I, IN, TBE, CDFP. MM, EMS) ASL 3079' GENWON Cevaes_64 - 2.0, 8.71@82 13.2@108.80 EMS with 4GLs of E-85, I, DP, ITV-22, MM, CD GENPU BigJimMs3 - 2.21, 8.76@85.89, 13.201 @108.23 (I, DP, MP, CDFP, EMS, IC, MM,3gal E85mix) GENPU Payne Racing 67 - 2.170, 8.657@85.18, 13.237@107.45 (I, DP, CDFP, EMS, IC) GENPU snailD - 2.21, 8.89 @ 87.78, 13.24 @ 113.65 (GTX2867, e85, 4500 ASL) GENPU JacksonMS30 - 2.18, 8.73@83.99, 13.31@106.42,(I, DP, MP, CDFP, MTH, S, MM) GENWON JNR5005 - 2.206, 8.762 @ 85.05, 13.330 @ 107.98, (I, Cobb AP LC/FFS) 330' ASL GENWON Slash - 2.13, 8.72@83.79, 13.39@103.35 (I, IN, CDFP, IC, EMS, 1250FT ASL) GENPU sleeper3 - 2.234, 8.742@84.18, 13.365@106.75 (I, IN, IC, MM) GENWON 08cosmic3 - 2.154, 8.773 @ 84.91, 13.392 @ 107.15 (I,IN,IC,EMS,MP,MM) 450'ASL GENWON SLS MS3 - 2.060, 8.691@83.54, 13.394@104.33 (I, DBE) GENWON White'swhitemps - 2.1929 60ft, 8.8499@85.72, 13.4471@108.14. I,IN,DP,TBE,EMS,IC(top mount),MM,S GENPU racebitz - 2.261,8.838@84.94, 13.460@106.30 (I,CBE,2.5"IN,FMIC,MM) GENWON Chaser27 - 2.063, 8.839 @ 83.24, 13.461 @ 106.39 (I, DP, CDFP, EMS (Self-tuned), FMIC, RMM, W) GENPU loopymps-2.164, 8.881 @82.74, 13.485@108.84 MPH (DP, IC, EMS, HPFP, MM, IN, METH, DR) GENPU aaronc7 - 2.239, 8.890@83.56, 13.506@106.30 (I/TBE/FMIC/MM/EMS/METH) 55' ASL GENWON Skierdood - 2.1 60', 8.87 @83.62 660' 13.510 @106.14 1/4 (I, TIP, TP, CDFP, EMS, MM, 3/9 E85) 250' ASL GENWON Spec - 2.221, 8.941@84.48 13.518 @ 108.95 (e85, IN, CDFP, TP, EMS, 199FT ASL) GENPU mswierse - 2.21, 8.36@81.96, 13.58@106 (I, RMM, CDFP, EMS) GENPU Andrewbox - 2.04/13.6 @ 104 full weight, 3/4 tank Mods: IN, TBE, CDFP, EMS, IC, MBC, MM, S GENPU Breeze10 - 2.365, 9.06/84.14, 13.61/108.77 ASL 1180(I,IN,CBE,MP,CDFP,EMS,IC,MM,S,25%E85) GENPU Jsn Rob - 2.29, 8.94@84.27, 13.61@107.42, RMM,DP,TP,SRI,LS,WOT BOX,BPV GENWON Eazy - 2.153, 8.876@81.27, 13.623@103.47, (I, IN, MM, S, DP, MP, CDFP, MBC@19, BSD, DR) 29' ASL GENWON spd frk - 2.138, 8.900@81.02, 13.624@105.33 (I, IN, DP, CBE, MM, Cobb AP LC/FFS) GENWON Nataphen - 2.249, 8.949@82.30, 13.638@101.67 (I, CBE, MP, EMS, IC, MM) GENPU Gr8Speed - 2.2668, 8.9417, 13.6458 @ 104 (FULL BOLT, METH, 50/50e85, DR) GENWON Ray Danger 2020 - 60'=2.2645; 8.9648@83.66; 13.6722@105.53; ASL=1180' (I, TBE, CDFP, EMS, IC, MM, S, E85 mix 5gal/tank, Finkle Tuned) GENPU dsmluck - 2.383, 9.212@88.37, 13.688@111.78 (will update mods later, gt3076r @25 psi) GENWON kashbringer; -2.30,9.16@83.35,13.71@110.46,(I/IN3.5",TBE,CDFP,EMS,IC,MM,25%E85,Stock tires) ASL 199ft GENPU 240mazspd3- 2.143, 8.94@80.94, 13.714@ 102.43 (I, MM , S BOV...pre AP & TP) GENWON baluums3 - 2.25 9.0998 @ 82.77 13.7656 @ 105.49 (CAI, MM, DP, RP, FMIC, CDFP, Meth 50/50) ASL 600 GENWON Daytripper79- 2.219, 9.038 @ 82.37, 13.765 @ 103.46 (I,MM,TBE) GENWON Blackms3_71 - 2.380 60ft 9.129@9.465,13.768@106.45 (I,in,dp,mp,cbe,cdfp,ic,mm,s) GENWON jtspells - 2.253, 9.028@83.97, 13.798@103.67 (I) GENWON Focused - 2.319, 9.102@81.84, 13.8@102.67 (I/MM) GENWON BLACKMS3 - 2.287, 9.063@82.16, 13.802@104.16 (I, MP, MM, W) 200 ASL? GENWON ArcticSpeed3 - 2.04., 8.92@79.10, 13.87@99.13 (I, MM, DR) 75ft. ASL GENPU k_skidz97 - 2.186, 9.121@81.96, 13.889@102.16 (I,MP) GENPU EnzoR - 2.163, 9.048@78.61, 13.898@101.38, (I, TIP, IC, DP, TP, CBE) ASL 465ft GENPU alexwlwsn - 2.309, 9.127@81.38, 13.909@101.38 (I/IN/CDFP/MM/S) 350ft ASL GENWON Jarods7920 - 2.139, 9.034@79.93, 13.916@100.7 (Bone Stock) 410' ASL GENWON DingoDave - 2.2179, 9.1097@80.65, 13.9181@101.63 (I, IN, MM) 150' ASL GENPU Scatt Nasty - 13.940 @ 106, 2.39 60ft, 9.2 1/8 @ 81.9 ( I,IN,TBE,CDFP,EMS,IC,MM,S,MTH ) 3075' ASL GENWON opt_ms3 - 2.362, 9.128@79.89, 13.955@100.48, (I,MM, DP, MP catted, CDFP) 204ft ASL GENWON reddeerspeed3 - 2.209, 9.06 @ 79.75, 13.96 @ 101.51 (I, IN, TBE, CDFP, MBC@15psi, MMx3) 2373' ASL GENWON ms3077 - 2.07, 9.033@ 80.17, 13.97@99.92 (I,MM) GENWON phillyb - 2.385, 9.203 @ 81.48, 13.97 @ 104.23 (I, DP, IC, MM) GENWON Frequentlfyer - 60' - 2.364 1/8 - 9.323 @ 80.32MPH 1/4 - 13.991 @ 107.35MPH Spicytune VP 109 unleaded dp HPFP internals SRI TMIC GENONE 14 Second Club: Super_X - 2.251, 9.135@79.99mph, 14.012@99.37mph (Stock) GENWON clos561 - 2.28, 9.14@79.9, 14.03@100.26 (I) GENWON Deek - 2.28, 14.05@98.25 (in/tip/fp/ap/tp) GENWON Jesse MS3GT - 2.278, 9.156@78.58mph, 14.058@99.40mph, (I/MM) 740' ASL GENWON PoMan - 2.38, 9.32@81.48, 14.06@105.14 (I, IN, TBE, CDFP, EMS, MM) 600' GENWON EuroTuneR - 2.198, 9.210 @ 80.34, 14.090 @ 96.99 (Stock) 50ASL GENWON jam_asian85 - 2.302, 9.206 @ 79.94, 14.099 @ 99.43 (I/DP/MP/MM) GENWON joeylow - 14.11 @ 97mph (MM/S) GENWON monkey.bones.007 - 2.186, 9.268@81.66, 1/4, 14.185@100.85 (I, MP, CDFP, IC, MM,S, STRATIFIED OTS+) 715.2 GENPU ill_eagle94 - 2.390, 9.361@79.27, 14.194@102.16 (I/DP/MP/MM) 90' ASL GENWON RonTonkinMazda - 2.435,9.466@82.95 ,14.206 @104.38 (I/IN/IC/MP/CBE/20psi) GENWON Paul - 2.312, 9.376@79.25, 14.209@102 (I, DP, CBE, MP, TBE, CDFP, EMS, IC, MM, S) 3850ft. ASL (E85/91 1/3mix) GENPU MidwestSpeed3 - 2.304, 9.349@78.05,14.279@100.17 (I/MM) GENWON MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) GENWON stephano18 - 2.3580, 8.8191@?, 14.3093@98.45 (I/MM/MP/CBE) 2200ASL GENWON ccann - 2.512, 9.283@80.48, 14.314@94.83 (I/IC/MM/EMS) GENWON robh - 2.352, 9.369@78.67, 14.325@97.41, I CBE 900 ASL GENWON Sensei - 2.393, 9.509@77.01mph, 14.370@102.92mph, (I/TIP/CDFP/TP/FMIC/RMM/PMM/EMS) 90' ASL 469' DA GENWON 5doorsoffury - 2.210, 9.470@76.38, 14.380@100.44 (IN,MP,EMS,CDFP) 500ft asl GENPU Doc_sean 2.404,1/8th -not available,1/4 (14.381@ 101.02 mph) (I,DP,EMS-Hypertech,MM,)170 ASL GENWON Darth_Nuruodo - 2.61, 9.68 @ 80.1, 14.39 @ 107.7 (3" I/IN, TP, EMS, E40 (50% E), CDFP, MM)Asl 199 GENPU Redninjagirl - 2.32, 9.447@77.02, 14.407@100.55, bone stock, 720 ASL GENPU BigJimMs3 - 2.290, 9.487@76.22, 14.408@101.52 (??) GENPU kingpin748 - 2.312, 9.487@77.78, 14.469@101.62 (I/TBE/IC/MM/WB) 2100ASL GENWON Babyface13 - 2.36, 9.50@76.89, 14.47@99.71 GENWON Plaqyero02- 1/4 (14.563 @103.45)(i,mm) 2k4_8 - 2.3999, 9.6337@77.60, 14.5671@103.26 mph 4860asl w/6783 Da (I, DP, EMS, MM) GENPU Texasboy21 - 2.1994, 9.5667@75.52mph, 14.6258@99.29mph, I, 600' ASL GENPU cbusby - 2.325, 9.529 @ 78.55, 14.634 @ 96.17, (I/MM/S) 25' ASL GENWON KaisorSoze - 2.543, 9.676 @ 78.86, 14.672 @ 98.37, (MM) 2100' ASL GENWON Snotrocket - 2.353, 9.605@77.07, 14.673@98.93, (I, IN, DP, CBE, MP) ASL 260ft GENPU 2010MS3! - 2.587, 9.715@77.82, 14.721@95.80, 14ft ASL GENPU akabickle - 2.370, 9.610@76.86, 14.753@96.21, (I, MM) ASL 700ft GENPU CaptObvious75 -.944, 2.26, 9.7 @ 73.0mph, 14.8 @ 94.5mph Stock GENPU Once you post your time in the correct format with a link to the time slip you will be added to the list. ALL TIMES ON THIS LIST HAVE BEEN VERIFIED Last edited by SofaKingAwesome; 05-10-2016 at 01:38 PM. |
| The Following 16 Users Say Thank You to littleloogy For This Useful Post: | aaronc7 (10-13-2008), dantes5823 (04-11-2013), Eazy (08-12-2008), Enki (10-12-2014), jlarson1983 (03-25-2008), MazdaMan13 (06-26-2008), MS3inDC (04-15-2013), NJSPEED3 (01-08-2013), Payne Racing 67 (10-07-2012), rigor (06-08-2013), Scatt Nasty (07-25-2009), SgtP (09-14-2008), stang9779 (11-28-2011), WetzMS3 (11-09-2015), ZetaDrift (10-08-2015), [R]usty (09-23-2014) |
| Banned ![]() Join Date: Mar 2008 Location: Kent, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,649
Groaned at 32 Times in 14 Posts
| Not Ranked : 0 score Speeed3 - 2.326, 9.537@75.68, 14.613@96.96 (I,MM) Last edited by Eazy; 08-10-2008 at 07:37 PM. |
| The Following User Says Thank You to Eazy For This Useful Post: | jlarson1983 (03-25-2008) |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score |
| The Following User Says Thank You to Laloosh For This Useful Post: | jlarson1983 (03-25-2008) |
![]() Join Date: Mar 2008 Location: Oklahoma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
| Not Ranked : 0 score BlackMS3 - 2.213, 9.230@77.61 (I/MP/MM) 60ft: 2.213 Time: 9.230@77.61 Last edited by BlackMS3; 03-24-2008 at 07:47 PM. |
| The Following User Says Thank You to BlackMS3 For This Useful Post: | jlarson1983 (03-25-2008) |
![]() Join Date: Mar 2008 Location: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score full interior, spare tire, stock tire pressure, only mod is a mazdaspeed cbe this was at raceway park in englishtown, NJ the 12.18 car was a subaru legacy that at its previous run smoked all four tires and the 10.19 car was a fully built muscle car |
| Dismember ![]() Join Date: Mar 2008 Location: Panama City, FL
Rep Power: 1242 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 821
Groaned at 27 Times in 13 Posts
| Not Ranked : 0 score 2.543, 9.676 @ 78.86, 14.672 @ 98.37, (MM) 2100' ASL I'm # 47
__________________ 2012 Nissan Titan 4x4 |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score UDNTKNW - 2.24, 9.01@? (no mph recorded), 13.84@99.95 (I), 1243' ASL |
![]() Join Date: Jul 2008 Location: Montclair, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score JCMS07 - 2.352, 9.388@78.83, 14.286@101.16 (I,CBE) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score all this time i forgot to post my most recnt time in here.....duh !! here you go.. lets see if i can list all my mods I/DP/MP/CDFP/MBC @ 19PSI/T/MM/EM/SL..... i think thats all the important stuff !! i am going again this friday night with the WOT box this time. hopefully i can do a little better. i will be running against my cousins new gt500 mustang. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score Kinda disappointed with these times but there were stock vettes out that were running low 14's also so I guess it was ok for my first time driving hard in a striaght line . Advice welcome . cobb stage 2 suspension , 18/8 235/40 nitto nt01's Cobb ap stage 1 +cai 1.02 tune , MsCai , Ets 3.25 tmic , AWR r motormount 88 duro I missed 3rd + 5th gear and spun all the way through 1'st . haha check out the trap speed ! |
| MSF Punished Member ![]() Join Date: May 2008
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Improved my previous time by quite a bit: Speeed3 - 2.196, 9.088@81.42, 13.900@102.21, (I, MM, S) 29' ASL #1123E Last edited by Eazy; 08-12-2008 at 12:10 PM. |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
| Not Ranked : 0 score SharkDiver 2.23,8.94@83.64,13.62@106.91..MM,FMIC,DP,MP,MSCAI, EMS It looks like I have the 2nd highest trap speed so far or maybe 3rd after Tru-boost gets listed,But he is on slicks...WooHooo
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
| Not Ranked : 0 score SharkDiver 2.221,8.93@83.80,13.610@107.17mph..MM,FMIC,DP,MP,M SCAI,EMS Car 25
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score 2.266, 9.236 @80.24mph, 14.181 @100.89mph (DP) 2373' ASL my motor mount showed up in the mail right after i left for the track
__________________ |
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score 2.3580, 8.8191, 14.3093 @98.45 (I/MM/MP/CBE) 2200ASL |
| Not Ranked : 0 score SharkDiver 2.01/8.63@82.87..13.31@105.35.MM,FMIC,DP,MP,cobb sri,EMS Car 51,My brothers Mach1 is car 52... My highest trap speed for the day was 107.69mph..
![]() Join Date: Jan 2009
| Not Ranked : 0 score Mods testpipe |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Jarods7920 60ft 2.139 1/8 9.034 79.93 1/4 @13.916 @100.7 Bone Stock ASL 410ft Last edited by Jarods7920; 03-10-2009 at 07:54 AM. |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score phillyb, 2.385, 9.203 @ 81.48, 13.97 @ 104.23 i/dp/ic/mm/ Last edited by phillyb; 03-09-2009 at 12:49 PM. |
![]() Join Date: Aug 2008 Location: Kahaluu, HI
| Not Ranked : 0 score 2007 Mazdaspeed 3 I = MSCAI2 DP = Corksport CBE = GHL EMS = AP v2 Stg2+MSCAI2+FMIC 91 103i IC = TURBOXS MM = SU Rear mount S = COBB Stg2 http://www.cardomain.com/ride/3123210 California Speedway (Fontana, CA) on 2 Nov 08: SN - .230 RT; 2.183 60ft; 8.860@82.33 1/8th; 1/4, 13.602@98.93 - Yeah I missed 5th gear and coasted the last few feet SN - .325 RT; 2.397 60ft; 9.232@81.69 1/8th; 1/4, 13.975@105.68 If ya care on 7 Mar 09 I did a 16.30@98mph, with a 1 sec RT a missed shift 1st to 2nd then car died at the end of the track, turns out I broke a clamp on a hose going to the bottom of the intake manifold and then two missing turbo stud bolts for the exhaust manifold (rattled/shook loose and lost somewhere on the I-101/I-405)
__________________ 07 Black Mica with Sunroof" 11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles) "I'm back Baby" says the almighty Bender CURRENT MODS: Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN: VDyno 351hp and 331tq BEST 1320: COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear) Last edited by ljudgeii; 03-12-2009 at 12:37 AM. Reason: add attachment |
![]() Join Date: Nov 2008 Location: West Palm Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score MGMSIII- 1.91, 8.41@82.34, 13.16@103.8, I,DP,MM,S,DR 10' ASL
__________________ '08.5 Speed3- Mods: Cobb sri, SU MM, TWM, SW dp, HR Springs Best ET: 13.16 @ 103.8 WWW.MobileDynoSolutions.COM DynoDay 4/11/09 |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
![]() | | #24 | ![]() |
| Not Ranked : 0 score JCMS07 - 2.191, 9.129@80, 13.945@102.53 (I,IN,CBE,EMS,IC,MM,S) 1121 ASL Last edited by JCMS07; 05-31-2009 at 09:13 PM. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score BLACKMS3 - 2.287, 9.063@82.16, 13.802@104.16 (I, MP, MM, W) 200 ASL?
__________________ Best to date - 13.802@104.16 (I/MP/MM/W) |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score I, MM, S, BOV 13.71 @ 102.4(pre AP and TP) 60': 2.143 1/8: 8.948
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #27 | ![]() |
| Not Ranked : 0 score reddeerspeed3 - 2.376, 9.26 @ 79.86, 14.07 @ 102.48 (I, IN, TBE, CDFP, MBC@15psi, MMx3) 2373' ASL
![]() | | #28 | ![]() |
![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
| Not Ranked : 0 score Scatt Nasty I,IN,TBE,CDFP,EMS,IC,MM,S,MTH 13.940 @ 106, 2.39 60ft, 9.2 1/8 @ 81.9 3075' ASL
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL Last edited by Scatt Nasty; 07-25-2009 at 11:07 AM. |
| The Following User Says Thank You to Scatt Nasty For This Useful Post: | phillyb (08-01-2009) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Eazy - 2.131, 9.028@82.26, 13.757@104.62, (I, MM, S, DP, MP, CDFP, MBC@19) 29' ASL |
![]() | | #30 | ![]() |
![]() Join Date: Jun 2009 Location: NS, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 171
Groaned at 10 Times in 1 Post
| Not Ranked : 0 score First time ever racing... cbusby - 2.325, 9.529 @ 78.55, 14.634 @ 96.17, (I/MM/S) 25' ASL
__________________ 2008 Mazdaspeed3 / Bolted (mostly) / Parting out. |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2008 Location: Austin
| Not Ranked : 0 score 2.25 9.0998 @ 82.77 13.7656 @ 105.49 (CAI, MM, DP, RP, FMIC, CDFP, Meth 50/50) ASL 600 Last edited by baluums3; 07-28-2009 at 08:44 AM. |
![]() | | #32 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score Beech Bend Dragway, Bowling Green KY. 8-1-09. 80 degrees and humid, stock tires w/27,000 miles Cobb AP Stg1+sf93v104 08cosmic3 - 2.209, 9.069 @ 82.10, 13.835 @ 103.58 (I,IN,EMS,MP,MM) 450'ASL
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #33 | ![]() |
![]() Join Date: Jun 2008 Location: Hogtown, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score 60' 2.138 - 1/8 8.900 - 1/8MPH 81.02 - 1/4 13.624 - MPH 105.33 - ASL - I, IN, DP, CBE, MM, Cobb AP LC/FFS Again here is the timeslip Car #986 along with my backup run of 13.67
__________________ 2008.5 Black Mica MS3 - Cobb AP, RPMC Inlet, CPE TBE, CPE CAI, SU Mount, HKS SSQV, Autometer boost guage 1/4mile slut |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Eazy - 2.153, 8.876@81.27, 13.623@103.47, (I, MM, S, DP, MP, CDFP, MBC@19, DR) 29' ASL |
![]() | | #35 | ![]() |
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score opt_ms3 - 2.362, 9.128@79.89, 13.955 100.48, (I,MM, DP, MP catted, CDFP) 204ft ASL
![]() | | #36 | ![]() |
| Not Ranked : 0 score hey all, Well I went back to the strip for the first time since my build.Im still using the stock tires up front since I dont have any slicks yet. I didnt do to bad but I did really want to get into the 12s but the track conditions today were bad for everyone. I ran a best time of 13.12 @ 109.51. I will be adding a video of the race and the datalog from it aswell. I datalogged all 5 runs today and incar video taped them. Also the temp outside was about 73F and we are about 600' above sea level.This puts me back at the top of the 13 class again.... ![]() Car #85 SharkDiver - 2.042,8.5@85.93mph, 13.12@109.51mph (MM,FMIC,EMS,DP,MP,I,EM,BSD,stock tires) In this video I did a 13.71@109.18..I messup and put the wrong video up.I missed 2nd gear here also. In this video I did a 13.12@109.51mph.. A civic got me again..
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn Last edited by SharkDiver; 09-02-2009 at 02:00 AM. |
| The Following User Says Thank You to SharkDiver For This Useful Post: | felt (01-10-2010) |
![]() | | #37 | ![]() |
![]() Join Date: Mar 2009 Location: Brisbane, Australia
| Not Ranked : 0 score Finally found a thread I like. I ran at the Jamboree (here in Australia) and won the Street Compact class (108 cars total) My best time of the day 13.06@106mph 2XS - 1.871, 8.394 @81.87, 13.06 @106.8 (I, TBE, EM, IC, S, SL, WB, MM, @16PSI) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score slowly learning to launch... reddeerspeed3 - 2.209, 9.06 @ 79.75, 13.96 @ 101.51 (I, IN, TBE, CDFP, MBC@15psi, MMx3) 2373' ASL
![]() | | #39 | ![]() |
| Not Ranked : 0 score Running Stg1+SF93v105 FMIC. Attached is a log of the run. My AF's are too lean and I need help with ATR to add fuel. I spun 1st gear badly and my 60 and the data log shows it. I was able to get only two passes at the track, very crowded. With practise I believe I can get 13.5 with my set up. Please update me on the list. datalog3.csv 08cosmic3 - 2.320, 9.058 @ 84.43, 13.685 @ 106.64 (I,IN,IC,EMS,MP,MM) 450'ASL
![]() | | #40 | ![]() |
![]() Join Date: Jul 2009 Location: Philadelphia Metropolitian Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 578
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score JNR5005 - 2.277, 8.880 @ 84.09, 13.536 @ 105.67 (I, Cobb AP LC/FFS) 330' ASL 13.53 @ 105.67 *The picture of the slip is in 13.53 thread, it says I cannot add it as an attachment because it is already attached in that thread?? Help?
__________________ 2008 Mazdaspeed3 GT 2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON) Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks Last edited by JNR5005; 11-06-2009 at 10:59 PM. |
| The Following User Says Thank You to JNR5005 For This Useful Post: | DevinS (03-18-2016) |
| Display Modes | |
| Official MS6 1/4 mile times | Raider | Drag Racing | 89 | 09-28-2018 07:23 AM |
| 0-60 times and 1/4 mile times (MS3 and other cars too) | chris410 | Gen2 MS3 General Discussion | 20 | 12-24-2011 02:09 PM |
| 1/4 Mile Times & Slips | Neverlift | Miata - Track Cars and Racing | 17 | 06-04-2011 07:11 PM |
| My 1/4 mile times! | Fagwagon | Drag Racing | 13 | 07-30-2010 08:06 PM |
