![]() Join Date: Jan 2013 Location: St. Charles, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 148
(Thread Starter) | Not Ranked : 0 score 2006 ms6 100% stock. 113k. Went into a gas station a couple days ago, came back, car wouldn't start. Did some reading thought it was an electrical issue, jumped the neutral safety switch, and got the car to start/run for about 45 seconds. To my dismay, the car dies. I find that the connection I made was no good, attempt to quickly repair it, but the car never started again. ![]() So i tow the damn thing to my house, and crawl back up under the dash and legitimately bypass the NSS so that I know it's good. (Car cranks without use of the clutch pedal now) ...but the car will not start. I just changed spark plugs today. Car is behaving the same. My next suspicion is fuel pump? Anyone have a way to potentially test an hpfp? I need this thing running and I'm pretty frustrated.
__________________ 2006 Velocity Red Mica Mazdaspeed6 GT #04425 Stocked out and hella slow... ![]() |
(Thread Starter) | Not Ranked : 0 score Bump... Really could use suggestions here
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
Groans: 32
| Not Ranked : 0 score Wish i could help, hope u get it sorted out bud Sent from my LG-LS980 using Tapatalk
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Well, it's going to be spark, fuel, air. Fine out which one you don't have. You mentioned you changed your plugs. See if they're hitting.
__________________ |
![]() Join Date: Sep 2013 Location: Seattle WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score what are the odds that it could be the in-tank fuel pump? i never hear about problems with them on these cars though, I'm just throwing something out there... keep us posted on this, always good to know about issues and the resolution...
__________________ 2007 Mazdaspeed 6 GT 2003 Ford Ranger XLT |
![]() Join Date: Dec 2011 Location: Dartmouth, N.S., Canada
| Not Ranked : 0 score I assume your lights and dash light up and you hear the various start up electrical noises? The same thing you're describing happened to me last week and it was the white wire that connects to the starter. This happens a lot from what I've read in here. It's the first thing I thought of when my car wouldn't start and that's exactly what it was. I'm not sure if it happens a lot on the 6 or not. It might be worth checking. |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
you really need to get with someone who has an AP and check fuel pressure and see if there are any silent check engine lights hidden without triggering the light | |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score From what he is saying the starter is turning but the car wont start. Listen for fuel pump under rear seat driver side. Take rear seat bottom out if have to, should be able to hear it. report back if you hear it or not.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
![]() Join Date: Feb 2013 Location: Auckland, New Zealand
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 217
| Not Ranked : 0 score Yes try to listen for the fuel pump noise: Check the fuse of fuel pump too, had a similiar problem with my RX-8 previously. Once I have replaced the fuse there has been no more issues.
__________________ 2004 Mazda RX8 - Bone Stock - SOLD 2010 Mazda 3 MPS K&N SRI | GFB BPV | Cobb TIH | Cobb AP v3 - Freektuned |CS Internals|OBX Cat Back + Test Pipe | JBR 70a RMM | JBR RSB|JBR EGR block off plate|JBR SSP + Solid Bushings |Denso ITV 22| Ultra Racing Front Strut Bar| Ultra Racing Rear Strut Bar | Bridgestone RE002 225/40/R18 Tyres|CS Brake Pads|H&R Lowering Springs| DBA T3 Slotted Rotors |Goodridge SS Braided Brake Lines Non performance parts: 35% Tint | Blacked Emblems | Painted Wheels |JBR Heavy Shift Knob | CS Tow Plate | [SIGPIC][/SIGPIC] |
| Ms6 cranks but wont start | maniospeed6 | Mazdaspeed3/6 General Discussion | 4 | 03-26-2013 09:08 PM |
| Car cranks but doesn't start after valve clean | InfamousSpeed6 | Mazdaspeed3/6 General Discussion | 11 | 11-29-2012 06:17 PM |
| GM cranks up no-frills car output in China | Haltech | Automotive News | 0 | 11-18-2012 06:50 AM |
| Coda cranks up battery-car sales after California 'soft' start | Haltech | Automotive News | 0 | 09-12-2012 11:40 AM |
| Toyota cranks up N.A. output | Haltech | Automotive News | 0 | 08-12-2012 10:10 PM |
