 Old 10-08-2019, 03:37 PM   #41
AlanSpeed3's Avatar
Posts: 4   (View Stats)
AlanSpeed3 is an unknown quantity at this point
Originally Posted by KCi View Post
UPDATE: This is maybe useful to the MSF community here. I sent my MS3 back to dealer and they have been very supportive in debugging the erratic idling and rich AFR. They changed MAF, O2 and other (which I forgot to ask) sensors and yet still the same. They even ran test on HPFP and coil packs and not helping.
At last, they found the culprit at throttle body. The throttle body apparently sending inaccurate signal back to ECU for AFR compensation. They noted that I had the coolant bypass done and they said this is bad to throttle body. The coolant apparently used for reducing heat produced by the drive-by-wire circuitry at throttle body.
No matther what, it does solved the problem. What do you think of coolant bypass at throttle body?
So what part did they change?
AlanSpeed3 is offline   Reply With Quote
 Old 10-09-2019, 07:17 AM   #42
Posts: 2,827   (View Stats)
It’s right there in the quote. The throttle body.
“At last, they found the culprit at throttle body. The throttle body apparently sending inaccurate signal back to ECU for AFR compensation. They noted that I had the coolant bypass done and they said this is bad to throttle body.”
If only I was as rich as my car is running... MaverickX3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-04-2013 01:28 PM
Running Rich in 1st and 2nd Gear ms3destroyer MazdaSpeed 3 - Engine, Transmission & Driveline 0 09-16-2012 06:47 PM
running rich? i need help ericdebruyn1 Mazdaspeed3/6 General Discussion 7 07-25-2012 07:10 PM
Running Rich in 1st and 2nd sallyspeed3 MazdaSpeed 3/6 - ECU Computer Tuning 12 05-31-2012 12:17 PM
Car running rich SilkySpeed3 Gen2 MS3 General Discussion 8 03-29-2012 02:28 AM
Page generated in 0.23253 seconds with 22 queries
