5Likes ![]() |
![]() Join Date: Sep 2014 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
(Thread Starter) | Not Ranked : 0 score This is how I first got her... Engine, Etc.: AWR Solid Motor Mounts Short RAM Intake Pipe Silicone Intake Air Filter Straight Exhaust Pipe from downpipe back Catalytic Converter deleted Newer NGK Spark Plugs New Coil Packs New Ignition wires MAF sensor relocated to cold pipe Front mount intercooler Hard Pipes TurboX's blowoff valve Forcedfed steering column pod Appearance: White powder-coated OEM Rims 6K HID headlights Windows tinted 5% Interior: Genuine Italian leather shift boot and parking brake boot Sony touchscreen head unit Two 12in Alumni subwoofers Added mods: s204 Subaru STI front lip Urethane sideskirt extensions Removed the tint Future mods: 5mm wheel spacers Fog light HIDs Maybe lowering springs for a 1"-1.5"inch drop Maybe plastidipping wheels a matte titanium grey When I first got her: First received MSP.jpg Then removed decals and added s204 lip Then added sideskirt extensions ![]() ![]() Last edited by Illa Noize; 12-30-2014 at 11:00 PM. |
![]() Join Date: Sep 2013 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score looking good
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
![]() Join Date: Jan 2014 Location: Sacramento
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score engine bay shots?
__________________ 2003.5 BLAZING YELLOW Mazdaspeed Protege FMIC|Potenza S-04 Pole Positions|P5 Transmission W/LSD Delete (Blew 2rd/3rd/4th in MSP trans) [COLOR="yellow"[/COLOR] AWR MM Tetralogy (70 Duro)|Havoc bumper plates|New pads + Slotted Rotors|Iridium Plugs Awaiting install:New pads + Slotted Rotors 2008 Black Mica MS3 Sport |
(Thread Starter) | Not Ranked : 0 score Thanks guys. Here's the bay: |
![]() Join Date: Dec 2013 Location: Pinckney, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 794
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score wow cleanest ive ever seen one, usually these things are hit.
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 |
(Thread Starter) | Not Ranked : 0 score Thanks bro. Yeah I intend on babying mine. I wanna say, I hit 7psi once a month, if that. Lol. Other than that I always try not to hit boost and if i do its really low like 3-5psi. I know the car isnt fast so I dont drive her like she is. I just plan on lowering here just a tad and DD her for the rest of her life. |
| The Following 3 Users Say Thank You to Illa Noize For This Useful Post: |
| Not Ranked : 0 score I dig it. Interesting way of running the piping for the intake. Any better pics? Sorry for asking for more pictures, I've just never seen the way yours is set up. Lol. Also, how is the turkey call with that bov? tappa...
(Thread Starter) | Not Ranked : 0 score The bov is great. I love the sound. No problem. I'll take some pics a lil later on today. |
(Thread Starter) | Not Ranked : 0 score A closer look: |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score When does the build portion of the thread start?
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following User Says Thank You to Neverlift For This Useful Post: | Easter Bunny (01-07-2015) |
(Thread Starter) | Not Ranked : 0 score Lmao. It's more of an appearance build. Not really touching the engine. |
| The Following User Says Thank You to Illa Noize For This Useful Post: | Nel Mazdaspeed (01-04-2015) |
| The Following 2 Users Say NO Thank You to Illa Noize For This Un-useful Post: | Easter Bunny (01-07-2015), Neverlift (01-04-2015) |
| Neutral : +1 score /thread tappa...
| The Following 3 Users Say Thank You to HFDSpace-Junk For This Useful Post: |
![]() Join Date: Sep 2011 Location: Newington, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score Ah damn, I'm disappointed. I was expecting an auto-x build or something from the title
__________________ Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon... |
| The Following User Says Thank You to plak424 For This Useful Post: | Illa Noize (01-07-2015) |
(Thread Starter) | Not Ranked : 0 score I'm considering upgrading to forged internals and lowering springs in the near future. Just takes a lil time. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
| Not Ranked : 0 score |
![]() Join Date: Jan 2012 Location: Mesa, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 620
| Not Ranked : 0 score Nice car and I really doubt you can resist building that hoe up and make some power. Surprise some of those cocky faggots on the road with more expensive car's than you |
(Thread Starter) | Not Ranked : 0 score Trust me, I wud love to do that. I'm gonna be working from home, so that means saving money on gas and wear and tear on the car, which means more money for the build. I'm thinking tax return time well see some major changes. |
| Not Ranked : 0 score Just remember to plan out everything and do it right the first time. Don't just throw money at the car and expect huge gains. I feel so bad when people do that and then sell the car because they are disappointed. Honestly, slap a pope manifold and downpipe with a 3" exhaust and free flow cat, MBC, theb crank the boost up to 10 psi and have fun with it. tappa...
| Not Ranked : 0 score Just personal preference, but put a hi flow cat in there. The ecu does screwy shit with the AFRs already. Keep it happy. Remember, this motor is just an NA motor with a turbo slapped on. And it HATES going lean. Cat will help combat that. tappa...
(Thread Starter) | Not Ranked : 0 score The bare beginning of the mod build |
| Not Ranked : 0 score Factory or forge adjustable? tappa...
(Thread Starter) | Not Ranked : 0 score Atp, non adjustable. Set at 6-7psi |
![]() | | #24 | ![]() |
![]() Join Date: Aug 2014 Location: Illinois
| Not Ranked : 0 score That lip looks sick how much did you pay? |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score It was like $50 I think. Subaru 06 s204 lip. |
![]() | | #26 | ![]() |
![]() Join Date: Apr 2013 Location: MI (near the edge of the earth)
Rep Power: 0 ![]() Thanks: 0
I Agree. Awesome look and improved high speed function with that lip. Once you mod your motor, you should take her to the track and test it out. I am also still working on a long term fix for my Sway bar bushings (every 10k miles replace) and tig welding flange nuts into the rear cross member where the old nuts don't hold. Last edited by DarkProto0D; 01-24-2015 at 09:35 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
| Not Ranked : 0 score All gears or just first? Mine hits 9 -12 psi in first. Only thing I can think of that may be causing that is a failing BPV. Sent from my PipBoy 2500
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score The valves seemed to be fine. I need to recheck them cuz I did only a brief inspection on them when replacing the wga. I think I was in second or third when it happened |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Completely forgot you were running a BOV. Oops. Sent from my PipBoy 2500
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score ![]() Should I get ace concave, tenzo, or xxr wheels? |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I offer another suggestion... a nice set of fd wheels Sent from my SAMSUNG-SM-N900A using Tapatalk |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Just a suggestion and yup fd rx7 wheels. They're light, look great, and usually affordable. Whatever you choose is going to look good on a msp, lol Sent from my SAMSUNG-SM-N900A using Tapatalk |
![]() | | #35 | ![]() |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score Out of the 3 which ones should I get? Here are the specs: Str 607 18x8.5 +35 $173/wheel Str 601 17x7.5 +38 $190/wheel ![]() Privat akzent 18x8.5 +40 $216/wheel ![]() In the future I might get lowering springs with a 1-1.5 inch drop but not sure. I may just stick with stock height. |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score My new setup. ![]() Sent from my SM-N920T using Tapatalk |
| Product Release! Mazdaspeed Protege / Mazda Protege Front Motor Mount | CorkSport | CorkSport | 0 | 02-22-2013 10:10 AM |
| Paris: 2014 Ford Transit Connect adds form to function [w/video] | Haltech | Automotive News | 0 | 09-27-2012 11:20 AM |
| Form follows function? Hamann Aston Martin V8 Vantage | Haltech | Automotive News | 0 | 09-24-2008 06:20 PM |
