 Old 01-10-2019, 07:46 AM   #1
SkippyScallop's Avatar
Posts: 65   (View Stats)
SkippyScallop is an unknown quantity at this point
Default Compatible wheel/tire size for snow?
Will a set of 16x6.5", 114.3mm with +46mm offset fit with our cars? I did search and read previous threads, but there have been mixed comments about whether or not it will fit over the calipers.
Additionally, would 205/60/16 be an appropriate size tire for those wheels?
SkippyScallop is offline   Reply With Quote
 Old 01-10-2019, 02:02 PM   #2
Posts: 2,235   (View Stats)
Some 16inch mags fit the ms3 but the ms6 need at least 17
I don't know about offset but 6.5'' wide is a bit tight
 Old 01-13-2019, 06:40 PM   #3
6.5" width is tight?
 Old 01-13-2019, 10:07 PM   #4
Police - Grammarhead
Vansquish's Avatar
The stock wheels are 7.5" wide, so yes, 6.5" would be tight.
 Old 01-14-2019, 07:48 AM   #5
i checked, you can mount a 215 on 6.5'' but best would be 7''
 Old 01-14-2019, 11:08 AM   #6
Sorry, I was referencing gen1 MS3 so I think our stock ones are: 18x7 | +52.5mm offset
Having clarified that, would the 6.5" be a solid option for snow tires?
 Old 01-14-2019, 01:31 PM   #7
This is about the tire you want to mount on it.
So yes 215 on 6.5 is approved by the few tires brands i checked so it should work as long as the offset fit too.
you can compare at place like that.
https://www.wheel-size.com/calc/
wheel and tire size help? nwalker Wheels & Tires - BLACK 8 11-16-2011 06:03 AM
Best tire size to fill wheel gap SLOWHATCH 2010 MS3 - Wheels & Tires 11 07-10-2011 03:02 PM
tire/wheel size calculator ZoomByU MazdaSpeed 3/6 - Wheels & Tires 3 07-22-2010 06:03 PM
Wheel/Tire Size for Lowered MS3 mrjoshyman MazdaSpeed 3/6 - Wheels & Tires 0 07-20-2010 03:58 PM
Page generated in 0.26469 seconds with 22 queries
