 Old 02-10-2020, 09:20 AM   #1
grammates's Avatar
Posts: 17   (View Stats)
grammates is an unknown quantity at this point
Default KR super high
Just replaced the vvt chain and switched my oil to rotella t6
After the fix and switching there has been a more Audible ticking at idle and when accelerating. Watching the KR while driving you can see it climb all the way to 8.0 at times maxing out there . What could the issue possibly be?
grammates is offline   Reply With Quote
 Old 02-10-2020, 09:46 AM   #2
Police - Grammarhead
Vansquish's Avatar
Well, you could be having any of a whole number of different problems, or you might have no problem at all.
1. Are you sure that the engine is timed properly? That is, when you replaced the timing chain, are you sure that the camshafts, crank, and so forth were correctly aligned relative to one another?
2. Did you only replace the timing chain? Did you replace the VVT actuator, the chain tensioner, or anything else while you were in there?
3. If you did anything other than the timing chain, did you replace the diamond friction washers with new OEM parts? If not, then you will absolutely need to before driving any further. Timing will slip if you don't.
4. Is the knock only at part throttle? If so, then extremely high counts of knock are not atypical at all. If, on the other hand, you're having non-negligible knock while under load/in boost, then you definitely have a serious problem to address.
 Old 02-10-2020, 09:54 AM   #3
grammates's Avatar
I had used the plate to hold the cams in place And the bolt to make sure the engine was at TDC
The vvt actuator, timing chain, tensioner, and the bolts and friction washers were all replaced ,
I値l have to check to see when I have knock. So I should not have high knock under boost / what would be acceptable under load/boost
 Old 02-10-2020, 10:12 AM   #4
BlackBrave8's Avatar
Posts: 13   (View Stats)
BlackBrave8 will become famous soon enough
You realistically don't want any knock at WOT. That being said, spuratic smaller values under 1 could be contributed to other engine noise if the knock sensors are at high sensitivity.
Sent from my SM-G950U using Tapatalk
BlackBrave8 is offline   Reply With Quote
 Old 02-10-2020, 10:16 AM   #5
Vansquish's Avatar
Don't just "check." Datalog.
 Old 02-10-2020, 10:43 AM   #6
Posts: 2,233   (View Stats)
i would add: do it asap and be very carefull while driving because if the timing job as some fail, it will cost an engine pretty soon.
I would rather lift the VC, put the timing bolt behind the crank and rotate it to find TDC and make sure the cams are still properly timed. If not, stop driving it and start again your timing job but this time, by following the instructions on the thread ''how too VVT'' failure to follow all instruction there is a recipe for blown engine...(And yes unfortunately the single use parts would need to be bought again)
While looking at cams positions, you should also double check if the damper is still aligned by being able to put correctly the 6mm bolt thru the damper pulley where it should.
Once being in the garage, i would check engine compression...of course, after removal of all timing tool installed before cranking the engine....
Vansquish (02-10-2020)
 Old 02-10-2020, 11:58 AM   #7
grammates's Avatar
Understood. Took a WOT log in 3rd gear will be uploading later. While at half throttle or mid range rpms I知 sitting around 5/8 and then when I put the pedal down it tends to drop to around 5. I can also get KR if I知 in neutral and rev it to like 3000 rpms
 Old 02-10-2020, 01:16 PM   #8
Vansquish's Avatar
If you're getting knock at WOT and consistently during part throttle driving or revving in neutral, you should probably stop driving the car and check timing ASAP. It sounds like your engine may be improperly timed.
 Old 02-10-2020, 02:09 PM   #9
grammates's Avatar
What would be the easiest way to check and retime the car if it痴 out of time?
 Old 02-10-2020, 02:47 PM   #10
grammates's Avatar
If it was out of timing wouldn稚 it be throwing a code or not?
 Old 02-10-2020, 04:57 PM   #11
Maybe if you keep driving it the ECU will eventually throw a code but, from how bad it sounds, I don't think you should take that risk. There are some forms on here describing how to install the timing chain. With enough searching you should be able to find them and they describe how to time the engine properly. If I remember correctly, there is some special tool you need that a lot of people make themselves. You can buy it too for like $60
 Old 02-11-2020, 09:19 AM   #12
To validate timing, yes you can made the locking bolt with precise exact length but for doing the timing job, the timing plate is something that would need machinist skills and tools...And since the precision needed for those, i would rather get the right thing....(You can even rent it)
the search won't be exhaustive, the thread is called ''How to VVT'' and gives all the infos but one need to pass thru it. A general mechanic that never did a keyless timing job will probably fail at it, if the person don't know and don't read. with low cost worn out cars, many will try to cut on the cost and probably try to do it by replacing the part looking broken, it won't work.
OP will also need to separate mechanic problems against electronics ones. The ecu isn't programmed to validate if mechanical work has been done properly, the cell are there to diagnose something wrong out of normal specs.
So as you said, yes it may detect if the cam is out of phase but will this detection happen before the valves bend against the piston ? probably not...
And constant knock under many conditions is sign of something bad enough to vent the bloc soon or later if ignored....
 Old 02-11-2020, 11:48 AM   #13
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
tl;dr
If you did the VVT/Timing chain and it's not sounding the same then It's most likely out of time...
Not following procedure will just lead to catastrophic failure. There are components that cannot be reused when servicing the chain.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 02-11-2020, 01:10 PM   #14
grammates's Avatar
tl;dr
From my understanding if it was out of time it would be throwing codes either right away or after two full vehicle cycles? I知 going to try to put one gallon of e85 into 93 to see if the knock persists or if it痴 just bad fuel. I知 also going to check all my connection and spark plugs. Is there anything else I should check before just paying someone to have it retimed
 Old 02-11-2020, 02:13 PM   #15
Vansquish's Avatar
Before you start driving it more and risk blowing the motor, why not post the datalog you took and have a few sets of experienced eyes look it over for safety?
Official: Audi A8 super high-tech headlight teased, whole car coming Aug 21 Haltech Automotive News 0 08-14-2013 04:30 PM
High knock super rich afr ciezczak1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 07-24-2013 11:25 AM
WOT now super lean, high stft, and stalling at idle. Doucems6 MazdaSpeed 3/6 - ECU Computer Tuning 13 04-25-2013 04:49 PM
Setting boost per gear -is it safe to put other tables to super high values? 08Anamoly MazdaSpeed 3/6 - ECU Computer Tuning 0 03-27-2010 11:00 AM
Verizon FIOS Super High Speed Internet Deal - $100 Circuit City Gift Card w/ Triple Play at Verizon Wireless Haltech Hot Deals Section 0 04-10-2008 07:40 PM
ゥCopyright 2008 ; 2019 Cymru Internet Services LLC | FYHN� Autosports HQ
Page generated in 0.35723 seconds with 24 queries
