| MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection Have a CDFP fuel pump question? Do you want to add Nitrous or Water Injection to your Mazdaspeed 3/6 ? Please come on in! |
![]() | | #281 | ![]() |
![]() Join Date: Feb 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score
__________________ 17x9 Enkei Rpf1 wrapped in Hankook ventus rs3 255/40/17 tires~Cobb Accessport V3~Corksport RMM~UR Turbo back Exhaust~ CP-E 3.25 intake~Autotech hpfp internals~Tuned by Purple Drank Tuning on 22lbs boost |
![]() | | #282 | ![]() |
![]() Join Date: May 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 848
| Not Ranked : 0 score Cobb sells Autotech internals... So, yeah, lots of us have 'em in our cars. |
| The Following User Says Thank You to frothy For This Useful Post: | Gerbilo (12-24-2016) |
![]() | | #283 | ![]() |
![]() Join Date: Aug 2016 Location: Gatineau Quebec
| Not Ranked : 0 score Thanks a lot lads. Much apreciated. Definitely going to be my next buy. Cheers and happy holidays. |
![]() | | #284 | ![]() |
![]() Join Date: Aug 2015 Location: Roswell, GA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score I am having trouble getting my HPFP back onto the motor. I changed the internals years ago with no problem and I am currently changing the hard line to a CS braided line. I pulled the pump off and now it will not even come close to seating correctly. It's like the shaft from the pump inside the spring is being blocked when I try seating it. Is the lifter supposed to be down in a hole to allow the shaft to slide in there? It looks the same as the pictures I see everywhere else.... |
![]() | | #285 | ![]() |
![]() Join Date: Jun 2015
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score The cup shaped metal piece in the hole likely flipped over. The cup opening needs to face the hpfp. Either that or your o-ring needs replaced. |
![]() | | #286 | ![]() |
![]() Join Date: Oct 2016
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score I've heard mixed answers about this question, but i'm currently in the market to get some autotech interals, and are used interals safe to get? I don't see why they wouldn't be especially with autotech's fantastic return policy, some people say absolutely not, some say why not? Is it safe for me to save 100 bucks and grab some used ones? |
![]() | | #287 | ![]() |
![]() Join Date: Mar 2017 Location: Palm Beach, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score From previous answers in this thread used don't seem to be a huge issue. If you're worried about it get new ones. Considering I don't see many used Internals in the for sale section I shall be buying new. Probably corksport because I will also be getting my SRI from them. Might as well save some cash that way
__________________ 2012 Silver MS3, CP-e stage 2 RMM, Damond Motorsports PMM, AP V3 Last edited by Gnar'd Up; 04-18-2017 at 06:51 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #288 | ![]() |
![]() Join Date: Jan 2017 Location: Madison Wisconsin
| Not Ranked : 0 score How about the Cobb Mazdaspeed fuel pump internals? How are they? |
| The Following User Says NO Thank You to BloodBanez For This Un-useful Post: | Vansquish (05-26-2017) |
![]() | | #289 | ![]() |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| There's no such thing.
![]() | | #290 | ![]() |
![]() Join Date: Mar 2014 Location: South Dakota
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score You mean autotechs? Thats what they sell on their site. I just installed mine and they work as advertised. Sent from my iPad using Tapatalk Pro
__________________ 2013 Speed3 w/ tech Autotech HPFP Cobb APV3 ETS TMIC JBR 3.5in SRI UR catless DP Corksport TP Corksport Hoodscoop JBR RMM Stratified e30 tune Other Stuff: 1992 Jeep Cherokee 202,000 miles (salt/snow work horse) 2009 Toyota Rav 4 (wife has to drive something practical) 2012 Yamaha R1 Full Two Brothers exhaust & ECU flash |
![]() | | #291 | ![]() |
| Not Ranked : 0 score Yeah I just did some more reading and noticed that that's what they were |
![]() | | #292 | ![]() |
| Not Ranked : 0 score After installing a new hpfp with aftermarket internals, as well as tuning the cobb stage 2 ots map, within 10 miles of my car driving home it died and came back to live immediately after, I thought it was because I was very low on gas, filled it same to fix the issue, then finally my car threw a code P2188 (too rich at idle) my car ended up running so rich unused fuel would drip from the exhaust and a little smoke on acceleration, so putting the pieces together I immediately swapped pumps back to my stock one, fixed the smoke and fuel drip, code didn't go away. Then I decided to clean my MAF, pull my intake look for leaks, re tune to stage 0 (stock), and also reset my ECU. Nothing fixed the code, still idling at around 700rpms. All of my gauges/data logs show normal levels for hpfp levels, AFR, and so on. I have been told it could be my bank 2 02 sensor, my purge valve, spark plug, or open injector. I just find it very coincidental that somehow within 10 miles of a fresh tune/fuel pump it throws this code. Any ideas will help! |
![]() | | #293 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
__________________ 2007 Mazdaspeed3 GT | |
| The Following User Says Thank You to MD1032 For This Useful Post: | Vansquish (05-30-2017) |
![]() | | #294 | ![]() |
| Also, did you add any other aftermarket parts at the same time?
![]() | | #295 | ![]() |
Nope, just hpfp swap and stage 2 tune Last edited by Dawson_MS6; 05-30-2017 at 11:10 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #296 | ![]() |
Groans: 143
| Not Ranked : 0 score Remove the internals you installed on the other pump, inspect, and post pictures. Make sure the o ring in the cylinder retainer is still in there. Hint: If the piston moves freely, it is surely missing.
![]() | | #297 | ![]() |
| Not Ranked : 0 score I never installed the aftermarket internals in either of the two pumps, I bought one pump with internals already installed and my stock pump which worked perfectly fine prior, both pumps and both internals throw the code, my hpfp active pressure levels are normal. I think it might be an o2 sensor or maybe purge valve, just a coincidence it happened so soon after hpfp install |
![]() | | #298 | ![]() |
![]() Join Date: Aug 2014 Location: Atascadero California
| Not Ranked : 0 score I am experiencing fuel pressure issues, i am trying to determine if I have a fuel pump or pressure relief failure. car runs like shit, has fuel cut, giving me random misfire codes, and sputtering, has good compression and spark. I've attached logs. Log 27 idle with a rev. not sure what the other 2 logs were but I know they were logged in fault. Any ideas would help. |
