![]() Join Date: Apr 2015 Location: NyC
Rep Power: 0 ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Wassup guys so my speed6 died on the highway yesterday. Blew the 15 amp engine ignition fuse. Found voltage at coil #2 signal wire and traced it back to a burnt computer. Question is has anyone rewritten the VIN to a used computer and Ware you able to un mary your access port it keeps saying to connect to the car.
__________________ CorkSport SRI & TIH, CorkSport high pressure internals, ETS TMIC |
![]() Join Date: Feb 2012 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score You should contact Cobb and explain the situation.
__________________ 2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017 Power: BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth Handling: KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate Other: Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35 |
| Burnt oil smell | gmpetrov | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 05-27-2017 07:35 AM |
| another burnt valve | thebestdj07 | Mazdaspeed3/6 General Discussion | 11 | 10-19-2014 05:56 PM |
| Burnt Clutch? | jeffreyj | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 10-19-2012 08:44 PM |
| Burnt my seat | Snotrocket | Interior | 38 | 04-04-2011 06:50 AM |
| Oil smells burnt? | SRTie4k | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 11-16-2009 08:17 AM |
