![]() Join Date: Feb 2014 Location: Surrey, BC, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
(Thread Starter) | Not Ranked : 0 score I've been trying quite a few things, including trying to see what WOT would do when the car is half warmed up (I know this isnt a good thing), the car has no knock at all, but still not hitting the boost targets, as soon as it gets up to temp, knock comes back. Also a few days ago, the car decided to work flawlessly for 2 full days. No knock, 15.5psi, spooling fast, absolutely perfect. I filled it up with gas, runs like shit again. A long while back, I accidentally filled up at a station who had some bad gas. I ran around with it, didnt boost a whole lot while i had the shit gas, then filled up at a station I knew was good. I dont remember if the problem started then, but I have a feeling it might have. I have already checked for boost leaks, doesnt have any. So basically, car ran like shit, worked flawlessly for a couple days, filled with gas, runs like shit again. Here are some datalogs to look at, taken about a week apart, weather was about the same. One is while it was running like shit the other is when its running perfectly. I'm totally stumped as to what this problem could be, really need help.
__________________ Silver 06 Speed6 Currently in what I'm dubbing, super sleeper mode. Quite a few paint chips, scratches and dents. 117,000 KM/72700 miles Mods: Corksport Short Ram intake, HPFP Internals, Cobb V3 with Purple Drank tune pushing 19ish PSI, HKS SSQV1 BOV, J2 Downpipe, Custom stereo using 700rms total with double din nav deck, JBR SSP & weight Still cant beat a lightly tuned, stock SRT-4 |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Mods?
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
(Thread Starter) | Not Ranked : 0 score Woops, sorry. Corksport Sri stage 1, Cobb accessport running stage 1+, drilled out second cat.
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Knock sensor doesnt turn on until the coolant is up to temp, so you were getting knock. But you didnt know it |
| The Following 2 Users Say Thank You to speed23 For This Useful Post: | ADHDAdditiv (07-04-2014), chaser27 (07-08-2014) |
I just went down to the store and got some nice fuel system cleaner.
__________________ Silver 06 Speed6 Currently in what I'm dubbing, super sleeper mode. Quite a few paint chips, scratches and dents. 117,000 KM/72700 miles Mods: Corksport Short Ram intake, HPFP Internals, Cobb V3 with Purple Drank tune pushing 19ish PSI, HKS SSQV1 BOV, J2 Downpipe, Custom stereo using 700rms total with double din nav deck, JBR SSP & weight Still cant beat a lightly tuned, stock SRT-4 | |
(Thread Starter) | Not Ranked : 0 score Ok so my car decided to behave pretty much perfect (little bit of knock here and there, but I wasnt complaining). At least most of the time. here are some datalogs I took, all within 20 minutes of eachother, "Just after low boost" and "low boost" were taken literally on the same road, I did a pull, turned around and went back. I'm not the best at reading MAPs ATM so if someone with more experience could look at these and give me their thoughts, I would greatly appreciate it.
(Thread Starter) | Not Ranked : 0 score Bumping again because there is a drag day on friday and I'd like to actually race in it. I was driving yesterday, did a pull, and it did the most peculiar thing, which might give everyone a clue to what the problem is. I started out with the usual problem, (4th gear pull) slow boost build (took 200rpm to get to 11psi)m then at about 4.3k rpm it seemed to jack into high gear and hit 15.5 psi (which should be the stage 1+ boost target) and had 0 knock. It felt like a random kick-in, like it just sort of started working. I continued into 5th gear (shifted at 5.3k) and after about 2-300 rpm it went back to hitting 13.5 psi and knocking again. Im seriously stumped on what the problem is, considering how random it is. Please help!
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| It looks like your car is compensating for IAT and BAT by dropping WGDC levels. If you look at the RPM ranges on the logs where you're knocking, and compare it with the same area in the logs where you're not knocking, you can see that in the non-knocking logs, you've got: more airflow (approx. 25 g/s higher @ 4K rpm); higher WGDC levels, and significantly lower IAT/BAT. To me, that says there's a compensation table kicking in to prevent your motor from blowing. The answer, I believe, is go VIP, read the tuning materials there, and try yourself, or better still, get yourself a custom tune from one of the e-tuners on here.
Do you thinks its all tune problems or could something with the engine be causing it? PS any spelling or extra word is because I'm on my phone
| Not Ranked : 0 score How many times have you filled up since putting the shitty gas in? And what do you mean by "bad gas?" Did you use 87 octane?
| The Following User Says Thank You to btstarcher For This Useful Post: | Vansquish (07-07-2014) |
(Thread Starter) | Not Ranked : 0 score I got the bad gas like 3 months ago so like 12+ fills. And by bad gas I mean it was after winter and I guess either some settlement or water or something got into their 94 octane tank. My dad had problems after filling there too
| The Following User Says Thank You to ADHDAdditiv For This Useful Post: | btstarcher (07-07-2014) |
| Not Ranked : 0 score That happened to me a couple summers ago; it took a long time to get back to normal. I'm not sure why. I drive around 5k miles per month and it was better after a couple months. Then my engine blew LOL
Should I be worried?
| Not Ranked : 0 score Well it depends; I don't know if all that knock/detonation I had with the bad gas contributed to the premature failure or not. It may have weakened the rods over time. But it was probably more to do with my dumb ass learning how to tune with e85 mixes and advancing the timing past the point of no return.
(Thread Starter) | Not Ranked : 0 score Ah OK. So basically run some fuel system cleaner and wait it out?
| Not Ranked : 0 score No, that shit made it worse. Avoid WOT and drive to almost empty, then refill with good gas; if you have e85 maybe a gallon or 2 of that also. Just keep running good gas until it's back to normal. Might also try that Heet stuff, something that will eliminate the moisture in your tank (if there is any).
(Thread Starter) | Not Ranked : 0 score Ok. I've already done that, should I keep doing it til it runs good?
| Not Ranked : 0 score Oh, yeah.....check your plugs, mine were ruined.
(Thread Starter) | Not Ranked : 0 score Will do. What about my injectors and fuel filter?
| Not Ranked : 0 score I didn't see that much KR in your logs. It rarely was over 1 degree. Unless you want to pull everything off to get to your injectors and send them to get cleaned, I'd leave them alone. I've never touched the fuel filter and I'm at 235k miles.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress Last edited by btstarcher; 07-07-2014 at 09:59 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score You must have looked at the wrong one lol. But OK. I'll check the spark plugs tomorrow and recap if needed. Thanks for the help. If anyone thinks it could be something else let me know. I will post the results tomorrow.
![]() Join Date: Dec 2011 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 966
Groans: 127
Groaned at 24 Times in 17 Posts
| Not Ranked : 0 score i had bad gas and my plugs were bad.. then i added octane booster (stupid i know now) and they were fucked. check your plugs run that bitch out till way below the E and fill up at the last second.
__________________ 2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna FreekTuned ![]() |
| That's not the best plan either...it's a good way to suck sedimentary crud that might not normally get sucked into the fuel filter into the fuel filter.
![]() | | #24 | ![]() |
Groans: 127
| Not Ranked : 0 score never thought about it that way, all i know is that i had to run mine down tot he way minimum to get that bp shit out of my tank and that + new plugs helped a ton
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score So if I have to get new plugs, which ones do I get. I know there is a list, and I read it (I dont totally understand it though), but for my setup which plugs should I get? I dont really plan on going much further yet due to lower finances.
![]() | | #26 | ![]() |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score Check to make sure your plugs aren't fouled, covered in oil, etc. Knock can be caused by a lot of different things. And yes the Cobb OTS tune sucks that bad. It's the reason I got into tuning. If you don't feel comfortable doing that yourself, there are a few good tuners on here that can do it via email. It will make your car feel infinitely better.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
![]() | | #27 | ![]() |
Groans: 63
| Not Ranked : 0 score run stock heat range plugs. OEM or Denso ITV 20s or the NGK equivalent (I don't know that part number).
![]() | | #28 | ![]() |
![]() Join Date: Sep 2011 Location: SCRANTON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
__________________ Upgrades so far:
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Woops forgot I put this thread up lol. Other one very active. I ended up getting 1 range colder NGK's for less money then stock ones. I chose them off the spark plug list here on the forum. Also thanks for that latest video. I had a thought about my problem on the other thread that could be viable. The top mount intercooler could have a crack in it that is more present during hotter conditions and at certain RPM's the intercooler itself actually rattles, causing my knock. Its a bit of a long shot, but makes a bit of sense. BTW I ran the stratified stage 1 tune and I hit 17psi exactly like im supposed to, I actually sometimes overboost a bit to 18psi. Still getting the knock but that kind of shows the wastegate is working.
| Not hitting boost targets | sjdannen | MazdaSpeed 3/6 - Turbo Induction | 29 | 06-17-2013 03:36 PM |
| boost tuning, not hitting easy boost targets? | Caldazar | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 05-18-2012 06:09 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| OTS Map Not Hitting Boost Targets | kahunab14 | MazdaSpeed 3/6 - ECU Computer Tuning | 53 | 02-18-2012 10:30 AM |
| Not hitting boost targets again (AP).. | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 28 | 08-01-2011 05:35 PM |
