![]() Join Date: Nov 2009 Location: Hudson, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score I really like the TSW Nürburgring wheel which comes in 2 sizes that might work: 18x8.5+45 or 18x9+63 (this will need 10mm spacers & extended wheel studs) The fenders have already been rolled, not flat but done professionally, and no pull. The 8.5" wheel with a 235/40 tire according to Rims&Tires should have plenty of clearance inside and stick out about 20mm. The 9" wheel with a 245/40 tire will be approximately 13mm closer to the suspension and stick out 17mm if I use a 10mm spacer giving an effective offset of +53. These are the tires I've been looking at. The dimensional data comes from TireRack. (I couldn't insert my Excel spreadsheet.) Model/Size Tread Width Diameter Weight Rim Width Pirelli P Zero Trofeo R 225/40R18 8.1 25.1 23 8.5 235/40R18 8.5 25.4 22 8.5-9.0 245/40R18 8.7 25.7 25 9.0 Toyo Proxes R888R 225/40R18 8.2 25.1 23 8.5 235/40R18 8.6 25.4 24 9.0 245/40R18 8.9 25.7 25 9.0 255/35R18 9.6 25.0 25 10.0 Michelin Pilot Sport Cup 2 235/40R18 8.0 25.4 21 8.0-8.5 245/40R18 8.3 25.7 22 8.5 BFGoodrich g-Force R1 S 225/40R18 9.0 24.9 21 9.0-9.5 245/40R18 9.7 25.4 23 10.0 Hankook Ventus Z214 225/40R18 8.4 25.0 21 8.5 245/40R18 9.1 25.6 24 9.5 245/40R18 9.1 25.6 24 9.5 Yokohama Advan A048 235/40R18 8.2 25.4 24 8.5 Hoosier R7 225/40R18 8.8 24.8 20 8.5-9.0 245/40R18 9.0 25.4 22 9.0-9.5 Hoosier A7 225/45R17 9.0 24.7 20 9.0-9.5 Hoosier Radial Wet H2O 225/45R17 8.8 24.8 21 9.0 245/40R18 8.7 25.5 21 9.0 Yokohama Advan A052 225/40R18 8.4 25.1 22 8.5 235/40R18 8.8 25.5 23 9.0 245/40R18 9.2 25.1 24 9.5 Any insight on sizing what will fit would be appreciated. Also any recommendations on the tires as well. This would be a dedicated setup for autocross and occasional track days. I hope to get coilovers this spring too.
__________________ 2006 Mazdaspeed 6 (recent acquisition, 49600 miles) CPE RMM; TWM Stage 2 short shifter; TWM A6 Leopard shift knob; JBR Shift Kit; GTX3071R; Corksport SRI with 3.5" MAF with TIP; Whiteline RSB; Sure Dreadnaught & Juggernaught rear diff mounts; CPE TMIC; CPE DP; CPE Dual Cat-back Exhaust; HKS BPV; HKS TT; Cobb AP tuned by EFI Logics; Cobb injector seals; 2007 Mazdaspeed 6 (212K miles & smiles, now destined to be a parts donor) |
| Not Ranked : 0 score I'm willing to bet one of @phate;'s threads will answer your question.
Really, if you don't have much experience autocrossing, just rock street tires for a while. Don't run Hoosier A's on a road course, they'll overheat way too quickly. Hoosier R's suck for autocross. In general, run the widest wheel you can, then size the tire to that. You can run a 9.5 with 255's on heavily rolled and pulled fenders.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
I'm considering running the MS6 this year but if I do, the car needs help in the tire department. THe previuous owner dumped all his money into the engine and drivetrain but nothing into the brakes, suspension, or tires.
__________________ 2006 Mazdaspeed 6 (recent acquisition, 49600 miles) CPE RMM; TWM Stage 2 short shifter; TWM A6 Leopard shift knob; JBR Shift Kit; GTX3071R; Corksport SRI with 3.5" MAF with TIP; Whiteline RSB; Sure Dreadnaught & Juggernaught rear diff mounts; CPE TMIC; CPE DP; CPE Dual Cat-back Exhaust; HKS BPV; HKS TT; Cobb AP tuned by EFI Logics; Cobb injector seals; 2007 Mazdaspeed 6 (212K miles & smiles, now destined to be a parts donor) | |
| The Following 2 Users Say Thank You to IT Gnome For This Useful Post: | mr_mazda329 (01-18-2019), phate (01-07-2019) |
![]() Join Date: Jul 2018 Location: Graham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
| Not Ranked : 0 score I kinda hate when people do that to these cars. If you wanted power without the ability to handle why not just get a Mustang instead of a Mazda? |
(Thread Starter) | Not Ranked : 0 score My feeling exactly. He also put aesthetic aero mods on it like the rear diffuser among others which I'm in the process of removing.
This is my 5 year and counting journey of turning the MS6 into a dedicated autocrosser for Street Prepared: MS6 Suspension Data & DIY Bilstein Coilovers Much of what you're considering boils down to budget and at what level you want to compete (and if you really want to stay in SM). Are you looking to stay local and have some fun with the car? Would you be willing to go a little smaller or even back to stock turbo? Or are you talking about a full bore autocrosser?
| The Following User Says Thank You to phate For This Useful Post: | IT Gnome (01-07-2019) |
The engine is built and tuned. I don't feel like messing with it at this stage so I'd end up staying SM. I haven't defined a budget yet either.
| Not Ranked : 0 score I was looking at TSW Nurburgring yesterday for summer tires. The 18x8.5+45. My only hangup is which color to get. Gray...or gray with machined face.
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score If your budget allows, Hoosiers all day every day. A7 for autocross R7 for road work. The Hankook 214s offer multiple compounds and are a much cheaper option and last a little longer. As Phate eluded too - one tire (compound) won't be the best for both applications.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
Maximize wheel width. You compromise tire contact patch and response by throwing a big tire on narrow wheel. 17x9.5 with a 245/40/17 R comp will work well. Slightly shorter tire than stock - works well if you tend to run lower speed autocrosses where you don't bang limiter but can still be up in the revs for boost. 18x9.5 with a 245/35/18 is the same story. This will be a little crisper since there's less sidewall. 18x9.5 with 245/40/18 works, too. If you have higher speed courses, these will give you a bit more top end speed. But it might suck coming out of really slow digs. You can run any of those combos without cutting fenders with proper offset. A 9.5 should be around +45 to be as far inboard as possible, and let you spacer it out a few mm if you get any rubbing. I ran 17x9.5 +38 Enkei NT03+M and had ~5mm of space to go inboard with a 255/40/17 street tire. Stock rotors and calipers are good. Upgrade to your pad compound of choice. Camber control is a MUST with R-Comps. You won't unlock their potential until they're happy, and you'll chew through the shoulders if you don't have enough. Expect a need for upwards of -3.5° of camber front and rear, ESPECIALLY if you have soft suspension.
| The Following 2 Users Say Thank You to phate For This Useful Post: | IT Gnome (01-07-2019), mr_mazda329 (01-18-2019) |
(Thread Starter) | Not Ranked : 0 score My wife and I both like the grey with machined face. I like the contrast.
The TSW Nürburgring does come in an 18x9.5+40. Would that work with the 245/35/18 tire? I have room to roll the inner fenders more. They're not a flat roll now but there's no pull which I'd prefer not to do. I saw a link to an article about proper sizing of tires in another thread somewhere. It mentioned that the rim should be the same to 0.5" wider than the measured tread width. The autocross courses are mostly of the tight technical variety. Almost all the drivers never get out of 2nd gear. I guess I can take my springs out and move the wheel through its suspension range to get an idea the clearances. The car only has the Eibach Prokit springs with the stock shocks. If I don't get coilovers, I figured on getting Bilstein B8 shocks at least.
| The Following User Says Thank You to IT Gnome For This Useful Post: | phate (01-07-2019) |
I have a set of Hawk HPS 5.0 pads for daily running but I have used Carbotech pads in the past and will probably use something like their AX6. Last year my wife and I used the Hawk Street/Race pads (DTC-30?) They worked quite well. I used them with Comar GS610 fluid.
I haven't used the AX6 compound, but I did like both the XP8 and XP10 for autocross. Since I went to the CS caliper with a smaller pad/less stopping power, I had to bump up to the HP+ compound and have mostly liked it. I have a set of DTC-30 in the garage for testing next season.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | ||||
(Thread Starter) | Not Ranked : 0 score The DTC-30 is noisy and dusty but it bites like the Dickens. Sent from my Moto Z (2) using Tapatalk
| Not Ranked : 0 score One thing about RComps is that they are much lighter than a regular street tire. They're easier to lock up if you stab the brakes, and pads with crazy bite can make it even more difficult. They also have way less feedback under both braking and cornering, so you have to be very cognizant of what the car is doing. The 6 has a very intrusive ABS system, so I run with the ABS fuse pulled.
| The Following User Says Thank You to phate For This Useful Post: | IT Gnome (01-08-2019) |
| The Following User Says Thank You to IT Gnome For This Useful Post: | phate (01-08-2019) |
HPS/HPS5.0 have no bite, but moderate overall friction. HP+ have high initial bite, and moderate-high overall friction. It's just because they're lighter - much easier to stop a lower mass rotating object than a heavier one, especially because we're talking about mass at the outer region of a spinning disc. Overall, RComps will brake WAY harder than street tires (and blend turning much, much better). We've pulled ~1.4g decel on rcomps vs ~1.2g on street tires. So, you still need a good amount of overall friction, you just can't slam you're way into full decel like you can with most street tires. You need to work with the weight transfer a little bit and get into rip-your-face-off braking force just a hair slower than skreet tires.
(Thread Starter) | Not Ranked : 0 score Phate, you said the Eibach Prokit springs are softer than the stock springs. The night I picked up the MS6, my wife was following me and at one point we turned to go up a hill and I gunned it. She noticed sparks coming from underneath as the car squatted down. Probably from the CPE exhaust which seems to hang a little low. Is there a better option for springs that don't squat as much and would work well with the Bilstein B8 shocks if I go that route? I'm not too concerned with being super low. A small drop is ok.
| The Following User Says Thank You to IT Gnome For This Useful Post: | phate (01-10-2019) |
| Not Ranked : 0 score I have a new set of Corksport springs if you don't want to do full coilover set-up. But most will tell you that coilovers offer much more bang for the buck. That's the reason they're still in the box.
Edit: There aren't any ots "spring kits" that offer any meaningful increase in spring rate. You're limited to ~20% stiffer than stock in a compromised rate split. For reference, my springs are over 4x stiffer than stock with a lot more front and rear bar on top of that.
| The Following User Says Thank You to phate For This Useful Post: | IT Gnome (01-17-2020) |
| New tire on RX-8 wheel | Atomic41 | Wheels & Tires - BLACK | 28 | 04-03-2016 05:44 AM |
| Picked up an autocross wheel/tire set, worried I went too aggresive | Kutakino | 2010 MS3 - Wheels & Tires | 7 | 05-15-2014 11:00 AM |
| Tire and wheel help Please | RUMBLEFISH | MazdaSpeed 3/6 - Wheels & Tires | 6 | 10-10-2008 06:52 AM |
