MAZDASPEED Protegé
> MSP - Engine, Transmission & Driveline
 Old 07-08-2012, 05:42 PM   #1
protespeed's Avatar
Posts: 7   (View Stats)
protespeed will become famous soon enoughprotespeed will become famous soon enough
Question busted rear motor mount??????
I just purchased a used 2003.5 and love it, I have noticed that the shifter seemed to raise and lower when I shifted gears. I jacked the car up and investigated I found that the rear motor mount were it affixes to the motor was missing. Upon further looking I noticed that the previous owner had some tranny work done and when re-installing the motormount he screwed the lower bot in an snpped the aluminum housing exposing half of the inner threads. My question now is how do I fix the aluminum and what size bolt woud be missing? Thanks
PROTESPEED
2003.5 mazdaspeed protege. Silver
protespeed is offline   Reply With Quote
 Old 07-08-2012, 05:49 PM   #2
The msp rmm is a bitch to get at, let alone fix. Looks like you bought a fuked car.
 Old 07-08-2012, 07:09 PM   #3
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
Rmm was one of the easiest direct replacement mods ever
But sounds like a much worse of an issue. Did you take a pic?
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 07-08-2012, 07:11 PM   #4
Front on msp is easy. Rear is a bitch. It's not a ms3...
helmetface (07-08-2012)
 Old 07-08-2012, 07:59 PM   #5
protespeed's Avatar
Default i will try to get a pic
I wil fix the mfr if I have to pull the motor, ain't scared.
PROTESPEED
oem rear motor mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-21-2010 03:08 PM
another SU REAR MOTOR MOUNT armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-23-2009 06:45 AM
Page generated in 0.24770 seconds with 22 queries
