![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
(Thread Starter) | Not Ranked : 0 score I did a log the other day and I checked it out and saw my AFR never moved from 14.85 (dont monitor AFR on the AP because I have an external AFR gauge). Obviously something was wrong, found the culprit pretty quick too (see attached picture). No biggy, ordered a new O2 from rock auto, got it 3 days later. Planned to install and be hunky dory and back on the road. Installed the new O2 and still cant get my car to read anything but 14.85 (on the AP now). Things I have done so far: Reflashed my map Unhooked the battery for 30 min Unplugged and re-plugged in the sensor Checked the sensor pins Bench tested the new and old O2 Via this method: Driveway Diagnostics - Bad Oxygen Sensor - Jp Magazine All my on car testing yielded no results. On the bench, I couldn't get the volt meter to work for either O2 so Im not sure if Im doing it right, or if both are bad. Before I try and make a return to Rock Auto and get a new one (still not sure if the one I have is bad or if its the car), I figured I would see if any one else has any suggestions on what to check. My car hates me so its probably the most obscure thing possible.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score I had this same problem before I blew up cus my car was originally hydrolocked which most likely fouled one of my sensors. I am built now so I just bought 2 new OEM O2 sensors for when I put it together this past weekend. If you are only doing this to the primary sensor, you might try doing it to the secondary one too.
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's |
Groans: 75
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC | |
| The Following User Says Thank You to maisonvi For This Useful Post: | WetzMS3 (10-06-2015) |
I guess it wouldn't hurt if you did it. I take it you don't have an AFR gauge?
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's | |
Groans: 75
I do have an AFR gauge I mentioned in the OP.
Sorry I haven't given you much usefull information. I wouldn't worry about it since you have an AFR gauge but I know how it goes to make sure everything is running right. I hope you find the solution to the problem!
Groans: 75
(Thread Starter) | Not Ranked : 0 score The gauge only tells me what the AFR Im hitting is. I need the primary O2 to read correctly to tell the ECU what to do. If its not reading right, the system doesnt know how to fuel properly. Letting it just be stuck at 14.8 could be terrible for the motor.
| The Following User Says Thank You to maisonvi For This Useful Post: | HawkeyeGeoff (10-06-2015) |
| Not Ranked : 0 score I know you are tight on money but did you try replacing with an OEM O2? Maybe the Rockauto one was for a normal Mazda 3 and not the speed 3? I know some things are switched on that website.
Groans: 75
(Thread Starter) | Not Ranked : 0 score The one I bought from Rock auto is an OEM O2 sensor.
| Not Ranked : 0 score Hm. I'm not sure then. Sorry again that I couldn't help you..
| The Following User Says Thank You to zjnspeed3 For This Useful Post: | maisonvi (10-06-2015) |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Did you try the thingy-ma-bob @maisonvi; I heard that works
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
![]() Join Date: Jul 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 301
| Not Ranked : 0 score Since you installed a new O2 and that didn't fix the issue is there something else that could be causing the issue? Have you tinkered with anything else recently that may be skewing your AFR's? Are the connectors themselves in good condition? Not too savvy when it comes to trouble shooting just thought I would throw some ideas. Hope you get it figured out. |
| The Following User Says Thank You to Erick13Speed3 For This Useful Post: | maisonvi (10-06-2015) |
Groans: 75
I'm putting money on either A. Faulty replacement or B. wiring.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD | |
| Not Ranked : 0 score Is it throwing any codes? I agree with Geoff on both points. Any way you could swap to a known good sensor from another car?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following User Says Thank You to phate For This Useful Post: | maisonvi (10-06-2015) |
Groans: 75
(Thread Starter) | Not Ranked : 0 score No codes. I had a code with the old bad one. Nothing with the new one. I hopefully will have a bit of time tonight to try and reinstall it and check the wiring.
![]() Join Date: Jan 2012 Location: westland , mi
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score Did you get anywhere with this? @maisonvi;
__________________ 2012 Cadillac CTS-V ![]() 2014 focus st ![]() 2010 Taurus sho- sold 2009 speed 3 gt cwp -was once a monster -sold |
Groans: 75
I pulled everthing out and tried to check contunity between the ecu connector and where the O2 plugs in, but I get nothing on any of the spots. Which means one of 2 things: either A: All 3 of the wires are broken/fried or B: Im doing it wrong. I tend to lean towards B. So now I plan to un wrap all the wires and see if anything is broken anywhere. then maybe go about replacing them all. Yay...
| Not Ranked : 0 score I understand that your added AFR gauge works and read something that move when you change the engine running conditions. Then your OEM AFR from the oem sensor is pinned to 14.85 but you don't know when it quit working because you don't check it often? If the AFR is really at 14.85 constantly, our LTFT/STFT are going to be maxed out on the low side and this should give a cell ? How reading of the added gage compare to the oem one ? 1 You can't mix speed and mz3 sensors because the speed use a wideband as the primary VS a narrowband for the mz3 and any secondary probes. 2- You can compare the value from Cobb AP with an OBD2 bluetooth dongle and Torque or another APP on your cell phone. That one could gives primary and secondary reading from the oem probes. For the wiring, i would check critical region first. There isn't much current into that circuit to overload the wires so it must be a mechanical issue. I would check around the exaust for burned wires. Then check if you have something that could squeeze the wire harness...(usually new parts install) You can also check for screw into the wire harness...(i did see that once...) Then you could check all the connectors. start at PCM and look for loose or bent terminals. Check other plugs for the same thing... Not sure if a fuse is used inside that circuit...It won't hurt to check them too.
Groans: 75
From what I can tell via the shop manual there isnt a fuse in the line at all. I am thinking about hooking eveyrthing back up and checking if Im getting any voltage movement on the wires when the car is running.
look at this info: How 5-Wire Sensors Work (Tech Edge)
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
Groans: 75
![]() Join Date: Dec 2013 Location: Scranton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I had something short out on me awhile ago causing my car into limp mode and my AFRs to stay around 14. Check your eng bar fuse. It's quick and something to try. Just thought I'd throw in my suggestion
__________________ 2006 Mazdaspeed 6 rebuilt with v6 rear end CPE TMIC || Cobb SRI + TIP || Grimmspeed 3 port EBCS || Forge BPV V1 || UR Test Pipe || CPE Single Exit Exhaust || JBR heavy shift knob and shifter bushings || JBR RMM || SU short throw || Corksport Stubby antenna || Glowshift boost and voltage gauges || CS Mudflaps |
![]() | | #24 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score I had this happen to me before. My results were hopefully more painful than yours. Ended up being an ECU. Although with my issue, it would peg the AFRs ta 14.85 for a few minutes (5-10 IIRC) then start reading (among other issues). I am told sometimes that the AP may not read back AFRs (instead it'll show 14.85) until the O2 is up to some internal temp. Sorry if I missed it, but are your AFRs actually affected? As in, does the car actually function correctly outside of the AP not reading correctly, or does it stumble all the time, or maybe at just part throttle?
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
![]() | | #25 | ![]() |
| Not Ranked : 0 score @maisonvi; Did you ever find out what caused the damage to the first one? It kind of looks like heat damage. If that's the case then I would definitely be chasing wires. Heat causes resistance and excessive resistance can cause wires to burn up.
![]() | | #26 | ![]() |
Groans: 75
I really have had zero time to look at this in the past 2 weeks. I just got to looking at it and I think I found the solution, a tiny break in the ENG BAR3 fuse. I couldnt really even see it but my meter says it not connected. I will get a new fuse and put it all back together. Hopefully that fixes it.
| The Following 3 Users Say Thank You to maisonvi For This Useful Post: |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Good one. it is harder to find a broken fuse that isn't blown.
![]() | | #28 | ![]() |
![]() Join Date: Oct 2014 Location: North Texas
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Just wondering did a new ENG BAR Fuse fix the problem? i have intermittent AFR stuck at 14.85 with P064D code. |
![]() | | #29 | ![]() |
Groans: 75
(Thread Starter) | Not Ranked : 0 score Yeah, it had the tiniest of breaks in it. It looked fine holding it at arms length, but up close you could see that it had separated. Only way I found it was testing all my fuses with a multimeter.
![]() | | #30 | ![]() |
| Not Ranked : 0 score Checked all my wires and fuses and everything was good. Found another discussion and someone said he replace spark plugs and that it helped him. I had I think about 20kish on mine. Replaced them and haven't had a problem with a stuck AFR at 14.85 or code p065d. I've seen a few other forums on SVT sites having similar problems and they are always followed with misfires. I personally didn't feel any large misfires, but it might have been small ones causing the PCM to think the o2 is malfunctioning. Just my opinion though. But I replaced spark plugs again with Denso ITV22 set at .028" and been running great with no problems. Hope this helps. Last edited by Texasgunslinger9; 03-06-2016 at 06:20 PM. Reason: grammar |
| HU stuck | sega_rt | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 06-14-2013 11:32 AM |
| Stuck Axle... help! | mczimer | Mazdaspeed3/6 General Discussion | 11 | 09-24-2012 01:57 PM |
| tcs light stuck on | turd burglar | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 05-26-2010 06:30 PM |
