 Old 04-01-2009, 01:30 PM   #1
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
Default Only boosting 10PSI ??
Couple days ago I decided to tighten down all of my clamps , boost tubes, turbo inlet, cp-e cai, bpv ect...
Thought everything went well...Next thing you know, I reset the ECU, take the car out to a 40 mile drive to let the ECU re-learn, afterwards the next day, I take the car out and to find out that instead of the "wooosh" sound my intake makes when it's sucking in air, it sounds like a high-pitched "wooosh", didn't think nothing of it, so I look at my dashhawk and find out I'm only hitting max boost of 10psi in all gear....
here is my datalog.
glocK23 is offline   Reply With Quote
The Following User Says NO Thank You to glocK23 For This Un-useful Post:
 Old 04-01-2009, 01:33 PM   #2
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
check again for boost leaks, check inlet!
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
 Old 04-01-2009, 02:01 PM   #3
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
meh it happens, it will come around eventually...search for prior threads talking about this symptom
'08 CWP MS3 w/ T3 3071r
 Old 05-16-2009, 01:06 AM   #4
phantomspeed3's Avatar
Posts: 559   (View Stats)
phantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud of
here is my datalog.
Having the same problem...I didn't tighten down anything or nothing though, but I have since and i'm still only pushing 10 psi
2007 MS3: HKS Hi-Power CBE with muffler cut-out, HKS CAI, TurboXS RP, Forge BPV, PTP Air Straightener, OCC, MBC(not hooked up der), Cobb AP, Denso Iridium ITV22 Spark Plugs, PG Turbo Inlet
phantomspeed3 is offline   Reply With Quote
 Old 05-16-2009, 01:31 AM   #5
glocK23's Avatar
Groans: 701
Wow, I fixed this along time ago.
Was a loose clamp on my boost tubes.
 Old 05-17-2009, 09:25 AM   #6
mexicant's Avatar
Groans: 147
you can paypal me $10 now
NATOR PERFORMANCE
 Old 05-18-2009, 02:35 PM   #7
nesiospeed's Avatar
Posts: 29   (View Stats)
nesiospeed will become famous soon enough
do you have a mbc ? i have mine , but when i take off my mbc , and re-installed the original boost tubes from solenoid , always it gonna give me only 10 psi , no more you need to go the dealer for a reflash .... that works for me , o put one mbc , and setup yourself to 15 or 16 psi ... i hope it works for you...
nesiospeed is offline   Reply With Quote
Brake boosting? Sloane Mazdaspeed3/6 General Discussion 14 12-24-2008 01:13 PM
Boosting to High AP Log albone
Cobb Access Port/Maps
24 12-19-2008 02:54 PM
took off mbc and only seeing 10psi b-ron MazdaSpeed 3/6 - Turbo Induction 2 07-29-2008 11:01 PM
Honda boosting Fit production to meet U.S. demand Haltech Automotive News 2 06-23-2008 12:10 PM
Page generated in 0.27797 seconds with 25 queries
