  • 1 Post By GODspeed7
 Old 09-05-2012, 04:06 PM   #1
J'sSpeed3's Avatar
Posts: 722   (View Stats)
J'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the world
Groans: 76
Default Help please. Broken shifter cable?
First, I did search. And I'm hoping it's not a broken shifter cable... Any input? Thanks in advance!
Ok, so I have the JBR SSP, bushings, counterweight, and FOMOCO tranny fluid. JBR products have been on for around 5-6 months and Tranny fluid in there for about a month maybe 2. Yesterday, the shifting was perfect, the same it's ever been. Last night, I went in and re-gapped the spark plugs and started it up this morning.
I drove the car to class and the shifting felt terrible. As you can see in the video, there is a ton of play back and forth while the car is in gear, and it barely takes any force to move it like that while I'm driving.
Also, the shifts seem to go in like butter, almost too easy. When it is in gear, it feels like it's barely held in gear, and will easily come out of gear with hardly any force. Idk what else it could be or what exactly to look for. Torn rubber part around the cable?
Thanks for the help guys!
| 2007 True Red Mazdaspeed 3 GT |
GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV |
SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate |
J'sSpeed3 is offline   Reply With Quote
 Old 09-05-2012, 04:11 PM   #2
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Video Link: http://www.youtube.com/watch?v=C0gOxdmBsZM
Did you even check the SSP and the linkage around it? Could have come lose or gotten hung up.
2012 Mazdaspeed3 Black Mica
 Old 09-05-2012, 04:18 PM   #3
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
Yeah, we'd do better helping if we had a pic inside the engine bay. Check the SSP, see if something came loose. Check he shifter cable and the cheap ass plastic connector. Give us a pic man.
Stealth01
2006 Mazdaspeed6 GT
 Old 09-05-2012, 04:37 PM   #4
J'sSpeed3's Avatar
Groans: 76
Thanks guys! I think I found the problem. Somehow the riser came loose which is really weird. In the pic you can see how it's crooked. Somehow I overlooked it the first couple times, but I just got a friend to shift it for me while I watched. Thank God that's all I have to do is tighten it I was getting worried lol
Has anyone else had this problem? I don't want it to keep happening.
 Old 09-05-2012, 04:38 PM   #5
Stealth01's Avatar
Groans: 201
Loctite is your friend!
Stealth01
2006 Mazdaspeed6 GT
The Following 3 Users Say Thank You to Stealth01 For This Useful Post:
daztdMS6 (09-05-2012), J'sSpeed3 (09-05-2012), Pseud0logik (09-05-2012)
 Old 09-05-2012, 04:40 PM   #6
J'sSpeed3's Avatar
Groans: 76
I put loctite on it when I installed it lol that's the weird thing idk how it would come loose like that
 Old 09-05-2012, 04:48 PM   #7
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
Same thing happened to me a few days after I installed my shift plate. I tightened the shit out of it and it didn't come loose again, even without loctite.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
 Old 09-05-2012, 05:14 PM   #8
J'sSpeed3's Avatar
Groans: 76
Ok I got it figured out thanks guys!
Anyone who reads this. PUT LOCTITE ON THE RISER!! That shit might come lose and I wouldn't risk it if I were you.
Mods you can close this down if you'd like. Problem has been solved
 Old 09-05-2012, 05:34 PM   #9
GODspeed7's Avatar
Red loctite that bitch until it looks like a used tampon! And hooray for me diagnosing a problem on a part that I don't even own!!! LOL
Stealth01 likes this.
The Following 4 Users Say Thank You to GODspeed7 For This Useful Post:
daztdMS6 (09-05-2012), J'sSpeed3 (09-05-2012), Stealth01 (09-05-2012), SWAY (09-05-2012)
shifter cable install issue dooderek MazdaSpeed 6 - Engine, Transmission & Driveline 75 10-12-2014 11:14 PM
MS6 Broken Shiftier Cable Possible Fix? xI Leveler Ix MazdaSpeed 6 - Engine, Transmission & Driveline 9 08-21-2012 10:46 AM
Shifter cable endlink bushing removal chuckms6 MazdaSpeed 6 - Engine, Transmission & Driveline 5 07-09-2012 09:12 AM
Page generated in 0.31072 seconds with 23 queries
