AFR stuck at 14.85 - HELP Hello everyone, The AFR on my accessport V3 is stuck at 14.85. I noticed the problem when it would intermittently peg at 14.85 but then work normally. I know the car isn't actually running lean and in fact is running rich for many reasons; the exhaust smells like fuel, the spark plugs are carbon fouled, my fuel consumption is really high and my LTFT are pegged at 20. This is because the 14.85 AFR is being read and trying to be corrected. Im getting the codes: P2187 - lean at idle P2177 - lean at off idle and the code for o2 sensor low voltage which I forgot the code for I've replaced the o2 sensor already and need more ideas on what to look for. Is it possible I bought a dud o2? Is the problem with my harness? |
There are two O2 sensors. If your AFR is pegged at 14.85, then it is probably your primary O2 sensor that has failed. If you only replaced the secondary, then that wouldn't have addressed the issue with the primary sensor. Also, did you buy a new O2 sensor, or was it used? If it was the latter, there's every chance that the sensor was already fouled by the time you got it. |
Quote:
Have you captured logs of and/or monitored O2 voltage? I think it should be like a waveform going up and down on the primary if i recall... If your AFR is static I would assume the signal would be as well coming from the O2 sensor. Also, what intake are you running? I had crazy high LTFTs (15-20) w/ the MSCAI, adding the air straightener brought it down to 5 in less than 5 min idling. My exhaust wreaked of gas too, super rich. |
Quote:
And I think my LTFTs are so high because for some reason my ecu is reading an AFR of 14.85. If the problem was with the AP for example, the car would run normally because the o2 sensor is actually working, but the AP is not. |
The AP is not the problem, though your tune could be an issue. Could you please post a full list of your modifications? That may help us assist you in diagnosing your issues. In fact, if you could put your full mod list in your signature, that would streamline future diagnoses. |
Quote:
OK, and if I recall correctly, you're running a Cobb OTS stage 3 93 tune. That tune is, at least theoretically, reasonably appropriate for the modifications on your car. So... That brings us back to electrical issues (i.e. sensor/wiring harness/harness connections/etc.). You might want to check out this thread: http://www.mazdaspeedforum.org/forum/foru...4-85-a-193982/ There are a couple of possible solutions in there, ranging from replacing a bad fuse or changing spark plugs, to having to replace the ECU. As a place to start, you might want to try checking the ENGINE BAR fuse. |
Where do we get our AFR data, is that not from the 02 sensor? |
Quote:
Is there a thread that explains how to test if the female connectors on the wiring harness are good or bad? I'm guessing testing for continuity or something? |
Quote:
Is it possible the person at autozone sold me the wrong o2 sensor? Could someone tell me what the part number is for the primary o2 sensor for a gen 1 ms3? |
you might want to return that, drop more coin and get an oem sensor. |
Quote:
Anyone know which one I should get from rock auto? They have many options. |
I feel like you might be jumping the gun here, have you made any efforts to see if there is valid sensor output yet? Beyond the AP or a BT adapter you can probably back-probe a connector. |
So correct me if I'm wrong but isn't there a bunch of threads stating to stay away from aftermarket O2 sensors? Maybe it's just me and I'm full of shit but keep wasting time and money on a different aftermarket ones or just buy an oem one and be done if that is indeed your problem. I get it they are expensive and it'd be nice to put that money on towards a tune. |
Quote:
Quote:
NGK/NTK and Denso are fine. |
Quote:
Could you post a couple of datalogs including some at idle, and at least one WOT log from ~3000rpm to at ~6000rpm? |
Quote:
https://cobbtuning.atlassian.net/wik...talog+Monitors And to log: https://cobbtuning.atlassian.net/wik...How+To+Datalog |
Gen 1 OEM primary O2 sensor: https://edgeautosport.com/mazda-oem-...d-6-2006-2007/ Be sure you get the Gen 1, as Gen 2 is different. |
Quote:
Maybe check for corrosion or damaged wires in the o2 sensor and ECU plugs. |
Quote:
Is there a diagram that shows what each pin in the ECU plug is for? That would help alot. Quote:
There are a couple of wiring diagrams (including pinouts for various components) for the MS3 and MS6 in the VIP section. I think there's only one for the GenPu MS3 though most things should still be the same in the engine compartment. If you're getting strange behavior at WOT, then if you can capture a log that shows what's going on, that will help a lot. Please make sure that you're datalogging at least the following parameters: Accel. Pedal Pos. Actual AFR Boost Boosted Air Temp Calculated Load Coolant Temp Engine Speed (RPM) HPFP Actual Pressure Injector Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term FT (LTFT) MAF Voltage Mass Airflow Short Term Fuel Trims (STFT) Spark Advance Throttle Position Vehicle Speed Wastegate Duty Cycle |
Sorry, I may be wrong but I thought cobb ots did not have a tune for a catless dp. |
Quote:
Quote:
4 Attachment(s) Quote:
Yep...that definitely looks like a bad O2 sensor reading to me. Are you sure the connectors are fully engaged for the O2 sensor pigtails? Are the pins in the connectors in good shape? |
Quote:
Got a new code though, P0140 - Bank 1 sensor 2; no activity No other new codes. |
Sounds like you should probably check/replace your secondary O2 sensor! Also, you might want to read this thread: http://www.mazdaspeedforum.org/forum/foru...9-p0140-46971/ It's possible that you have some debris in your exhaust system. |
Quote:
Quote:
Quote:
My turbo blew a long time ago. Disassembled all piping and there wasn't much metal in the piping or intercooler, nor in the oil pan magnet. |
I'm not sure about that, but it may have to do with the number of drive cycles that the ECU needs to go through after each ECU flash before it can determine that there is a fault with the secondary O2 sensor. |
Sorry if i missed this info above, but: what happened to your original OEM O2 sensor? Was that a casualty of the blown turbo? Or oil leakage leading up to the blown turbo? |
Quote:
Quote:
Possibly a wiring harness rubbed through on an engine component. I might start looking near hose clamps next to the ECM harnesses as this seems like a common failure point. |
1 Attachment(s) Quote:
| All times are GMT -7. The time now is 06:06 AM. |
