![]() Join Date: Mar 2008 Location: North America ;)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
(Thread Starter) | Not Ranked : 0 score This is the pdf version of the 2012 Scca solo rulebook. http://scca.cdn.racersites.com/prod/...ules_March.pdf There are three classes that a street driven MS3 would be classed in DS, STX, and DSP. The MS6 is classed in DS, STX, and ESP. Stock class (DS) rules are in Section 13. DS is by far the most competitive class for the MS3 and has a very wide rage of cars. This class is for stock or near-stock cars. The full list of eligible DS cars is on page 170 of the rule book. ST class (STX) rules are in Section 14. STX also has a wide variety, from Mini Cooper S and Sentra SE-R on the small end, to Infiniti G35 and sub-5.0L Mustang/Camaro/Firebirds on the large end. This class is between DS and DSP on a scale of preparation, and would be for most cars with typical mild bolt-on modification. The full list of eligible STX cars is on page 182 of the rule book. SP class (DSP and ESP) rules are in Section 15. DSP is typically dominated by BMW's, and would take a substantial amount of effort and parts to build a competitive car. The full list of eligible DSP cars is on page 189 of the rule book. SM class (SM and SMF) rules are in Section 16. Any major engine modifications would typically put your car in SM or SMF. That would mean built motor or big turbo would place you here. The rules are very open and just about anything is allowed aside from cutting things off of your car
__________________ 08 Cosmic Blue MS3 Autox pwns j00!!! Last edited by Raider; 03-28-2012 at 12:14 PM. Reason: 2012 |
![]() Join Date: May 2008 Location: ME, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,600
| Not Ranked : 0 score Good info! Just wonder if and/or when they are going to change us to GS |
![]() Join Date: Mar 2008 Location: Earth
So where does a MS3 that doesn't fit into DS, DSP, nor STU go...?
__________________ 2008 Stage 3 Roush Mustang 302E 5.0L Stroker 647rwhp-620 rwtq | |
(Thread Starter) | Not Ranked : 0 score Then you would go to a Prepared class....not sure which prepared class it would fit in though...
__________________ 08 Cosmic Blue MS3 Autox pwns j00!!! |
| Not Ranked : 0 score What about SM...? I think Prepared would be too hard of a class considering those are for race cars...
![]() Join Date: Jul 2008 Location: The Ocean State
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 709
our car has a chance in DSP, problem is nobody has actually approached the class with the mindset to actually create a DSP car rather than race their street car which happens to fall into DSP here's a lil teaser for ya if my finances cooperate (not photchopped) | |
| Not Ranked : 0 score |
| Not Ranked : 0 score I read that...but thats only for DS (stock MS3)... DSP remains...
| Not Ranked : 0 score What size are those and don't you worry about tire rubbing the fender? Along with all your paint being sand blasted!!!
(Thread Starter) | Not Ranked : 0 score Guys....start another thread about that....this is the rulebook thread... I'm serious...I wanna see what you got planned..i'm liking what i'm seeing so far ![]() 255's?
![]() Join Date: Feb 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I need to see what it's all gonna cost to run a comp. "old man reflex" run. I wasn't that good when I was young, but technology Ho! |
| Wide tire man ![]() Join Date: Feb 2009 Location: Indianapolis IN
Rep Power: 383 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 162
| Not Ranked : 0 score The 2009 rules are done and on the website. http://cms.scca.com/documents/Solo_R...Solo_Rules.pdf
__________________ 2012 Crystal White Pearl Mazdaspeed3 Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs. Too many wheels & tires to list. |
| Not Ranked : 0 score 2010 Rules are up. http://www.scca.com/documents/Solo_R...solo_rules.pdf
| Not Ranked : 0 score Very nice, thanks! :Edit: NO MORE LEGACY GT'S IN DSP CLASS!!!!!!!
__________________ [SIGPIC][/SIGPIC] Last edited by jtspells; 03-16-2010 at 04:06 PM. Reason: im a dumbass |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score 2012 Rules http://scca.cdn.racersites.com/prod/...ules_March.pdf @Raider Can we update the OP and have the link to the current year at the top and change the title to be general as opposed to 2008? Thanks.
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
| Not Ranked : 0 score LMK if verbiage needs updating. Link and title updated. |
| The Following User Says Thank You to Raider For This Useful Post: | Crarrs (03-28-2012) |
| Not Ranked : 0 score There are three classes that a street driven MS3 would be classed in DS, STX, and DSP. The MS6 is classed in DS, STX, and ESP. Stock class (DS) rules are in Section 13. DS is by far the most competitive class for the MS3 and has a very wide rage of cars. This class is for stock or near-stock cars. The full list of eligible DS cars is on page 170 of the rule book. ST class (STX) rules are in Section 14. STX also has a wide variety, from Mini Cooper S and Sentra SE-R on the small end, to Infiniti G35 and sub-5.0L Mustang/Camaro/Firebirds on the large end. This class is between DS and DSP on a scale of preparation, and would be for most cars with typical mild bolt-on modification. The full list of eligible STX cars is on page 182 of the rule book. SP class (DSP and ESP) rules are in Section 15. DSP is typically dominated by BMW's, and would take a substantial amout of effort and parts to build a competetive car. The full list of eligible DSP cars is on page 189 of the rule book. SM class (SM and SMF) rules are in Section 16. Any major engine modifications would typically put your car in SM or SMF. That would mean built motor or big turbo would place you here. The rules are very open and just about anything is allowed aside from cutting things off of your car. @Raider Last edited by Crarrs; 03-28-2012 at 10:38 AM. |
| Not Ranked : 0 score Do me a favor, rewrite post #1, and I can edit/paste, ok? |
| Not Ranked : 0 score Done |
| Banned ![]() Join Date: Jul 2009 Location: Fremont, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
| Not Ranked : 0 score DS most competitive class for MS3? No way. |
| Not Ranked : 0 score Yeah....I forgot to change that when I revised the original post. It was before the ST re-org, but it still wasn't pretty.
![]() Join Date: Nov 2009 Location: Hudson, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Some updates: The most recent rules revision: https://www.scca.com/pages/solo-cars-and-rules The MS6 is still in D Street but the MS3 has been lowered to G Street. Then both move up to the new Street Touring Hatch class. The MS6 is still E Street Prepared and the MS3 is still in D Street Prepared. |
| 2012 SCCA STX Auto-X build | justint5387 | MazdaSpeed 3/6 - Build Diaries | 240 | 04-28-2014 07:19 PM |
| SCCA AutoX Feb 26 2012 | Paul | Auto-X / Road Racing / Time Attack | 3 | 02-27-2012 01:49 PM |
| Starting to SCCA autoX | beachshoer | Auto-X / Road Racing / Time Attack | 3 | 09-04-2011 06:32 AM |
| NYR SCCA 2011 AutoX schedule | NYR Solo | Auto-X / Road Racing / Time Attack | 2 | 06-22-2011 08:56 PM |
