| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | | #201 | ![]() |
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 8 Users Say Thank You to superskaterxes For This Useful Post: | 06Speed6 (09-27-2011), Dano (09-26-2011), jracer (09-27-2011), kmac (09-26-2011), redboat (01-24-2014), SSinstaller (09-26-2011), wolly6973 (09-26-2011), xcoldricex (09-27-2011) |
![]() | | #202 | ![]() |
| Not Ranked : 0 score Fail
![]() | | #203 | ![]() |
| Not Ranked : 0 score lol, few hundred references. fuck.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
![]() | | #204 | ![]() |
| Not Ranked : 0 score no shit...I'd say its time for a dedicated piggyback for the fuel sensor...no? or is there not enough voltage to scale it and you're right back to the SB limitations?
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
![]() | | #205 | ![]() |
| Not Ranked : 0 score how old r you? dont u remember the famous DJCKT?!?!?!
| The Following User Says Thank You to superskaterxes For This Useful Post: | Dano (09-26-2011) |
![]() | | #206 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score subbing.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() | | #207 | ![]() |
| Not Ranked : 0 score yessssss I absolutely do!!!! those things were poised to sell like hotcakes...then cobb up and started back on development for our platform LOL guess we are back to the DJCKT.. @djuosnteisn...ready to get back into production??
![]() | | #208 | ![]() |
Groans: 60
| Not Ranked : 0 score That sucks, but at least we learned a little from your testing... Now that we're sure the injector can handle at least 2300~2400psi, can cobb at least remove the cut we get when the OEM sensor hits 4.5v... That would allow us to run a 2350psi RV and just target ~2025psi and not worry about cutting if we overrun that pressure...
| The Following User Says Thank You to SSinstaller For This Useful Post: | Realgib3 (09-27-2011) |
![]() | | #209 | ![]() |
@Erich seems to be just fine running a 2050 RV i think. if u look at his logs he seems to have every consistent pressure just below the OEM sensor limit.
![]() | | #210 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score I am running a 2150 RV, and targeting (with good success) in the 2030-2050 range. I don't seem to get any cut on the rare occasion it spikes to above 2071. Maybe something they changed from the MS6 to MS3 ECU. Has Cobb looked at the MS3 ECU for this as well as the MS6? Do they know if the same hardcoded bullshit is in the MS3 ECU? |
| The Following User Says Thank You to Erich For This Useful Post: | Realgib3 (09-27-2011) |
![]() | | #211 | ![]() |
Groans: 60
I guess I'm stuck waiting for a port injection solution...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #212 | ![]() |
| The Following 3 Users Say Thank You to Erich For This Useful Post: |
![]() | | #213 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Just when things were looking up... Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
![]() | | #214 | ![]() |
| Not Ranked : 0 score chris, why dont u ramp up FP so that u dont get a spike?
![]() | | #215 | ![]() |
Groans: 60
| Not Ranked : 0 score I've tried every possible FP combination and it still spikes.. I tried targeting 1000psi at WOT and it still pegged the sensor with the 2350 and 2050psi RV's.. IMO, the only reason my car is driveable is the OEM RV opens at 1886psi, and can bypass a shitload of fuel.. I still sometimes see logs where my FP touches 2050psi..
| The Following User Says Thank You to SSinstaller For This Useful Post: | Realgib3 (09-28-2011) |
![]() | | #216 | ![]() |
| Not Ranked : 0 score I would not put much stock in the injector duty cycle value. It is known to have issues and doesn't account for the DI rail pressure. With DI it seems the soft fueling limit is found by spark blowout not by running lean so I wouldn't say you are out of fuel till you start seeing blowout. I bet your MAFCAL cal is spoofed lower than actual to adjust for those injectors. That's the only way we have to account for fueling changes right now. (spoof the MAFCAL low to force smaller injectors pulsewidths for upgraded injectors that flow more, spoof the MAFCAL high to force larger pulsewidths to account for E85....) Zigatapatalka
![]() | | #217 | ![]() |
Groans: 60
I don't know that I agree about the spark blowout issue, I've logged some very high maf g/s numbers and never had blowout issues... Maybe the oem fuel spray pattern is wetting the injectors(and my injectors somehow don't have the same issue), or it could be my lower compression... There are way too many variables to say hitting the fueling limit is causing the blowout. I really don't know about the MAF cal, I made my adjustments to fix the fuel trims and match my WOT targets, but I haven't seen enough big maf sensor cals to say if mine is skewed any.. IIRC on my cal the 3.25" housing tops out somewhere around 600~650g/s, but I need to rescale it since I installed the MAF straightener.
![]() | | #218 | ![]() |
Problem: Fuel pressure drops and I go rich at high load. I originally thought this was due to a dying set of pump internals, but it's not. How do I know? I ran 4 MAF's in my car last week trying to find one that worked for me to dyno on. My stock MAF= FP problem, hitting 2.3x load Toyato Ech MAF= FP Problem even worse with MAF scaled down a tone, hitting 2.6-2.8x load Subaru MAF= NO FP Problem with MAF scaled UP 18-20% and hitting only 1.8-2.0 load Used MS3 MAF= FP Problem, hitting 2.3-2.5x load again... I'm totally baffled by this, so I'm either throwing the Suby sensor back in, or scaling all my tables to run this sensor, but show lower load. I'm boost tuning and there aren't any load cuts/targets I could be hitting in the map that are doing this either form what I can tell. Also... If you didn't catch it... shouldn't I be showing MORE load if the MAF is scaled way UP? and LESS load if it's scaled way DOWN? Cuz I'm seeing exactly the opposite now... Ugh, my brain is fried right now. HELP!
My Toyota sensor was all the way down to like 500 and my Suby cal is at 725 peak g/s Last edited by Realgib3; 09-28-2011 at 11:20 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #219 | ![]() |
Groans: 60
| The Following User Says Thank You to SSinstaller For This Useful Post: | wolly6973 (09-29-2011) |
![]() | | #220 | ![]() |
| Not Ranked : 0 score Just got a pm back from jacksonms3. I had told him it looked like he may be having some of the same issues I was because of what his logs looked like, but I originally thought hismaf was scaled way up for some reason, but it's not. His maf cal peaks out in the 400snew g/s and he's seeing crazy high loads. Like 2.8-3.0 load... Am i missing something here or is this strange? Since when does bringing the MAF cal down make load read way higher? In the load cap days... we scaled it way down to make load read lower... when did this change? |
![]() | | #221 | ![]() |
| Not Ranked : 0 score this is news to me but I don't have much experience with the larger 30 series and larger turbo cars. so when you neg scale do your g/s get lower and load still goes up? also make sure all your TRLS ABS targets are above the cobb 2.5 load range...not sure how that would effect fueling but get them out of the way anyway.
| The Following User Says Thank You to Dano For This Useful Post: | wolly6973 (09-29-2011) |
![]() | | #222 | ![]() |
Groans: 60
| Not Ranked : 0 score I have no idea how the maf cal correlates with the load, but for me at least 400-450 g/s is 2.5-2.8 load..
![]() | | #223 | ![]() |
LOAD*(some constant)*RPM = MAF RPM being constant, a higher MAF value will result in higher load.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk Last edited by Ziggo; 09-28-2011 at 07:09 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #224 | ![]() |
Groans: 60
The calculated load is actually derived from the MAF, IAT, RPM, and BARO--which is why I stated that using a different manufacturers MAF with different scaling on the IAT could throw off the load calculation.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | ||
![]() | | #225 | ![]() |
Actually, if you think about it, if it wasn't g/s we couldn't do MAF cal's, run larger diameter intakes, run different fuels at different stoich ratios, etc. g/s has to be the driver.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following 2 Users Say Thank You to phate For This Useful Post: | cld12pk2go (09-29-2011), wolly6973 (09-29-2011) |
![]() | | #226 | ![]() |
| Not Ranked : 0 score Different MAF sensors will certainly screw with things, and i wouldn't expect other manufacturer sensors to be plug and play, but the beauty of hot wire MAF sensors is that you get density for free. MAF voltage is directly proportional to the mass of air flowing past it, its not measuring speed that then has to be corrected for density of the air. That proportion is what we calibrate. Zigatapatalka
| The Following User Says Thank You to Ziggo For This Useful Post: | wolly6973 (09-29-2011) |
![]() | | #227 | ![]() |
| Not Ranked : 0 score scaling with my new mazda maf actually worked as it should, not like I experienced with other mafs. So. Neg scaling gave me less calc load and visa versa. Iats seemed dead on with the other sensors tgough too so I think its something else in the equation causing these oddities. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | wolly6973 (09-29-2011) |
![]() | | #228 | ![]() |
![]() Join Date: Jul 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Any updates from cobb?
__________________ 2006 speed6 ... bnr s4 soon- on order... when danger to manifold explodes... 8 port 335i day driver LSA supercharged Caddy CTS-V stealth gray-sold Porsche Panamera turbo- sold Bmw m3-sold Z4m- sold |
![]() | | #229 | ![]() |
| Not Ranked : 0 score Nope, their ATR release yesterday looks like it added some FP monitoring, but nothing to scale the FP Sensor (in fact it looks like they removed the tables to do that on the GenPu) |
![]() | | #230 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score I heard they cut it until they could release the total FP Sensor scaling ability.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| The Following User Says Thank You to Alpha For This Useful Post: | superskaterxes (11-18-2011) |
![]() | | #231 | ![]() |
| Not Ranked : 0 score ^^^^ this is correct
![]() | | #232 | ![]() |
| Not Ranked : 0 score Anthony were you the one who bought the sensor upgrade? Steve at versatune was wanting to get his hands on one to help him decipher and test the code.
![]() | | #233 | ![]() |
| Not Ranked : 0 score if im not mistaken kmac did as well. does he want to purchase/borrow it from me? send me a PM/email if so.
| The Following User Says Thank You to superskaterxes For This Useful Post: | Alpha (11-19-2011) |
![]() | | #234 | ![]() |
| Not Ranked : 0 score 0265005303 is that the bosch part number that you have? Nm I read back in the thread.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 11-19-2011 at 03:39 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #235 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score Sorry for bringing back old thread, but does anyone know if really is socket 27 for stock sensor? I tried putting it on yesterday and just couldn't. Didn't see anything in the way either, just seemed too small? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/fuel-rail-high-pressure-sensor-upgrade-67643/ | ||||
| 0265005303 - Virgilio Ricerca Web | This thread | Refback | 10-18-2011 07:58 AM | |
| High Pressure Relief Valve Option | SilverDemon | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 161 | 04-29-2011 08:10 PM |
| Opinion On High RPM High Pressure Fuel Pump Spring | ms3brendan | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 07-13-2010 01:04 PM |
| Removing Fuel Rail...and where is the DI psi sensor located? | AFcadet | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 3 | 11-18-2009 04:48 PM |
