| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | | #81 | ![]() |
![]() Join Date: Oct 2012 Location: Savannah Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,300
Groaned at 40 Times in 21 Posts
| Not Ranked : 0 score
__________________ [SIGPIC][/SIGPIC] 2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM / FOR NOW... |
| The Following User Says Thank You to Menace1 For This Useful Post: | Dizzy Turbo (02-12-2013) |
![]() | | #82 | ![]() |
![]() Join Date: Feb 2013 Location: Bw8/290
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 195
Groaned at 21 Times in 12 Posts
| Not Ranked : 0 score so today i decided to datalog since ill be installing my fmic on friday. i dont have AP. but i do ave a snap-on solus ultra. It showed to be at 1725psi wot and dropped to 1580-1600 while shifting. wondering if these internals need to be replaced before actually installing the ic. thANKS GUYS |
![]() | | #83 | ![]() |
![]() Join Date: Nov 2012 Location: Florida
| Not Ranked : 0 score Ms3Luke, you should definitely consider replacing your internals before any further upgrades just from all the reading I've done you don't want the "zoom zoom boom effect". My question is about boost. I replaced my internals yesterday, and I'm running a AP and Injen CAI but that's all and my fuel pressure is maxing out at 2100psi but my boost is only 14.7psi and the Max pressure for the map I'm running is supposed to be 16.5. I know its +/- 1.5psi, but should I be concerned about my internals if I'm not getting Max boost? Any help would be greatly appreciated. |
![]() | | #84 | ![]() |
![]() Join Date: Nov 2012 Location: Green Bay, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 8 Times in 7 Posts
| Neutral : -1 score Anyone had any experience with edgeautosport.com was thinjing about purchasing from the. Price Autotech internals are 350 shipped |
| The Following User Says NO Thank You to treavis For This Un-useful Post: | Raider (02-26-2013) |
![]() | | #85 | ![]() |
| Neutral : +1 score
Seriously, new guy. I know It's tough, but you need to spend time reading. Shit man, check out their section up top. Yes, they are awesome. Just read more. | |
![]() | | #86 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Has anyone here had problems installing AutoTechs? I have them in the pump already, but when I try to put the pump back in, It's extremely hard to get the pump close enough for the threads on the bolts to engage. Eventually I get 2 in and then the pump is so mis-aligned, I can't even get the 3rd to start threading. The stock pump seems like it would go back on no problem, and I'm not fighting nearly as much pressure trying to push the pump in. I'd really like to have a running car, so maybe someone can shed some light on what might be going on here.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #87 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score @sidekick; Pics?
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
![]() | | #88 | ![]() |
Groans: 47
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #89 | ![]() |
![]() Join Date: Nov 2011 Location: Minooka, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
| Not Ranked : 0 score Sounds like the cam shaft is in the way. You could try GENTLY bumping the starter to move it.
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. |
![]() | | #90 | ![]() |
Groans: 47
I was having the exact same problem and my cam follower is in the exact same position as his, so I'm pretty sure that is the problem. Thanks for your help though
![]() | | #91 | ![]() |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED | |
![]() | | #92 | ![]() |
Groans: 47
| Not Ranked : 0 score It was definitely stuck. I tried cranking the engine a few times, with no change. I used a rubber covered socket and a rubber mallet to knock it free. Everything went smooth as butter after that.
| The Following User Says Thank You to sidekick For This Useful Post: | jseams (03-12-2013) |
![]() | | #93 | ![]() |
![]() Join Date: Apr 2013 Location: Harrisonburg VA
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score quick random question. i broke my in-tank fuel pump. should i go for an upgrade right away without the internals. and wich one would be better to get. walbro or deatsch wrecks |
![]() | | #94 | ![]() |
Sent from my iBro 5 using tapatalk, Bro!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, FREEK TUNED, HTP full 3" intake/TIP, HKS SSQV 4 full VTA, Corksport catless downpipe, Corksport catless Racepipe, Cobb AP V3, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 80duro PMM, JBR cylindrical shift knob, Fidanza aluminum flywheel, EBC green brake pads, Centric high carbon rotors, Nitto NT555 tires, Gorilla spline lug nuts, DDM tuning HID's lows, Resonator Delete. | |
![]() | | #95 | ![]() |
| Not Ranked : 0 score well first i ran out of gas.. twice. the secound time my check engine light turned on. checked it out. computer showed that i had to lean fuel on idle and to rich when i flore it. thats how it was. my daily mpg droped by like 2 and at idle i would stal sometimes. this car was passed down to my by my older bro. he had internals installed. yesterday he took them out. put in the stalk one back in. no fuel going into the engine at all/ so engin just stal at start. what you think? |
![]() | | #96 | ![]() |
![]() | | #97 | ![]() |
sorry and yes. it aint hard to change it and the autoteck rod. Last edited by s_x_two; 04-13-2013 at 12:38 AM. | |
![]() | | #98 | ![]() |
| Not Ranked : 0 score ![]() my car was driving ok with the auto tech internal in the hpfp, bc it sends 50% more gas to the engine. but now with the stock internal in the hpfp, its not even going. not enough gas going into the engine. idk what it could be, my guess is the in-tank fuel pump broke. happened to a friend, on his civic though |
![]() | | #99 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score FYI: Their prices are retarded, but APR is selling their 'ish direct now: APR 2.0T FSI High Pressure Fuel Pump Pump: 1,099.99 -> SALE! $934.99 Kit: $649.99 -> SALE! $552.49 I'm too lazy to look - anyone using KMDv3 internals? |
![]() | | #100 | ![]() |
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score Sorry guys I am a complete noob and probably spamming the forum with this question but I really need a peace of mind on this one The current owner of the Mazdaspeed 3 I am looking to buy is planning on fitting a intake SRI and a FMIC kit without any software upgrade. I have read on the forum that this is not a good idea to fit a FMIC kit without upgrading the internals of the HPFP and told the owner this but he says it is no problem? Is it me who is wrong on this one? Thanks in advance guys |
![]() | | #101 | ![]() |
| Not Ranked : 0 score You need them if a 2010+. |
| The Following User Says Thank You to Raider For This Useful Post: | Madcaddies (04-14-2013) |
![]() | | #102 | ![]() |
| Neutral : +1 score It is a 2007 first gen:-) |
![]() | | #103 | ![]() |
![]() Join Date: Sep 2011 Location: New York City
Rep Power: 916 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 442
Groans: 93
Groaned at 27 Times in 16 Posts
| Not Ranked : 0 score Hi, guys. I have the opportunity to buy someone's upgrade fuel pump (installed AT internals and is now stocking out) for $250 in exchange for my OEM one. I'm one of the most paranoid people when it comes to my warranty, but I presume this is a safe bet as long as he's been maintaining pressure? I've done some searching but can't find any consolidated threads on upgrade HPFP failures (which, I guess, is a good thing). Have there been many failures of upgraded pumps or are they crazy reliable??? TIS
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" |
![]() | | #104 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
__________________ it's fun to do bad things | |
| The Following User Says Thank You to jack_hammer For This Useful Post: | Menace1 (05-04-2013) |
![]() | | #105 | ![]() |
Groans: 93
| Not Ranked : 0 score I trust him completely (know him personally) and he says (and has provided logs) that he maintains commanded pressure just fine. However, the pump (with warranty) that CP-E offers is so tempting, if only for peace of mind. TIS
![]() | | #106 | ![]() |
Groans: 549
| Not Ranked : 0 score then if yo uguys are buddies, if you have a warranty problem you could ask him to submit it to AT for you. but honestly, the risk comes at installation. once you're installed, up, and running, you're past the vast majority of potential pitfalls.
![]() | | #107 | ![]() |
![]() Join Date: May 2009 Location: St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Though a reference to APR exists in post #99 above, a search says there are no matches when searching for APR. Go figure... I sold some Autotech internals for my GTI HPFP to a guy with an MS3 a while back. I later elected to purchase an APR pump for that car instead. I've sold the GTI and bought another MS3, and I'm wondering if there are any differences in the Hitachi pump (other than the fittings that is) for the VW application versus that for an MS3. If not, I don't see why the APR pump wouldn't be able to be installed onto the Mazda motor. Has anyone ever tried this? |
![]() | | #108 | ![]() |
![]() Join Date: Mar 2013 Location: Ann Arbor, MI / Paterson , NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score just making sure but I don't need internals if all I have is a CBE right ... ?
__________________ 2013 Black Mica MS3 w/ Tech Cobb AP V3 - JR TUNED - E85 - ST coilovers - CS hpfp internals - CS sri - CS tip - CS rsb - CS short shifter - CS shifter bushings - UR axle-back - ATP catless dowpipe - CP-E rmm - Denso ITV22 rice : Rally Armor mud flaps - Deep Red powder coated pu wheels - 20% tint |
| The Following User Says Thank You to boatis For This Useful Post: | seeceejayrun (01-19-2015) |
![]() | | #109 | ![]() |
| Not Ranked : 0 score No. Just need to read more. |
| The Following 3 Users Say Thank You to Raider For This Useful Post: |
![]() | | #110 | ![]() |
And to add to my previous post. The CPE HPFP spring does make a difference and is different from stock. It allows the pump to out rev 1.5 times that of the stock spring on stock pump, as well as a stock pump with aftermarket internals. Now the upgraded internals design is what gives the pump higher pressures, resulting in some HPFP upgrades offering higher peak available pressure. @themytb; I think we should add these specs to the OP for everyone. The proper peak pressure for each individual HPFP Internal and the difference in the CPE HPFP spring compared to stock. I'm just going to leave these here as well. http://www.corksport.com/blog/fuel-p...arison-part-1/ http://www.corksport.com/blog/fuel-p...arison-part-2/
__________________ [SIGPIC][/SIGPIC] 2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM / FOR NOW... | |
| The Following User Says Thank You to Menace1 For This Useful Post: | hyedracyl (05-06-2013) |
![]() | | #111 | ![]() |
![]() Join Date: Jan 2013 Location: Fallbrook California (so cal)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Does anyone know where I can buy parts for my fuel pump? I droped mine and bent the two aluminum lines, and I tried to straighten them to the best of my ability and put everything back on and it spits fuel out!!! I just need the aluminum lines. |
![]() | | #112 | ![]() |
| Not Ranked : 0 score Post a wtb thread once you add city and state to your profile. |
| The Following User Says Thank You to Raider For This Useful Post: | Reyes_sdr (05-05-2013) |
![]() | | #113 | ![]() |
![]() Join Date: Jul 2011 Location: Des Plaines IL
Groaned at 9 Times in 2 Posts
| Not Ranked : 0 score I'm going to install a CS SRI + TIP and flash Cobb AP stag 1 . Do you think that i will need a fuel pump upgrade ? |
![]() | | #114 | ![]() |
| Not Ranked : 0 score Yes. Start reading. |
| The Following User Says Thank You to Raider For This Useful Post: | Menace1 (05-07-2013) |
![]() | | #115 | ![]() |
| Not Ranked : 0 score I didnt have any troubles with the fuel pump until I put a FMIC on... everything before that was CAI, TIH, TBE, iridium plugs, and access port. I put the fmic on and I got a fuel cut around 5500 rpms. Put the AT internals in and was fine... however it wouldnt pass smog so I put the stock internals back in and dropped the pump and bent the shit out of the aluminum lines and now im fucked untill I can find out where to buy external fuel pump parts |
![]() | | #116 | ![]() |
| Not Ranked : 0 score Dude! Please! No stories of how you did what you did. The progress of modding these cars are and have been posted for a reason. It only confuses people about what they can do to there cars before problems. Some speeds are different, but the mod path is direct and should be taken no matter what BS you did and didn't blow up.
| The Following 3 Users Say Thank You to Menace1 For This Useful Post: |
![]() | | #117 | ![]() |
| Not Ranked : 0 score Great info Menace1, I appreciate the tip. Now I'm wondering if it would be better to swap over the various external fittings to my APR pump, or to disassemble both pumps and move the APR internals over to the Mazda's housing. I thought that APR was machining the housings to match their improved internals, but the threads that you referenced didn't seem to indicate that the internals had been matched to the housing. Any other words of wisdom for me? Thanks in advance! |
![]() | | #118 | ![]() |
![]() Join Date: Jul 2012 Location: Middleton ID
Rep Power: 0 ![]() Thanks: 1
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score i have a quick question. is there a way to tell if you have upgraded fuel pump internals with out taking off the fuel pump by the pressure? or do I have to take it apart? |
![]() | | #119 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Check for zip tie on hard line if not then I doubt it.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
![]() | | #120 | ![]() |
| Not Ranked : 0 score well i'm going to try CS SRI + TIP and run AP Stage1+CS+TIH 93 (the map is for stock fuel pump)COBB Tuning - MAZDASPEED Accessport ,if i got any fuel pressure problems i will change it to CPE hpfp. |
