| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() Join Date: Apr 2016 Location: Orlando Fl
Rep Power: 0 ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score i attached a log on idle, hope this help. |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Neutral : +1 score What does it drop to 60psi? Have you checked your spill valve and HPFP internals? They could be sticking. Edit just checked the log it looks like the internals are sticking. Pull the pump and clean it out and check it
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | luisito320 (05-24-2019) |
(Thread Starter) | Not Ranked : 0 score the internals are brand new. and spill valve is clean. |
(Thread Starter) | Not Ranked : 0 score I will be replacing the fuel pressure sensor. Cuz going to basics and use the relief valve diagnostic the fuel pressure doesn't go up again. And it should go up since the car is still hot and the relief valve is brand new. |
(Thread Starter) | Not Ranked : 0 score So today I spend like 5 hours looking at wiring diagrams and doing diagnostics. I turn out that when the car gets to normal driving temperature the ECU cut the signal to the fuel pump relays. Now I have to figure out if the ECU is bad or there is another sensor causing problems. |
(Thread Starter) | Not Ranked : 0 score So ECU is good. Cleaning mechanical pump again. |
(Thread Starter) | Not Ranked : 0 score Fuel still drops and shut off. Even with the ITFP connected directly to the battery. |
(Thread Starter) | Not Ranked : 0 score Found what was causing the fuel drop. Problem solve. |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | Vansquish (05-24-2019) |
(Thread Starter) | Not Ranked : 0 score ITFP was getting hot and is was losing pressure slowly. |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score So you replaced it, or found out what was making it over heat and fixed that, or what?
(Thread Starter) | Not Ranked : 0 score I did replace it. Still dont know why it was overheating. I think the pump was bad, because I check all wires trying to figure out what was wrong with it and everything is good. |
| The Following User Says Thank You to luisito320 For This Useful Post: | MSMS3 (05-26-2019) |
| Fuel System Problem | Speeden6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 10-08-2017 07:26 PM |
| PI Fuel Pressure Problem | nswartz19 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 04-26-2015 09:50 PM |
| Hey I have a fuel cut problem | BigD99 | 2010 MS3 - Fuel, Nitrous & Water Injection | 16 | 02-24-2014 06:40 AM |
| Problem after problem: Running rich & Fuel cuts | wherewuat | 2010 MS3 - Troubleshoot/Diagnostics | 30 | 01-30-2014 02:13 PM |
| Fuel gauge problem... | Speedaway | Mazdaspeed3/6 General Discussion | 14 | 01-17-2011 12:01 AM |
