ABS and Traction Control Light's always on and the system's are not functioning. After getting my 2007 Mazdaspeed stuck in the snow in my driveway again I noticed my ABS and Traction control light were on and would stayed on. I've driving it at least an hour already and they are still on. The abs and traction control are both not functioning now also. I have tried pushing the DSC button and it dosen't do anything. I have even unpluged the battery. I have no clue what to do and google can't find anything. I don't want to have to take it to the dealership again because that is getting real expensive. Please help if you have any idea how to fix this. Thanks. |
Mazdaspeed 3 or 6? It's possible that a wire to one of the wheel speed sensors or ABS plugs was damaged or came loose. Check behind each wheel for any loose or damaged wires/plugs. You may want to unplug and clean the plugs out, it may just be that a bunch of crap got into one of the plugs and it's sending a bad signal. Check the fuses too (and first), it's always possible that one of them blew. |
It's a mazdaspeed 3. So there are sensors in the wheel wells or something? There was a lot of snow lodged in there. |
When you got stuck in the snow, did you hit anything? Check the fuses first followed by the connection to the sensor like @keymaster; said. Other then that you may have damaged the sensor it self. When I hit a curb they had to replace the sensor, hub bearing and then reset the sensor in the computer. |
Quote:
Thanks! Any chance there are diagrams or pictures of where or what these sensors look like? |
Check the fault codes. Those modules generate faults. |
Quote:
And Lex is right, the warning lights should be generating codes that you can pull and look up...you'll need something to do that with. I think a ODBII scanner will read those as well, but don't quote me on that...that would include stuff like a Dashhawk or AP, anything that can pull codes. Auto parts stores used to read those codes for free, I recently heard some aren't doing it anymore. Check for a local meet, someone probably can help you out with that. |
What was the reason? |
Quote:
Quote:
Quote:
| All times are GMT -7. The time now is 06:25 AM. |
