 Old 01-06-2011, 02:13 PM   #1
JumpingJackson's Avatar
Posts: 967   (View Stats)
Default Bad Fuel Pressure Sensor?
Ive noticed some odd behavior on my dashhawk a few times and like to get some opinions.
Say i start the car. Everything is running dandy. I stop the engine by turning the key. turn key back on but dont start car yet (Everything has power, dashhawk is still running etc) My Fuel DI pressure will steadily rise from ~400 psi too like 1600 psi even though the engine is off. Has anyone else noticed this behavior? Next time you drive you could check and see on your DH or Cobb AP?
If i turn the key when the car has been sitting the pressure sticks at 60 psi like it should.
-Phil
2006 Titanium Gray MS6 Mods:
DCR - Built Longblock with Pauter Rods , Wiseco 8.9:1 Pistons, Stiffer Valvesprings, P&P Head Upgraded VVT Actuator
Cobb AccessPort + 3 Bar Map Sensor
CP-E TIP , RMM
Aquamist HFS-4 WMI Injection System
Bullseye - T3 .55AR S259 Turbo
Synapse - BOV
Custom - Ceramic Coated T3 Exhaust Manifold , 3" T3 Downpipe, 3"-2.5" Dual Catback Exhaust, 3" MAF SRI, FMIC
PT-P CDFP + Walbro 255 Intank Pump + Fuelabs Adj. FPR + -6 AN Feed/Return
Turbine Tech / Street Unit - Front & Rear Diff Mount
eDesign Audio - NINe.2x 760W AMP , 2x 11Kv.2 10" Subwoofers
 Old 01-06-2011, 02:53 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I've never seen anything like that.. I see my idle fp gradually fall until it settles around 60~70psi..
SSinstaller is online now   Reply With Quote
 Old 01-06-2011, 03:02 PM   #3
Speculation as to cause?
CP-E TIP , RMM
Synapse - BOV
 Old 01-06-2011, 03:06 PM   #4
TRex's Avatar
Posts: 3,139   (View Stats)
Ima try this...will let you know
 Old 01-06-2011, 03:09 PM   #5
Groans: 60
I'd guess it's a can bus/DH issue not a sensor problem... Unless you start getting strange readings while the motor is running I wouldn't worry too much..
 Old 01-06-2011, 10:57 PM   #6
TRex's Avatar
mine does the same thing....it climbs (slowly..in jumps of 2 or 3) all the way up to 1600 when the car is on but not running
 Old 01-06-2011, 11:06 PM   #7
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
Funny enough I was sitting in a parking lot tonight after running into the store. I turn the key on but didn't start the car but the ap showed 1200 psi pressure and was slowly climbing. I thought it was weird but car runs fine though.
JmkC is offline   Reply With Quote
 Old 11-18-2013, 07:34 PM   #8
GabSev's Avatar
Posts: 5   (View Stats)
GabSev will become famous soon enough
Smile Hello everyone
Looking forward to meet some of you and learn the ways of the Speed6.
I'll be gathering and posting my information and mods, and hopefully find solutions to some of the problems I have encountered.
For now, I am a proude owner of a 2006 MazdaSpeed 6
Thank you,
GabSev is offline   Reply With Quote
 Old 11-18-2013, 07:51 PM   #9
brandonnicholson's Avatar
Posts: 1,699   (View Stats)
brandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the worldbrandonnicholson is the leader of the world
Thank you,
You're not off to the greatest start... Try making your own thread in the new member section and not posting in a thread with nothing in common from 2011.
brandonnicholson is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/bad-fuel-pressure-sensor-68927/
VTRides :: View topic - I love www.mazdaspeedforum.org/forum This thread Refback 03-27-2011 04:12 PM
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
TIRE PRESSURE SENSOR... redneckrecon MazdaSpeed 3/6 - Wheels & Tires 12 01-21-2011 07:23 PM
How to scale the HPFP pressure sensor djuosnteisn MazdaSpeed 3/6 - ECU Computer Tuning 521 04-07-2010 08:39 AM
P0107 - Barometric pressure sensor low input vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-14-2009 01:31 PM
Page generated in 0.28166 seconds with 25 queries
