![]() Join Date: Jan 2010 Location: Columbia, SC
(Thread Starter) | Not Ranked : 0 score Hi all. I had a brake line go out on me a few weeks ago. Being a full time student with a full time job (plus some part mix ups) I didn't get a chance to fix it until yesterday. I got the new line installed, the brakes fully bled and went to take it for a test drive. Unfortunately the battery was dead. No biggie, so I jumped it. It cranked for a bit, halfway started and then died. I had advance charge the battery for me and put it in last night. Since then it has done nothing but crank without starting. It was running great before I parked it. I can hear the fuel pump and it smells like gas after cranking it a few cycles, so it's getting fuel. The other mystery is that it's not throwing any codes. I've checked all the fuses and none are burnt. The immobilizer light is acting like normal, and everything seems to be in good operating order it just won't start. I'm just wondering if there's anything blatantly obvious that I'm missing.
__________________ 2007 Mazdaspeed 6 GT-AP v2, CPE SRI, COBB TIH, AUTOTECH FP INTERNALS, CPE 3" TBE, FORGE BPV, AND ALL THE MOUNTS [SIGPIC][/SIGPIC] |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Check the battery again. If it so happens it’s drained, you either have a bad battery or a bad alternator.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
| Not Ranked : 0 score If you smell a lot of gas and think it might be getting flooded, hold the pedal to the floor while cranking to clear it out.
(Thread Starter) | Not Ranked : 0 score I let it sit for a whole day. I think it's fine but I'll try it tonight.
| cranks but wont start | BigRed06 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 09-20-2015 12:06 PM |
| MS6 Cranks but won't start HELP!!! | KingJames | MazdaSpeed 6 - Engine, Transmission & Driveline | 16 | 03-23-2015 06:38 AM |
| Car cranks, won't start | 15driley15 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 04-23-2014 04:51 PM |
| Ms6 cranks but wont start | maniospeed6 | Mazdaspeed3/6 General Discussion | 4 | 03-26-2013 09:08 PM |
| Car cranks but doesn't start after valve clean | InfamousSpeed6 | Mazdaspeed3/6 General Discussion | 11 | 11-29-2012 06:17 PM |
